Question about Husqvarna Forest & Garden 125l 18" Gas Trimmer
Replace the head on Husqvarna 125L ... The trimmer head broke from the bumping and I can not pull the old head off to replace it
    Sergeant:
  • 337 Answers
Hi winipig1 the heads dont pull off they screw off. Spray some lube oil behind the head and it should free it. It will undo clockwise
Posted on Oct 12, 2013
4 Suggested Answers
SOURCE: Husqvarna Gas Line Trimmer Head melting
wrong fuel/oil mixture...try 25mls of oil per litre fuel.
Posted on Apr 04, 2009
  • 28 Answers
SOURCE: I have a husqvarna 125L gas trimmer and dies after
Could be clogged gas cap. Take the cap off and see if you can blow air through it. If no air passes, the trimmer will become vapor locked and wont be able to get enough gas.
Posted on Jun 23, 2009
FreeTech
  • 426 Answers
SOURCE: replace pull rope
there should be a retaining C Clip that will need to be removed from the shaft look closely!
Posted on May 23, 2010
I have a Husqvarna 125L weedeater, New Fuel, has spark but will not start. Pulling the starter rope makes me feel that either I have a compression problem or a clutch problem it is just to easy to pull. I...
Hi there. Firstly remove the end with the starter cord and make sure the fly wheel is opening when you pull the cord. If not lubricate it until it frees.If it is working then it could be just the carb gaskets need replacing or the worst case is that the piston is broke and may need sorting.
Oct 05, 2013 | Husqvarna Forest & Garden 125l 18" Gas...
My Husqvarna 125L trimmer makes a terrible grinding sound and vibration along the shaft. What is this?
Could be a damaged bearing in the gear head, could be a bent drive shaft or outer drive tube, clutch drum may have worn the
engine housing and spinning off centre.
Nov 20, 2011 | Husqvarna Forest & Garden 125l 18" Gas...
Cant get the line spool out of the housing and no feed coming through
Is it the 'bump feed' type.? just knock the head on the flood while strimming
Jun 22, 2011 | Husqvarna Forest & Garden 125l 18" Gas...
Husqvarna makes a trimmer that you don;t bump the head to feed the line, right?
What make you ask this question?
just check this out, it replaces the orig. head and all of Husq. have bumps unless you change it..
Tanaka head semi auto.
Nov 05, 2010 | Husqvarna 28cc Gas Line Trimmer
Hello I have a Husquvarna 125L trimmer manufactured in 2007. A part has failed in the starter cup assembly because when I try to crank the trimmer it does not engage and simply turns free. I have the...
Have had same problem. This is a very old post so this is for those who have this problem. It is part 15 from the link given up there. WARNING I AM NOT A MECHANIC OR WELL VERSED!!What happens when you pull the handle is two starter couplings(plastic) engage the shaft that engages the engine. When it starts these fall free and allow the engine to spin freely. When they break the engine isn't harmed. You need a star head screw driver and NOT a phillips. Just he two on either side of the starter cup. Don't think you need to take off all 8 or more screws. Just the two. Pull out the other coupling. They just pop in. Buy 2 new ones. The other one is probably compromised anyways. Husqvarna 530059800
Coupling-Starter. Not a very involved process at all. Two screws. Pull off cup. pull out white plastic couplings. Put in new ones. Put the cup and screws back on.
Jul 20, 2010 | Husqvarna Forest & Garden 125l 18" Gas...
My husqvarna 125L weed eater will only run with the choke on why ?
sometimes it's caused by too much air in the mixture---check for leaks around gasket where carb meets head--also, check the jets--make sure they are not clogged
May 08, 2010 | Husqvarna Forest & Garden 125l 18" Gas...
How to replace accessories from a husqvarna power motor
Straight from Husky, the pole saw runs about $200...or if you have the straight shaft, you can get just the head for $185:
http://www.husqvarna.com/us/homeowner/products/trimmers/popular-accessories/
May 05, 2010 | Husqvarna 28cc Gas Line Trimmer
Want to remove huscavana weed eater head
You should find a hole in the piece just above the trimmer head, this should line up with another hole deeper in the area. You stick a piece of rod in there to keep the head from turning. Use some pb blaster penetrating oil to help loosen up the head.
Feb 25, 2010 | Husqvarna Forest & Garden 125l 18" Gas...
Husqvarna Forest & Garden 125l 18" Gas Trimmer Logo
543 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
