Question about Canon VIXIA HF10 HDV Camcorder
Does not power on. Not on battery or with the adaptor.
    Genius:
  • 1,812 Answers
This is usually caused by a failed component in the power circuit within the camera and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired qualified service technician.
Posted on Aug 21, 2010
When I hit the power on button on my compaq nc6220 the yellow battery light flashes and nothing happens
Please try removing the battery, and then connect the power adaptor and try switching the laptop on see it if works if it works then the battery needs to be replaced. I would also recommend if you can check your power adaptor / swap your power adaptor with a know good adaptor (if you have one). The remaining steps will depend on the outcome of the steps above.
Oct 02, 2012 | HP Compaq nc6220 Notebook
My laptop battery is drained to battery low after being fully charged.
two possible couses.
first one the adapter is not charging well the battery and therefore the adapter contains a problem.
the second one the battery is damaged.
Aug 12, 2010 | Computers & Internet
Laptop does not work off mains and battery does not charge
Just check the power connection from the AC going to your laptop if the power adaptor of your laptop are working. Note; you only know that the power adaptor was working if the LED (Light Emiting Diode) was light because the power adaptor are have the LED to see it that they are working normally. If the power adaptor working normally their was a problem of the power supply inside your laptop and need to be repair by the electronic service center. But if the power adaptor are not working the problem are in the power adaptor. I recommend that you replace your power adaptor and bring it to the computer store to check its type and model it is because only same type or model of that power adaptor to be replace.
May 19, 2010 | Dell Inspiron 6000 Notebook
Laptop will not power up.
  • If possible, make sure there is power coming from the power adaptor with a voltmeter. If nothing shows, the adaptor needs replacing or repairing.
  • Try removing the battery and running on the power adaptor alone. If this works the battery is dead. You can buy a new battery or just run it on the adaptor.
Apr 08, 2010 | Gateway MX6450 Notebook
My v2000 will not come on at all? I have it plugged in with the adapter and it's like there is no power to it at all?
check power supply adaptor and batteries if they are supplying enough power, if you can borrow a power adaptor and spare battery try replacing them with one your notebook has.
if it works then your adaptor and batter are out, normaly if the adaptor stops working the battery would have died down too as you would have not noted till the notebook totally died down.
Dec 07, 2009 | HP Compaq Presario V2000 Notebook
Toshiba satellite m35 power issues
Hi !
While power off, disconnect the power adaptor.
Take off battery.
Plug the power adaptor back and try to start !
Is it running?
If yes, than the power adaptor is OK.
Now shut down and disconnect the power adaptor.
Put back your battery and start!
Leave it untill you 'empty' the battery.
Do not start your laptop.
Plug the power adaptor and do not start your laptop yet.
Is there a led idicator showing that the battery is charging ?
Does it shows when the battery is full charged (e.g. red/yellow=charging, to green/off charged)?
If not, leave it for at least 3 hours. After that, start your laptop (adaptor is plugged) and see if you still have an icon saying charging 99%.
If that is the case, then something is wrong with the battery.
Check your warranty, and replace it.
DO NOT OPEN the battery - nothing interesting you will find inside - nothing you can do !
Regards.
Mar 28, 2009 | Toshiba Satellite M35-S456 Notebook
ACER ASPIRE LAPTOP 2920 NO DISPLAY
Ckeck if your adaptor has power on the connector to laptop.
Might be damaged power cord (to and from the adaptor) or broken adaptor.
While there was power in the battery, it was running, but not charging.
Now the battery is emty and can't be charged because of broken adaptor/cables.
If you find there is no power from the adaptor, bepair it or buy a new one.
Do not try to repair the adaptor by yourself if you are not a technician, it is DANGEROUS !
Either give it to a qualified servicer, or betteer, buy a new one.
Regards.
Mar 27, 2009 | Computers & Internet
Lack of Power
1) Battery can be derect.
2) Power adapter can be defect.
3) Power jack can be defedt.
In about 50% of such cases it is the power jack.
Bring it to a repair shop. They can check very easily the battery and the adapter to find out the problem.
Nov 17, 2008 | HP Computers & Internet
My psp wont turn on!
  • Hi! TRY THESE TO SEE IF WE CAN GET YOU POWERED UP! :)
    Confirm the system is not in HOLD mode
    Make sure the PSP system is not in Hold Mode (in the down position). Slide the Power/Hold switch up to clear Hold Mode. Or try sliding the Power/Hold switch up and holding it there until the power indicator light turns off and the PSP system is completely turned off. Then try turning the PSP on again.
    • Confirm the backlight is ON
      Make sure the LCD screen's backlight is not turned off. If it is, press any button to turn ON the backlight.
    • Confirm use of only licensed products (AC Adaptor, battery pack and charger)
      The AC Adaptor, battery pack and battery charger must be licensed for use with the PSP system. All licensed products for use with the PSP will have the following logos displayed directly on the product and/or the packaging:
      pslogor.gif global_logos_psplogo_168x35.jpg global_logos_scealogowhite_60x73.gif
      If any of the products you are using does not have these logos on them, we recommend that you immediately discontinue the use of these products, as they void the PSP system's warranty, and can cause damage to the system. See compatible peripherals for the PSP system for a full list of supported products.
      There are some products that can be used with the PSP system that may not display our logos. Products such as San Disk 1GB Memory Sticks, or various USB cables, needs only to be genuinely certified. Look for the genuine certified logos on these products or contact the company which manufactures these products for more information.
    • Confirm the battery pack is correctly inserted
      Make sure the battery pack is in its proper position (see inserting the battery pack for details).
    • Try the battery pack only
      Unplug the AC adaptor from the PSP system. Make sure a charged PSP battery pack is inserted inside the PSP system. Turn on the unit. If you get power, then the problem may be with the AC adaptor and power cord.
    • Try the battery pack in a different PSP system
      If possible, try your PSP battery pack in a different PSP system. If your battery works on a different PSP system, it may indicate an issue with your PSP system.
    • Try a different PSP battery pack
      If possible, try a different battery in your PSP system. If a different battery pack does work on your PSP system, it may indicate an issue with the original battery pack.
    • Try the AC adaptor and the PSP battery pack
      Insert the battery pack and plug in the AC adaptor. If you still do not get any power, your PSP system may need to be sent in for service (see PSP Service for details).
    • Try the AC adaptor / power cord only
      Turn off the PSP system, unplug the AC adaptor, and remove the battery. Now plug in the AC adaptor to the PSP system with the battery removed. Confirm the AC adaptor and power cord are firmly connected to each other. Now make sure they are also firmly connected to the PSP system and the electrical outlet.
      If the PSP system powers on, the battery may need to be replaced.
    • Check AC adaptor and power cord for damage
      Visually inspect the AC adaptor and the power cord for damage. Do not use if frayed, cut, or damaged in any way.
    • Check the electrical outlet
      Confirm the electrical outlet that you are using is active (receiving power). Try using a different electrical outlet.
    • Try a different AC adaptor and power cord
      If possible, try a different AC adaptor and power cord. If a different AC adaptor and power cord does not work, the PSP system may need to be sent in for service (see PSP Service for details).
    • Confirm no unauthorized system software or downloads were used
      Confirm that you have not used any unauthorized system software updates or downloads on the PSP system. Use of such unauthorized firmware updates voids the warranty and can damage the PSP system.
    • WLAN turned off
      Make sure the wireless (WLAN) network function is not in use while charging. The battery pack cannot be recharged when the WLAN function is being used.
    • Power surge
      If you experienced a power surge, shortage, or a lightning storm in your geographical area recently, this may have affected the PSP system's power supply. Please contact Consumer Services below for information.
    Sep 03, 2008 | Sony PlayStation Portable (PSP) Console
    COMPAQ V2000 WILL NOT POWER UP WITH DC/ADAPTER OR BATTERY
    Hve u tried a differnt adaptor , the adaptor might be blown too ,try replacing the adaptor , also check for the power cord if it has any kinks in it which may be interrupting the power supply , since the adaptor 18.5 v 3.5 a is the most common of all hp adaptors u should find one to try .
    Aug 27, 2008 | Compaq Presario R3000 Notebook
    Canon VIXIA HF10 HDV Camcorder Logo
    190 people viewed this question
    Top Canon Video Cameras Experts
    Chance Miller
    Lawrence Oravetz
    abdul rauf
    abdul rauf
    Are you a Canon Video Camera Expert? Answer questions, earn points and help others
