I have connected my ML 2510 to my laptop using parallel to usb cable. Now it reports this problem after printing one or some pages.
  • tajda_rezek Aug 21, 2010
    I have done reinstalling based on your link 'click here' (samsung.com). Tried installing some drivers, did not work. Tried to run services.msc, did not work, same trouble. Then uninstalled every driver, installed again driver ML2510_SP, changed port where USB is connected. Restarted, works, prints, has printer from Adobe, Word ... up to 18 pages. Works, but it still reports the same message. I suspect the port problem. Thank you, you have helped.
    President:
  • 3,278 Answers
Hello.
Since your printer comes with both Parallel and USB interfaces, try connecting with a different cable (USB instead of parallel). Or, try another of the same type.
If still a problem, please clarify what problem or error message or code is displayed.
Hope this helps.
Posted on Aug 22, 2010
  • 4,281 Answers
First try it in different usb ports also make sure cable is working fine.Then if still same issue then uninstall printer driver from computer then reinstall from below link. Click here Aslo make sure printer spooler service is start.You can check it in services list. For that press windows key +R so you can see run or go to start menu->run type in run "services.msc" without "" then press enter then you can see services list find printer spooler service right click on it then restart it.Then check. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Aug 21, 2010
Samsung ML-2510 Printer will not work with Macbook Pro - OS X
try to use the Generic drivers and not the Samsung ML driver for your model. In the drivers list type in GEN and it'll show up.
Dec 12, 2009 | Samsung ML-2510 Laser Printer
USB to Parallel connection (Panasonic KX-P1121)
I would recommend buying a Printer parallel port connection (PCI to LTP1), install it into the system, and use the printer parallel cable.
Sep 02, 2009 | Nikon COOLPRINT Thermal Printer
Driver for Samsung ML-1640 for WIN98SE
I got the same problem. It seems they did not develop specific drivers for win98se. However, I found that you can print using the drivers for the old Samsung ML-2510. Win98se drivers for that printer can still be downloaded from Samsung website. I've been using the 2510 drivers with the 1640 printer for a couple of months, and worked fine so far. It seems very little change in electronics from the 2510 to the 1640 model.
You need also Virtual Printer Port for USB from microsoft.
Jan 07, 2009 | Samsung ML-1640 Monochrome Laser Printer
Samsung ML-2510 will not print from MAC OS on Macbook
Hi, sorry to hear you are having problems,
OK, first of all, you can stop worrying about solution #3, this printer is a USB or Parallel, there is no networking on this printer so no possibility of an AppleTalk connection.
You say you have downloaded the latest version of the driver from the Samsung website.
And, the Mac is connected DIRECTLY to the printer via USB.... ( It won't work if it's connected to a PC and then shared.. well it might work but I have not been able to make this kind of connection work...)
Well, if this is the case and you are unable to print while the PC prints fine, I expect that it is over the Parallel port or do you plug and un-plug between the Mac and PC...
It might be that the printer needs to reset after switching between the Mac and the PC, Shut off the Printer, I mean really, shut it down, unplug it for 30 seconds then connect it to the Mac and restart the Mac and start up the printer....
If it still does not work, do you have another Mac you can connect to for testing?
Also, the first test should not be FireFox, open the Text Edit app and type ( TEST ) and just print that...
Give that a whirl..
Dec 22, 2008 | Samsung ML-2510 Laser Printer
Printer doesn't work
it seems to me that you might gotten the wrong driver install in your system.
error page - Position: )x42b (1067) System: h6fwaim_mono/xl_image Line: 132 Version: QPDL 5.04 04-25-2005
do a check on your OS version. Operating system. right click mycomputer icon -> properties.
download the correct version of driver from Samsung website again. uninstall the currect version and unplug the usb cable to the printer.
restart your system, install the downloaded correct version and plug in the usb cable to the printer. do a custom install to serach for the printer. if it does search the printer. it will show you. USB001. after install you will be prompt to do a test page. test on it to see it works.
if it does not work after downloading and install the driver. You might have a mainboad firmware corruption.
to run a firmware update is not easy it might course other major issue. only install by an trained Samsung Engineer.
Hope this Help :)
SamsuTech
Sep 20, 2008 | Samsung ML-2510 Laser Printer
Samsung ML-4500 with IEEE 1284 to usb cable not working
Windows XP/VISTA (do not install the CD)
1) Plug the cable into the USB port on your computer.
2) A prompt that says "Found New Hardware" will appear. Windows will then install the USB printing support driver automatically. You do not need to install the driver from the CD.
3) Plug the cable into the printer.
4) If your printer is already installed, click on Start, then Printers & Faxes. Right click on the printer you are connecting to and click on Properties. Click on the Ports tab and check the ‘Virtual printer port for USB’ port. Click OK.
5) You should now be able to print.
With XP, the biggest clue is to FIRST plug the cable into the usb slot, THEN the other end of the cable into the printer.
May 14, 2008 | Computers & Internet
ML-2510
can you do a test page to verify if you have a printer or software driver problem...
Press and hold the Cancel button for about 2 seconds.
A demo page prints out.
Make sure that the
Online LED on the
control panel lights
green.
• If the Online LED is off, check the power
cord connection. Check the power switch.
Check the power source by plugging the
power cord into another outlet.
• If a demo page does not print, check the
paper supply in the tray.
Print a short document from a software application to verify that the computer and printer are connected and are communicating correctly.
• If the page does not print, check the cable connection between the printer and the computer.
• Check the print queue or print spooler to see if the printer has been paused.
• Check the software application to ensure
that you are using the proper printer driver
and communication port.
more info required
Nov 13, 2007 | Samsung ML-2510 Laser Printer
Unable to print
If both printers are connected through a parallel switch, be advised that changes on the switch do not take effect until the computer is restarted. Those boxes worked fine under DOS, but Windows does not support them. Connect the Samsung printer to the USB port and make sure you use a good quality cable and not those thin and cheap cables.
Aug 30, 2007 | Samsung ML 1210 Laser Printer
Computers & Internet Logo
David Payne
David Payne
