Question about Teac Audio Players & Recorders
HI 1030 REEL TO REEL POWERS UP BUT MOTOR DOES NOT RUN.CHECKED POWER TO BOARD THAT SUPPLYS MOTOR GETTING 106 VOLTS.100VOLTS STAMPED ON MOTOR.DO YOU THINK THE MOTOR HAS GIVEN UP.MANY THANKS DAVE
  • Teac Master
  • 5,190 Answers
Sounds like it has yes! See if you can turn the spindle by hand. If you can't then it will have gone. It could be stuck! or something has got inside the motor.
Posted on Sep 02, 2010
How do I remedy error SC 552?
change the main motor or clear the eroor
Sep 10, 2015 | Ricoh Aficio SP C811DN Laser Printer
Electrograph 47-in monitor. Why does it have a multicolored vertical line running down it?
The cooling fans not running would definitely cause a problem with overheating. But the question is, did the fans fail or is there a problem with the power supply that is causing the fans not to work and also interrupting proper operation of the video boards. It is more likely a power issue than 2 failed fans. If you have a multimeter you can check the power coming into the fans. Most will be 12 volts, some might be 5 volts, usually stamped right on the fan.
May 24, 2015 | Computers & Internet
My boiler stopped working two days ago the f-l code came up so I have checked the ignition that seems fine then I checked the voltage for the gas valve which was 106 volts dc checked with idea and they...
Is the 106 volts measured when connected to the gas valve.....or is the 106 volts coming out of the pc board unconnected? If you are measuring the 106 volts on the gas valve the problem could be with the valve. The next logical problem would be with the valve with sufficient voltage coming out of the pc board.
Nov 28, 2014 | Heating & Cooling
Printer is not turning on
Hi dear friend , seems your problem is depend to dc controler board which makes hi and low voltages and sends them to other sections like drive motor-display - laser unit - fusing section and other parts in the mashine . If you are a technision so you know well what can you do , if not , just follow power cord and check if there is in put AC voltage ( 220 or 110 volts)on the power supply board ? If you saw the voltage on the diode bridge go a little further on the maun capacitor and check about 300 dc volts on it . If there is not ac and dc volts , you should remove main connection from power supply to dc board then check the voltages that mentioned . Remember that , this is step by step diagnostic finding issue and all of my prefers to you was depend to this point that be careful and if there is nothing voltage even on the panel lights . Good luck
Nov 24, 2014 | Canon I-Sensys Lbp5050 Laser Printer
Power 48v check
Hi
Either the power supply is
not generating a proper 48
Volts or the controller board
is not detecting a 48 Volt
output from the power
supply board.
1. Make sure the power supply
board is correctly connected to
the controller board.
2. Power on the printer. If the
message appears, do the power
supply operational check (page
195). If the power supply fails the
check, replace it. If it passes the
check, go to the next step.
3. Power on the printer. If the
message appears, replace the
controller board. Record the
message and return it with the
defective board.
Aug 11, 2014 | Printronix Matrix Office Equipment &...
Pressed express incline then machine went to top incline and received error 306. What is the problem?
Err 306 - Indicates power supply problem at start up.
1. Check all wiring for proper connections and damage
2. Replace the lower power supply board.
3. Replace the drive motor.
Recommended Parts: lower power supply board, wire harness.
I would suggest you get a tech out first. 877-805-1030
Dec 24, 2013 | PaceMaster Silver Select XP Treadmill
I have no power supply cord for my labtec lcs-1030 speakers- what do i replace it with? i cannot find specs for it anywhere online
On the back of one of the speakers, there will be 3 plugs; a green one, a grey one, and a black one. The black one is the power plug. Right below the power plug it says the voltage needed (I could only find one picture online, and it looks like it says 15v, which would be 15 volts). That number is the needed supply voltage, so search google for (number under plug) volt power adapter.
Mar 24, 2011 | Labtec LCS 1030 Computer Speakers
Ricoh FT 3013 error code E 21? how can it be fix
· Scanner home position sensor failure
· Defective scanner motor
· Defective main board
· Defective dc power supply board
· Incorrect scanner drive wire position
· FU202 on the dc power supply board open (blown fuse).
- Action -
Turn the main switch off and on.
Check the position of the 1st scanner sensor actuator.
Actuated De-actuated
Does the scanner motor rotate when the main switch is turned on?
No Yes
Correct the scanner drive wire position.
Check the voltage at CN106-2 on the main board.
24 volts 0 volts
Check FU202 on the dc power supply board.
Good No Good
Replace FU202
Replace the dc power supply board.
Check the voltage at CN105-1 and 6 on the main board.
24 volts 0 volts
Replace the main board.
Jun 26, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
I have a sharper image power tower that holds 200 CD's. Today it simply stopped reeling the CD's. I can hear the mechanism working. I have an 110 volt step down transformer as a source of power. There are...
there are two gears that run the changer one on the motor and one on the cartridge. Either one of the gears stripped out, or they got separated. You can do one of two things, if your mechanically inclined you can take it apart and check the gears, or you can take it in and have it fixed.
May 17, 2009 | Sharper Image Power Tower Motorized DVD...
TASCAM 80-8 DECK NO VU LIGHTS NO REEL MOTORS CAPSTAIN MOTOR RUNS VU METERS THUMP WHEN SWITCH /MAIN POWER IS DEPRESSED
the machine vu lights were dim the reel motors ran then the lights got dimmer and the reel motors stopped its quite old now but never let me down . best regards kirk
Dec 07, 2008 | Tascam Audio Players & Recorders
51 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
