Question about Mitsubishi WS-73909 73" Rear Projection Television
Does the Mitsubishi ws-73909 support hdcp and if not how do I get HD from my xbox360? I am currently running a hdmi cable into my hd fury3 into the dtv input and I do not have a picture.
  • Mitsubishi Master
  • 5,184 Answers
I don't think it does since it doesn't have an HDMI input of it's own. You may be better off connecting your Xbox to the TV by component video (Red, blue, green RCA connectors with audio L/R on a separate cable).
I wish that I could be of more help.
Posted on Aug 21, 2010
  • Cindy Wells Aug 21, 2010
    I mean the component video ports labeled 6 in the manual, just to the left of the DTV input.
How do I convert hdmi to RCA composite?
that outputs HDCP hdmi. you probably cannot convert it on a sony. they use software DRM on the hdmi output. Vivid AV HDMI to Component RGB Audio Video Converter
This supposedly talks to the HDCP on sony. Your mileage may vary.
Jan 26, 2015 | Mitsubishi WS-73909 73" Rear Projection...
Can't hook up hd
I would be surprised if the model listed here has a HDMI input--it should only have a single component HD input marked as DTV.
Jun 14, 2012 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi WS-65413 hdmi to component
unless you can find some kind of adapter--no. And for that matter the set has a HD input that is component----HDMI may use less cables but is prone to a lot of issues.
Apr 16, 2012 | Mitsubishi WS-65413 65" Rear Projection...
Hi, how can you connect my Mitsubishi ws-73909 to HD? Do I need some sort of an adapter? HDMI - VGA adapter , HDMI - RGB adapter, or etc...? Thanks for you help!
Are you trying to connect this tv to an HD device like a satalite receiver or a cable box. If so you will need an HDMI cable which cose between $20- $60 and your cable or satalite received must be HD ready.
Jul 21, 2011 | Mitsubishi Televison & Video
I have a pioneer vsx-30 with hdcp error on the face i see it when a scientific atlantic cable box is connected through a componet connection
Component cables don't have the ability to carry decrypted HD info.
HDCP is "High Definition Copy Protection"...In theory, it prevents you from running the HDMI cable out of your receiver, and into a recording device, thereby recording HD content without a license for it.
HDCP handshaking is done between devices that run HDMI, or DVI.
If you're running component from your Cable box, and then HDMI out to your TV, then the content you're carrying from the Cable box may not be getting decrypted properly when it gets upscaled onto the HDMI port from Component.
IT could also simply be that you're using an HDMI 1.1 or HDMI 1.2 cable, which may not be able to carry the high bandwidth stream of your Receiver and TV.
Please be sure that all HDMI devices can support the same HDMI version, and also be sure your HDMI cable is labled "HDMI 1.x compliant". . .e.g. if your TV and Amp support HDMI 1.2, make sure you're also using an HDMI 1.2 Cable.
Apr 21, 2011 | Pioneer VSX-305 Receiver
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
I have a 2002 Mitsubishi Medallion TV. The only input for HD is DTV (no DVI or HDMI inputs). Is there a converter box from HDMI to DTV that will allow for 1080i resolution?
From looking at the back panel of the TV, the DTV input can be configured as a component video. The M-Link/DVI-HD port is also a DVI with HDCP port and maximum signal handled is 1080i. The M-Link should work with an HDMI to DVI cable or adapter. For this to work, the source must not be a computer or another device using the default computer video output (computers give RGB output). The DTV port would need an HDMI to Component video converter. See this page for some examples: http://www.hdtvsupply.com/hdtocoad.html . The first one in the list (for Netflix and Boxee among others) will give 1080i out if the source is set correctly.
Most DVI-HDMI cables are single link. I've seen some examples where DVI-I (single link) and DVI-D (dual link) cables are not interchangeable. If you have video problems, check your cable. An HDMI to DVI adapters will let you run an HDMI cable up to the TV and then converter at the TV as a separate connection.
I hope this helps.
Nov 17, 2010 | Mitsubishi WS-65613 65" Rear Projection...
Hooking xbox360 up for HD in component 1
Thats the highest setting, for component, that TV will show. it really is that simple. You would need HDMI connector to possibly go any higher. but I think you will find it is the TV.
Apr 01, 2010 | Mitsubishi WS-55511 55" Rear Projection...
BLUE RAY 1080 (p) PLAYERS INHANCE VISUAL HD ON 1080 (i) tV
try to see if u have hdmi slots and check the highest resolution it can go.there is a higher resolution called hdcp,with not div x but dvi-d where resolution can go up to 20000
Feb 06, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Open Questions:
Mitsubishi WS-73909 73" Rear Projection Television Logo
201 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
