Question about Watches
Need instruction manual on how to set the time, alaarm and program remote control code
Como hago para que me funcione el ensendido del tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Aug 03, 2015 | Casio Watches
Klik radio controlled watch
Why would he need the manual to do that ???
The time is self setting !
and to chage the battery just take out the back cover and slide the pin holding the battery in place, and replace it with the with similar battery...
I will try to find the manual for you..
post back in a second
Jan 09, 2008 | Watches
Where can i get a replacement battery for a Ohsen wr30m Watch?
In order to help people set the ohsen sport watches easlier in the right way, our company (www.360sportwatches.com) write the ohsen watch manual instruction in English for all the ohsen watch users, hope this page is useful for you to set your ohsen watch, this ohsen watch manual operation is suitable for almost all the Ohsen digital electornic watch, also it is suitable for the ohsen analogue quartz digital electronic sport watches, for details ohsen watches models, please have a look at the following content!
Ohsen watch manuales instruction description:
A Key = Light
B Key = Mode
C Key = Start
D Key = Reset
In normal time to show, press the button to enter B mode, click Settings when choosing D Key respectively, minutes and seconds, C key to adjust.
Hours, minutes, seconds, month, day, week;
12/24 hour clock selection
* Daily Alarm Clock
Daily alarm only " Hours" and " Minutes" to choose
The whole point timekeeping
* Running Seconds
From 0.04 seconds start running time;
The Longest 23 hours 59 minutes 59 seconds
* EL black light
Any mode, press the A light EL backlight for 3 seconds
* Use 3V batteries
Running Second Mode:
Press B button click into the race second mode, press the C key to start timing, the timing of the state, press the D key to pause time;
At the time of state, then C key, stop the clock, press the D key to this state would be zero time.
Press B button to return to normal time mode;
Alarm setting mode:
Regular time mode, press the B button 2 times into the alarm set;
Press C key to the "alarm" whole point of time" to set " open" and "off";
Press D key to adjust the hours, minutes;
Press C button to adjust the number of selected;
Press B tutton to return to normal time statues.
At the same time in any state, this button will issue a Bi Bi sound;
Time, date setting mode:
In normal working mode, press the B button 3 times to see the second in the flashing, then press the C key, " seconds" will be zero;
Press D key to select each "Hour" " Minute" " Day" " Week" set;
Press C key, you can adjust the number;
Press B button to return to normal time status;
12/24 hours;
Under normal travel time; Press B button 3 times to enter time setting mode, then second in the flashing, second place in the transferred into " H" when the table show has been converted to 24 hours system; when the position becomes"O" on the afternoon of adjustments; seconds into "R" for morning; "P" for PM.
Apr 01, 2015 | Watches
Program my Toshiba remote ct-8037
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://electro-medical.blogspot.com/
Oct 19, 2014 | Toshiba 40UL605U 40-Inch 1080p 120 Hz...
Waveceptor reset
I have a number of these Casio and Citizen watches. This watch does not use GPS for the time keeping. It uses a land based broadcast time signal. There is public information about where the signals come from for your area. The technical breakdown of the time code signal is public access information.
The instruction manual of the watch has the information about when your watch should automatically receive the time signal, and how to set up the watch. Many of the manuals also included a map showing the time signal coverage, and includes the time of day information to show when the signal is strongest.
Make sure the watch settings are for your time zone. This is important. If the main time zone is not for your area it will be trying to receive the signal at the wrong frequency at the wrong time of day. There are areas where the signal may not be able to be received. You can get the mapping for this from the service that the watch has been set to use.
In North America the auto time receive is supposed to take place between midnight 00:00 to 04:00. In the eastern part of North America the reception is poor compared to central and western part of North America. Check the instruction manual for your watch for details.
Below is the spec listing of your watch.
  • Atomic Timekeeping
    Receives time calibration radio signals which keep the displayed time accurate
    Auto receive function (3 times per day)
    Manual receive function
    Signal: WWVB, UK MSF Frequency: 60kHz
  • 50M Water Resistant
  • EL Backlight with Afterglow
  • World Time
    29 times zones (30 cities), city code display, daylight saving auto/on/off
  • Date Alert
    Display flashes when set date is reached
  • 4 Daily Alarms and 1 Snooze Alarm
  • 1/100 second digital stopwatch
    Measuring capacity: 99:59'59.99"
    Measuring modes: Elapsed time, lap time, split time, 1st-2nd place times
  • Hourly Time Signal
  • Auto Calendar (pre-programmed until the year 2039)
  • 12/24 Hour Formats
  • Accuracy: +/-20 seconds per month (with no signal calibration)
  • Battery CR1620
  • Approx. battery life: 2 years
  • Module 2556
Size of case / total weight
WV57 47.0 x 39.0 x 12.5mm / 44g
WV57HD 47.0 x 39.0 x 12.5mm / 89g
Apr 29, 2014 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
I received a Sharp Remote Control Watch as a gift but it has no instruction manual. I am unable to set the time properly and would appreciate some help in getting the watch set up.
I would love to help with this problem...but I need to know the Model of the watch first. They perhaps I can give you detailed instructions on how to set it.
Thanks,
Sandy
Apr 11, 2011 | Watches
Watch will not programe to England Time
If it is 1 hour out it could be on daylight saving time setting (DST).
If you haven't got any instructions you can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Feb 15, 2010 | Timex T5G341 Sports Radio Control Watch
Battery replacement for casio wave ceptor wvq-200hu WATCH
Download abridged instructions from casio @ http://world.casio.com/wat/download/en/manual
Apr 05, 2009 | Casio Waveceptor Atomic Radio Controlled...
Setting wrist remote controller
Follow the link below and follow the instructions for finding your watch module, once this is done you should be able to download your particular watch manual. Good Luck!
http://world.casio.com/wat/download/en/manual/
Feb 09, 2008 | Casio Technowear CMD30B1T Wrist Watch
Need Codes for remote control watch
I have located instructions. I have them scanned and can send them to anyone who would like them. email cosmicnomad@verizon.net
Nov 10, 2007 | Watches
Watches Logo
12 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
