Question about Pool & Spa
The water pressure on my Hayward pump on the return is too powerful?
  • 1,383 Answers
CHANGE OUT THE IMPELLER . HAVE THE HP AND TYPE OF PUMP YOU HAVE ,SAY A SUPER 2 OR A SUPER OR NORTHSTAR. OR BRING YOUR IMPELLER )SCREWS OFF( TO YOUR LOCAL POOL PUMP REPAIR GUY..SAY..The water pressure on my Hayward pump on the return is too powerful? I NEED A SMALLER IMPELLER THEN THIS ONE
Posted on Aug 23, 2010
Reduce the suction side pressure with a "valve". I beleive the Hayward unit provides one with the unit.
Posted on Oct 08, 2011
  • Michael Quinn Oct 08, 2011
4 Suggested Answers
  • 61 Answers
SOURCE: my pool pump pumps water, return is low pressure
fix any air leaks on suction side of pump. Check valve positions.
Clean filters...may need to replace cartridges in cartridge filter, or take out D.E. grid assembly and clean it on a D.E. filter, or change sand in a sand filter...
Posted on Apr 04, 2009
  • 11 Answers
SOURCE: I lost water pressure in my swimming pool line and
If your pump is blocked in any way (usually a closed valve), then the pump cannot keep water flowing. It could be starved of water if blocked on the suction side, or an air leak. On the return side, it's usually a ``dead head`` pipe, or a closed outlet valve. In either case, the pump can overheat and actually boil the water within it. In that case, the fittings attached to it can deform and cause bigger air leaks, which compounds the problem. If you replace the fittings, reconnect the pipe and remove any blockages, you should be fine.
Posted on Aug 03, 2009
MOTORWIZJ
  • 1383 Answers
SOURCE: Clicking noise in new Hayward Super Pump
make sure the pump motor is set for 115 volts, it soumds like you have the motor set at the factory 230 v setting and are trying to run it on 115 v look on the motor label it will show you how to set the motor up for 115 v (if the breaker is wide 230 if its skinny like the ones that control your lights its 115v ..if you have ran it for awhile like this you may want to search your area for your local pool pump motor repair guy w/ free testing, because you may have damaged the start capacitor about 20.00 or less fix.if not this can come back to haunt you later,,jay
Posted on Dec 14, 2011
Low water return flow
sounds like DE remove grids clean then recharge with DE
Jun 14, 2012 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
My pressures low
Low water volume will cause low pressure. Check for any obstructions in the suction libe and/or minor leaks that will cause the pump to **** air. If everything checks out, make sure the water is actually flowing thru the sand. If you suspect the water is bypassing thru the multi-port valve or a tunnel in the sand: pour a cup of flour in the skimmer, if you see it return thru the returns, you have your verification.
Jun 17, 2011 | Hayward SAND FILTER, PRO SERIES
I loose discharge water flow after about 5 minutes of running perfectly. The pump has no air bubble and is trying to push water thru filtration system ( if I open the backwash valve I have very good flow...
If you have a pressure gage it would help .. if the pressure is high then there is probably an obstruction in the return pipe to the pool .. if the pressure is low then there is most likely a restriction in the supply or suction side of the pump .. this would seem more likely to me from your description, there may be something obstructing the flow into the pump, a clog, a collapse hose from the suction, some flap of pool liner .. something like that ..
Please Vote !
Jun 01, 2010 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
No water in pump after running for short time
suction side leak... your grabbing air somewhere in the suction line.... take a hose at low pressure and with the pump running put it over various parts of the suction line... including your pump lid... if the problem goes away and you have no more air in the pump then you know what your problem is
May 22, 2010 | Hayward 1hp Power Flo Matrix Above Ground...
My cousin has the hayward sp714 filter. she lost the manuel for it. i need to bakwash and clean the filter. where can i find a owners guide for this product? the pool is to green and the pressure on the...
Instructions are on side of filter tank.Looks like a pro series top mount. Turn pump off.Press down valve handle and turn to backwash. Start pump. When water runs clear , rinse and return to filter. The pressure gauge is defective! Replace. Superchlorinate pool.
Aug 16, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward sand filter pressure builds up and return hose pops , the flow is good.
pressure should be at around 10 if its higher backwash to bring pressure down make sure you are seating hos clamp screw type over ring on return pipe
Jun 22, 2009 | Hayward SAND FILTER, PRO SERIES
The water seems to be jumping out of the return jet?
Below is a copy of the users manual for these pool filters. It has a troubleshooting guide and several diagrams that should help you get the pressure problems solved. Hope this helps.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
May 26, 2009 | Hayward SAND FILTER, PRO SERIES
In-g pool loss of pressure and bubbles from return line any ideas
If you notice bubbles in the water returning into the pool from the eyeball/discharge, or water in the strainer basket is visibly swirling (bubbles visible) odds are you need you replace the o-ring on the lid of the strainer basket in the front of the pump. This basket may also be clogged with debris, which also effect pressure. Could also be a cracked or warped strainer lid. Should be easy to see when you remove to check o-ring. Once you remove the strainer o-ring make sure you lube it with a good silcone based lube.
May 18, 2009 | Hayward Sand Filter System & Tank 21" 1...
Low return pressure
if you are referring to the the guage on the filter, this is really too high. You should backwash and would like to see it down to 8-12. if not, have you changed your sand?. I like to change it every other year.
David
May 14, 2009 | Hayward 1.5 Hp Northstar High Performance...
Pool & Spa Logo
155 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
