Question about Canon PIXMA MP830 All-In-One InkJet Printer
Error Codes 6A00 and 5C10
I had an error code 5100 that I thought I had solved. I removed a foreign object that was stuck under two of the white flat parts, about 1" wide with rollers, that are located just under where the printer head slides back and forth. The unit restarted correctly so I tried to perform some cleaning. First, it came back with error code 5C10 and now it shows error code 6A00. I've seen a suggestion that I should check the area to the far right of the printer head but it is stuck to the right.
I'd really appreciate any suggestions. Thanks!
  • Anonymous May 17, 2008
    I have the error code 5101 come up all the time so I have to shut it down & then turn it back on again. It seems it does it mainly when one of the inkjet cartridges are getting low. This is very annoying as well as whenvever the ink cartridges just start getting low you have to keep pushing "ok" after you push the copy button.
  • Anonymous Mar 23, 2014
    how to take back off printer and check for blockages and clean rollers
  • 36 Answers
I tried everything suggested on other posts (cleaning paper feeds and making sure rollers were free, moving carriage back and forth manually, etc)., but nothing worked. With it still plugged in, I turned the whole thing upside down and shook it. It hummed and buzzed, and moved the carriage a couple of times. Viola, problem solved. Go figure.
Posted on May 18, 2008
What does 5100 code mean?
What is error code 5100 on the MP460? - Canon Community
community.usa.canon.com/t5/Personal.../What...code-5100.../103212
Jul 7, 2014 - Please remove foreign objects so that the print head holder can move: ... closet and hooked it up this morning, I was getting the 5100 message.
How to resolve error 5100 on an MX452 / MX459 - Canon
https://support.usa.canon.com/kb/index?page=content&id...
There are several reasons for error 5100 to appear. ... If the above recommendations donot help you resolve the error, the printer will need to be repaired.
How To Fix Canon Printer Error 5100 - YouTube
? 2:23
https://www.youtube.com/watch?v=rJQVwwRxPv4
Mar 14, 2013 - Uploaded by ITJungles
Learn how to fix the Canon printer error 5100, and have your printer running again. ... Reset error Canon ...
Jan 05, 2016 | Canon PIXMA MX340 Wireless Office...
How do I fix Fatal Error Fatal Codes:0X50 for Epson WF-2530
there is a driver update to this on there website.. http://2682220.r.msn.com/?ld=d3r7GeHDlTJrBUpqiKpMxT4jVUCUxr5V_qRawzP5W1kwg55cbcz5eg53VjPRThl_AClX5g-BdWf6mHDw2SlSJsTLfN9nJeK4phMY0-ErdgNCyKWWQgEXUUIi9nCuedGmcy6X7gtUKmemkIwZMZZFqFwJ3TIWhMol4QEau4TTcG8TFQ8ApN&u=https%3a%2f%2fwww.pcsupport4me.com%2fprinter-tech-support%2f
Nov 11, 2014 | Epson WorkForce WF-2530
Error 5100 error code
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 10, 2010 | Canon PIXMA iP6220D InkJet Photo Printer
Receiving error code 5100. what to do?
Next try.
Solution 1:
Solution 2:
Mar 05, 2010 | Canon Pixma iP6600D InkJet Photo Printer
Next try.
Solution 1:
Solution 2:
Mar 04, 2010 | Canon Pixma MP450 All-In-One InkJet...
What does error code 6A400 mean
Next try.
Solution 1:
Solution 2:
Mar 03, 2010 | Canon Pixma MP500 All-In-One InkJet...
Error 5100
Next try.
Solution 1:
Solution 2:
Feb 19, 2010 | Office Equipment & Supplies
Error code 5100
Next try.
Solution 1:
Solution 2:
Feb 10, 2010 | Canon PIXMA MX300 All-in-One Printer
Error 5100 on canon mp 160
Hi You can Try
Error Code 5100
Solution 1:
Solution 2:
Hope it do for you
Nov 27, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Cannon printer mp460error code 5100
Service Error 5100 is Displayed
Cause
Action
Movement of the FINE Cartridge Holder is blocked.
Clear the paper jam or foreign object that is preventing the FINE Cartridge Holder from moving, cancel printing from your computer, then turn OFF the machine and turn it back ON again.
Nov 05, 2008 | Office Equipment & Supplies
Canon PIXMA MP830 All-In-One InkJet Printer Logo
279 people viewed this question
old marine
old marine
