Question about Jet Health & Beauty
My chair controller keeps blinking untill I push on and off button then it can start going, as long as I not turn it off, most of time. Also the buttom that makes it fast or slow won't work. when I can start it when you want to stop it keeps going of course slow.
  • 3,083 Answers
Read this review:
http://www.usatechguide.org/itemreview.php?itemid=926
This fellow's having a lot of continual problems with the controller and wiring, so it's just not you. My suspicion would be that some part in the controller is going bad, and that will take servicing.
Here is a site that sells controllers, parts, and also services them:
http://www.monsterscooterparts.com/rebuild-service-pride-jazzy-jet-quantum-joystick-controller.html
Good luck, thanks for using FixYa, and hope this helps!
Posted on Aug 21, 2010
Lights flashing when turned on, replaced batteries,fuse, in drive position
the amount of flashing lights will give you a Flash code. If the the lights are going up and down, you may have a locked joystick. one method is to turn on and (within 10 sec.) push the horn button twice. Push the power button then push the joystick forward until there is a beep sound then back until you hear a beep sound to unlock.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Mar 30, 2016 | Pride Go Chair Power Chair
WHEN POWER ON CHAIR SPEED LIGHT BLINK .BOTH BATTERY WAS REPLACE AND JOYSTICK.SAME PROBLEM
The battery meter lights will flash a flash code when something is wrong. If the lights are flashing the same number of lights each time. get that number it is a flash code. if the lights are cascading up and down that indicates that the Joystick is locked. unlock by turning on the joystick and pushing the horn button twice within 10 sec. of turning on. Or push on button and hold the joystick gimbal forward until it beeps then back until it beeps. This should have it unlocked, if not Pride Jazzy Tech 800-800-8586
Mar 28, 2016 | Pride Mobility Used Power Chairs Jazzy...
Unlock control stick for jazzy select power chair.
Gerald,
Well there are a couple ways, One is push the start button within 10 sec. push the horn button twice. This should do it, but if it is a different Joystick then try, push the button to start then hold the Joystick forward until it beeps, then hold the joystick knob back until it beeps and then it should be unlocked.
Strege Mobility
Dec 04, 2015 | Select Health & Beauty
How can I program my RCA universal remote to my element tv , what button to press for the light to blink and the code to put so it can work on my tv
RCA does not have for a code Element TV. With that being said there is a work around:
Turn on your TV.Then push the code search button until the LED still ,when the LED keeps on let go the button now push and release the TV button then push and release the power button until the TV goes off, when the TV turn off stop to push the off button now push the set button the code are already set on the remote control( you might have to push the off button almost 100 times or more until you get the right code for your TV. Best of Luck
Aug 26, 2015 | RCA Televison & Video
The wheel chair when I push the button to turn off the power lights will go off but then come back on blinking 6 times, and keeps on doing it until the battery go's dead.
6 flashes indicate a right park brake fault or you have the right wheel in freewheel check the freewheel lever on the right motor to make sure it is in the drive mode Hope this helps
Mar 28, 2011 | Electric Health & Beauty
Not sure witch jazzy chair i got but the joy stick blink and keeps blinking i have tried pushing horn button twice and also turning it on and pushing joy stick forward waiting for it to beep but no beep....
The jazzy probably has a VSI controller and if it is sleep mode then the lights will scroll rather than blink. Now turn on the chair and see if the blinks have a pause between them, ie 4 blinks pause 4 blinks pause etc If they do count the number of blinks and this will give you the error code ie 4 blinks right motor 3 blinks left motor your owners manual should have a chart listing the error codes If not you can contact Pride tech support @ 1-800-800-8586 ask for jazzy tech support
Hope this helps
Feb 17, 2011 | Pride Jazzy 1103 Ultra Standard Power...
LOCKING/UNLOCKING THE VSI
The VSI has a feature that enables you to lock your power chair to prevent
unauthorized use.
To lock the VSI:
1. With the VSI powered on, press and hold the on/off key. After one (1)
second, the VSI should beep.
2. Release the on/off key.
3. Push the joystick to the full forward position until the VSI beeps.
4. Pull the joystick to the full rearward position until the VSI beeps.
5. Release the joystick. There should be a long beep.
6. The VSI is now locked.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile
indicator should ripple side to side.
Good Luck
mimobility
The lights blink but it want move when you pwer
The chair is in lock mode. To unlock, turn on, when the lights start to scroll, push the joystick forward and keep it there until you hear the beep. When it beeps, pull it back and wait for the beep, once the beep sounds let go and listen, if you hear a high pitch beep, success. If it doesn't work the first time, just do it again. Sometimes it may not work right away but don't panic, just follow the steps again.
May 12, 2010 | Jet 3 Ultra Power Chair
I have a wireless controller that won't connect with my Xbox 360. The batteries are not dead, and whenever I press the button to turn on the controller it just keeps blinking instead of showing that it is...
sync the controler to the xbox. there is a small button on the top of the controller next to the plug in for the cord. push that button along with the button next to the reciving eye on the consel. push them both at teh samt time until they stop spinning and start flashing as if they had low batterys.
Jan 13, 2010 | Microsoft Xbox 360 Controller
Health & Beauty Logo
48 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
Louis Smith
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
