Question about Refrigerators
My machine does not dispense cold water - Refrigerators
Mine doesn't either. How do we fix this.
Posted on Sep 26, 2010
No water is getting into the washing machine. Error code display and soap is still in dispenser.
machines have a hot water and a cold water intake
if the water cold isnt getting to the blue intake it wont work
as you have an error code
post the error code it displays
you posted insufficient info to come to a good recon
Sep 24, 2014 | LG WM0642HW 4.0 cu. ft. Front Load Washer
Hot water not dispensing
I ve glacier bay hot/ cold water dispenser - new product. Cold water is coming but no hot water. Water is not coming. What have I to do it is a week old machine.
Nov 20, 2013 | Vitapur Water Dispenser. Hot, Room and...
Cold button is pressed and warm water comes out
water valves might be wired wrong or water select control is bad or wired wrong
Apr 10, 2009 | Maytag Atlantis MAV7551 Top Load Washer
Bosch Washing Machine Softener Tray not emptying
You need to replace the cold water inlet valve. If the machine is older than one year it may be clogged on the side that moderates the cold water to the bleach and softener compartment. Replacing the valve fixed the problem. During the cycle when the softener dispenser fills it should fill quickly and no or little water should be seen in the soap dispenser area. If a lot of water goes into the soap dispense and little into the softener area the valve is clogged.
Feb 15, 2009 | Bosch Logixx WFT 2806 Front Load...
Fabric softener does not drain out of dispenser
Hi. Remove dispenser and thoroughly clean, are you sure you have cold water going into dispenser?
Nov 25, 2008 | LG WM-2277HW Front Load Washer
Hot water
Have you kept up with descaling?
Probably the water heater has failed. If you're technical then most parts should be replaceable but you may have to order them from Gaggia in Italy.
Oct 30, 2008 | Gaggia Titanium Espresso Machine
I have a lady Kenmore washing machine that when you put the temp on cold cold, it will first pour warm water through the front liquid despenser and then it will fill most of the way in cold from the back. ...
this is the way it was designed. cold water will not dissolve the detergent in the dispenser completely. if you want cold water only then connect cold water to both the hot and cold connections in the back of the machine.
Jul 16, 2008 | Washing Machines
When I use cold wash on my Miele W830 the water heats. Any solutions?
check the water connections going to the back of the machine, you may have the hot and cold mixed or reversed. if you turn it on hot water will it dispense cold water?
Jun 30, 2008 | Miele Washing Machines
Cold water not dispensing
the water valve is bad replace ,Water inlet valve kit
Recommended related item(s): 782959
Apr 21, 2008 | Amana ALW480DA Top Load Washer
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
