Question about McCulloch Garden
I have a McCULLOCH 1500 psi pressure washer and it seems like I need the top part of therod where the waer comes out it no longer adjusts the water stream seems like a little plastic defkector that you adjust your stream with, snapped and broke looks like I HAVE TO REPLACE THE ENTIRE TOP PART OF THE 2 PIECE ROD on the bar it says the following max130barmax60C PA66-GF30 Where could I purchase this piece Andy Nowostawsky my adress is 15447-rue d'esterel Pierrefonds,Quebec H9H 1Y9 Canada
jsrock516
  • 5911 Answers
SOURCE: Front vent fell off
This should be a very easy fix. I assume you are talking about the plastic vent grill on the top of the oven above the door. There should only be a couple of screws holding it in from the top. The grill then should tilt out from the top first then from the bottom to remove. Since you said that it had fallen off, it sounds like the tabs where the screw holes are have broken off. This is a common problem. You can buy the part by ordering from the manufacturer, or from most repair websites. All you need is the model number from the microwave. Good luck.
Posted on Jun 19, 2007
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite Oasis, fabric softer thing exploded...
Okay...the cone actually goes inside the the two other pieces you mention. The cone is to be inserted upside-down. That is, the opening of the cone should be facing UP. The way this fabric softener dispenser is supposed to work is, you place fabric softener thorugh the opening of the dispenser. The cone actually holds it like a cup. When the washer goes through the initial spin cycle before the rinse cycle begins, the centrifugal force of the washer spinning forces the fabric softener out of the cone and into the wash tub.
The dispenser assembly should just snap right on top of the agitator. If the dispenser does not stay on securely any longer, you may have to replace it with a new one. You can find replacements at searspartsdirect.com. Just type in the same model number you provided and look for item number 1 under the "Motor, Basket and Tub Parts" heading.
I hope you find this information helpful. If you still have questions, please let me know.
PS It is also a good idea to periodically remove the dispenser and soak it in some hot water to get rid of accumulations of hardened softner. They will clog from time to time.
Posted on Sep 04, 2008
  • 171 Answers
SOURCE: kohler one piece part number 1013282
Hi kayela,
I'm Harvey the Master Plumber.
Your question is: Just replace the fill valve for kohler one piece andthe fill valve sprays a stream of water out of the top and onto the undersideof the lid is that supposed to happen?
For some reason I can't seem to get the picture up. Nevertheless, the answer is no, it should not be leaking. Did you take a picture of the original before removal? Do you still have the original? Look carefully at the diference between the two. Make sure it's an exact duplicate and isn't missing parts. These one piece toilet parts are expensive but the suplier sometimes makes mistakes. You can only solve this problem if they match.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 28, 2008
jsrock516
  • 5911 Answers
SOURCE: Getting a small plastic piece out of a door
If the piece is jammed (locked) in the door latch assembly, there is a manual release that you can use to open the door latch to see if the piece will come from free. The following link advises:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
This may require two people. One to pull on the manual release, while the other works on retrieving the broken piece from the door latch.
Another method may be to remove the door latch assembly so you can easily manipulate it outside the machine. This link explains how to remove the door latch assembly:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
Now...if the piece is jammed too far inside the door latch assembly, a last resort would be to replace the latch. I hope it does not come to that, but it may be a last resort. The link provided will give you all the necessary steps to complete this repair, if required.
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Nov 08, 2008
SOURCE: Nikon D200 battery door - is it broken?
The battery door is meant to come off so the MB-D200 battery pack can be inserted, but it sounds as if yours has broken. There should be equally-sized rods that form the pivoting hinge, on on top and one on the bottom. Yes, you can buy a replacement part, probably through a local dealer or online. I believe online they cost around $20-$25. To remove the door, you are supposed to open the door to a 60-degree angle to the camera body and gently pull the door off. To replace the door, again, hold the door at a 60-degree angle to the body and gently press it into place. Or you could pay a repair shop an arm and leg to do this for you ($50 or more + shipping if you use a mail order repair shop).
I remember the 'good old days' when film SLR's were made to take a beating. Sadlly, we're in the era of plastic and I always have to remember to treat every piece of equipment as if it were made of glass!
Hope this helps?
Posted on Jan 12, 2009
Since I have heard that Stucco should not be pressure washed at greater than 800 psi, how should I use my non-adjustable 1500 psi Karcher Washer for this job?
You can keep a greater distance from the stucco in order to not have the full contact pressure on the surface. Then if it is not doing a good job move closer to the surface. Another option is to buy a vario lance for your model.
Feb 25, 2011 | Karcher K2.26 Electric Power Washer
Mcculloch power washer fh140A 1400 PSI help
the unit will only **** up solution when the pressure is low, thats how they all work so you cant use pressure at the same time. You will notice that the pressure drops when using the solution ****..
soap 1st the pressure wash.
Jul 02, 2010 | McCulloch FH140A Electric Pressure Washer
Removing lance from gun on McCulloch FH140A pressure washer
The Karcher is the same, and possible made the Mac. It's likely the sealing 'O' ring has deteriorated and stuck the two parts together. Try a little petrol around the joint to soften the 'O' ring. Perhaps it will come apart then. You will need a new o-ring however.
Apr 20, 2010 | McCulloch 1400 Psi Electric Pressure...
I need a manual for a McCulloch pressure washer FHH18A. Download did not work.
I need a manual for McCulloh 1600 PSI pressure washer > Its motor is working but there is no pressure
Aug 23, 2009 | McCulloch Garden
Parts
Go to McCullochpower.com and under power equipt click on pressure washer follow the links till you get to page about ordering parts and you will need your exact model number but the parts can be ordered online or there is a link to find a dealer near you. Let me know if you still need more help
Jul 26, 2009 | McCulloch FH160G Pressure Washer
I need a McCulloch FH140A pressure washer spray nozzle
you will have to replace the wand which you can purchase from a reputable hardware store
Apr 08, 2009 | McCulloch 1400 Psi Electric Pressure...
Gas driven portable pressure washer no longer draws chemicals up
Picks up under low pressure conditions by adjusting wand or changing tip.
Mar 18, 2009 | Honda Garden
Garden Logo
169 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
