Question about Remington Sport & Outdoor - Others
MY REMINGTON 770 300 MAG HAS A STICKY BOLT...I CAN LIVE WITH THAT BUT OCCASIONALLY IT GOT actually STUCK AFTER FIRING A ROUND SO SOLID I HAD TO BEAT ON BOLT to get the round out.i have heard rumors that certain types of ammo mite cause this but after searching the web about the 770,there are a lot of complaints about the bolt being sticky buy not actually stuck.like i said i can deal with a rough bolt but not a stuck one.has anyone heard of this problem ,and if so a remedy(got my moose tag this year for first time in 13years so dont need a problem like this happening)(gun sure is accurate though)
  • 39 Answers
SOURCE: what year 350 motors will bolt up in a 1999 4x4 tahoe
I believe in 97 they started the vortec 350 and they ran until 2001 not real sure but any salvage yard will know what years will fit. there are also different engine codes I think they are W and Z that will make alot of difference in the computer.
Posted on Mar 24, 2009
  • 117 Answers
SOURCE: The Bolt will not stay back after last shell is fired from mag.
Try putting the original magazine back in.The tapco mag probably does not have the vertical extension that holds the bolt open.Compare the two mags side by side.Good Luck
Posted on Apr 08, 2009
  • 23 Answers
SOURCE: i need to know how to assemble a remington 870 shotgun
The bolt has to go into the reciever form the front. It is inserted with the dog. This is a pain, but the bolt, dog, and action arms(from the pump) have to come together and be held just right to slide into place.
Posted on Aug 25, 2009
dontbother10
  • 2220 Answers
SOURCE: I have a Remington Pole Saw Model # 10689002.
Your manual can be found at the bottom of the page, it includes an IPL: http://lawnandgarden.manualsonline.com/ex/thread/view/idThread/2168817
The fan should be mostly stable, if the melted part isn't listed it most likely cannot be replaced.
Is the unit still under warranty? You might try contacting the manufacturer here:
Remington.com
http://www.remingtonpowertools.com/
Lou
Posted on Sep 05, 2009
gtmerkley
  • 190 Answers
SOURCE: SKS bolt jams with gun empty
If you have Cosmo any where it wont work . Clean it from inside the firing pin channel and trigger group , mine would also slam fire and bump fire till I got it all cleaned out
Posted on Nov 01, 2009
Mod 110 270 when i pull bolt back and load round push bolt forward round fires ?
Gunsmith call, Firing pin is sticking in the bolt or sear is worn.
Jan 19, 2017 | Cars & Trucks
44 magnum bullets for deer hunting rifle
Actually called 'ammunition'. On the barrel, near the muzzle, it will tell you the exact round as there are a number of 44 Mag rounds. Here are some of them for sale. There are images in the main link and one is called Buffalo Bore, Deer Grenade which is a hollow point round at 240 grains.
https://www.google.ca/search?q=44+magnum+ammunition&rls=com.microsoft:en-CA:IE-ContextMenu&biw=1366&bih=622&source=lnms&tbm=isch&sa=X&sqi=2&ved=0ahUKEwj-yOu-8sTPAhUHyj4KHYUQCP4Q_AUIBigB
44 Magnum Ammo ' Bulk .44 Mag Ammunition For Sale Cheap
www.luckygunner.com/handgun/44-magnum-ammo
  1. Cached
  2. Similar
44 Mag - 180 Grain JSP - Remington UMC - 500 Rounds. ... 44 Mag - 240 gr JHP - Blazer - 1000 Rounds. ... 44 Mag - 180 Grain JSP - Remington UMC - 50 Rounds.
44 Remington Magnum Ammo - Sportsman's Guide
www.sportsmansguide.com > Ammo & Shooting > Handgun Ammo
  1. Cached
  2. Similar
The Guide is your source for all things ammo. We have a great supply of .44 Remington Magnum Ammo at the best prices around! Check out our .44 Soft Point ...
Bulk .44 Mag Ammo Online at BulkAmmo.com - Ready to Ship!
www.bulkammo.com/handgun/bulk-.44-mag-ammo
  1. Cached
  2. Similar
Items 1 - 16 of 42 - 500 Rounds of .44 Mag Ammo by Remington - 180gr JSP. ... 1000 Rounds of .44 Mag Ammo by Blazer - 240gr JHP. ... 50 Rounds of .44 Mag Ammo by Remington UMC - 180gr JSP.
44 Remington Magnum- MidwayUSA
https://www.midwayusa.com/44-remington-magnum/br?cid=22546
  1. Cached
  2. Similar
Hornady LEVERevolution Ammunition 44 Remington Magnum 225 Grain Flex Tip ... Buffalo Bore Ammunition 44 Remington Magnum +P+ 340 Grain Lead Flat ...
https://www.midwayusa.com/44-remington-magnum/br?cid=21830
  1. Cached
  2. Similar
Magtech Sport Ammunition 44 Remington Magnum 240 Grain ... Buffalo Bore Ammunition 44 Remington Magnum +P+ 340 Grain Lead Flat Nose Gas Check ...
.44 Remington Magnum Ammo - .44 Rem Mag Bullets
https://www.cheaperthandirt.com/category/ammunition/.../44-remington-magnum.do
  1. Cached
  2. Similar
Look no further for your .44 Remington Magnum ammo! We have all the best brands for your firearm at the best prices, ready to ship right to your door!
44 Magnum & 44 Special : SFRC, your online ammo source!
www.theammosource.com/index.php?main_page=index&cPath=1_108_150
  1. Cached
  2. Similar
Products 1 - 10 of 19 - SFRC : 44 Magnum & 44 Special - Ammunition Firearms Firearms Accessories Reloading Supplies Scopes, Optics, Binos and Sights ...
.44 Magnum - Wikipedia, the free encyclopedia
https://en.wikipedia.org/wiki/.44_Magnum
  1. Cached
  2. Similar
The .44 Remington Magnum, or simply .44 Magnum (10.9×33mmR), and frequently .44 Mag, ... When loaded to its maximum and with heavy, deeply penetrating bullets, the .44 Magnum cartridge is suitable for short-range hunting of all North ... Bullet diameter‎: ‎429 in (10.9 mm) Rim diameter‎: ‎514 in (13.1 mm) Case length‎: ‎1.285 in (32.6 mm) Base diameter‎: ‎457 in (11.6 mm)
44 Mag - Hornady
www.hornady.com/store/44-Mag-c-354
  1. Cached
  2. Similar
... web browser. Home » Ammunition » Handgun » Choose by Caliber » 44 Mag ... 44 Mag 200 gr XTP® See details ... 44 Mag 225 gr FTX® LEVERevolution® ...
44 magnum ammunition Google Search
Oct 06, 2016 | Optics
I can not open barrel to load
sounds like the bolt got moisture in it and rusted, try putting wd 40 in the bolt area and letting it set over night
Dec 09, 2015 | Savage Arms Savage Model 111FXP3 Rifle...
I shoot my 30-06 Remington an now the trigger an the bolt is stuck
1) If the round did not discharge, you must take this to a qualified gunsmith as the riffle could discharge when manipulating the bolt, safety, trigger, or due to mechanical shock. Make sure you transport the rifle with the muzzle pointed at something that can stop the bullet - consider a sandbag, phone books or several pieces of wood. Do not carry it in to the shop, ask them to come out and assess the gun
2) If the round discharged, do the following:
Empty the clip
Point the gun towards a safe location
try pushing the bolt forward and then rotating the bolt, once it moves do not put any forward or back pressure on the bolt
Failing that, repeat the process with the trigger pulled
IF THERE IS A LIVE ROUND IN THE CHAMBER YOU COULD GET A BLOWBACK SO DO NOT DO THIS IF THE ROUND IN THE CHAMGER DID NOT DISCHARGE
Failing that, remove the trigger assembly if you know how
I highly recommend going to a gunsmith as the gun is not longer trustworthy once the bolt tangs are in question
If you want to see the results - look up blowback - think the entire bolt going through your eye and out the side of your head - seriously - bolt failures are extremely dangerous.
Nov 16, 2014 | Garden
Serial numbers winchester: bolt action #39163A, barreled by Griffith & Howe.
Griffin and Howe were out of business before the 300 win mag was introduced.
Sep 24, 2013 | Remington Model 700 BDL LSS Bolt Action...
The bolt release is not functioning on remmington 887
Make sure that you gun is well lubed. Some times after cleaning we can forget to properly lubricate the bolt and associated parts. Also a light lube might tend to freeze in cold weather making it harder to operate correctly. Use a heavier lube in cold weather as lighter lubes will freeze and make firing the rifle impossible.
Sep 22, 2013 | Remington Model 887 Nitro Mag Deer Barrel
On my sks rifle when stalling clip have to hold bolt back to install clip
Are you talking about a full magazine? You have to get the bolt out of the way because it is too tight? Take out 1 round and see what happens. Does it do it to an empty mag? You are not talking about a stripper clip are you? You know they don't come with magazines, the 30 rnd mags you get that are detachable have been modified some how. And they don't go in easy. Not like an AK, Let me know.
Apr 20, 2010 | SKS Rifle High-profile See-thru Scope...
I took apart a remington model 550-1 auto 22 and a small pin fell out and I have no idea where it goes. It is about 3/4'' long,round and it has 1 end the same size as the firing pin and larger on the other...
Without seeing it, It's hard to tell, the closest I can come is the extractor plunger, or a part of the lifter.3 pins in there, your trigger plunger, and 2 pins on the safety.None are the shape you noted. Going by this drawing anyway. I didn't want to take my 550 apart to look for it, But I will if I have to. There is one more pin in the end of the tube magazine.
Jan 17, 2010 | Optics
Sport & Outdoor - Others Logo
284 people viewed this question
Top Remington Sport & Outdoor - Others Experts
Tom Chichester
 steve
steve
Are you a Remington Sport and Outdoor - Other Expert? Answer questions, earn points and help others
