Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman Model 917251481 Kohler 18.5hp. Starts and runs fine for 30 to 45 min. stops and will not restart till it cools. Then it starts fine. and the same problen occurs. thanks, Larry
  • 153 Answers
SOURCE: Runs Great until the blad is engaged
Frozen idler pulley under the tractor frame or frozen or damaged bearings on the deck spindles. With no belt tension on these items they should spin freely. If you have the know-how you can fix the problem yourself (parts are available at sears.com or elsewhere), otherwise you will have to bring it in for repair.
Posted on May 18, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Craftsman 19.5 riding mower starts runs quits no power
When you let it sit did you remove all the fuel or add a additive? If you did not then I would recommend that you remove all the fuel and add brand new fuel to your system. Gasoline only last for about 3 to 4 months before it will start to go bad and this sounds like your problem
Posted on May 22, 2009
wadembly
  • 489 Answers
SOURCE: Craftsman LT1000 tractor not moving
hello otto i would check the belt that runs to the rearend but the brakes could be also froze up i would try to jack it up & see if it will move then go from there
Posted on Jun 08, 2009
  • 40 Answers
SOURCE: My craftsman 15.5HP kohler riding mower turns over
Try cleaning or better yet, replacing the spark plug. Depending on age and how your tractor was maintained, there are other possible causes.
  • Gummed up fuel system
  • dirty fuel filter
  • defective or misaligned armature/magneto (part that causes your plug to spark, igniting the air/fuel mixture, thus starting the engine)
  • throttle linkage/cable problems
  • low oil level. Some Kohler engines use a low oil shut down sensor which won't allow the engine to run or start to avoid internal damage.
  • Mechanical engine problems
I hope you find this solution helpful. Please rate it thanks for using Fixya!
Posted on Nov 05, 2009
  • 33 Answers
SOURCE: My craftsman mower with a 26 hp kohler dies when choke is in
carb dirty, jets partially plugged, float sticking. Not so uncommon problem and is caused by the fuel left in the carb over the winter gumming up (going bad). You can attempt to clean this on your own if you are somewhat mechanically inclined. Search small engine repair and it will give you a generic breakdown of the parts in a small engine carb. If not the, to have someone overhaul a small engine carb will run you about $120 including parts (at least around VA).
Posted on Apr 05, 2010
JD JS45 walk behind mover. Starts, runs fine for 5 minutes, then stalls, won't restart till i pull the spark plug and cool the motor, plug down. then same thing starts, runs for 5, stalls.
Probably either a fuel or a spark problem. You need to check for the presence of a good spark immediately the engine stops - by using a spark gap, a spare spark plug or a propriety spark indicator.
If the spark is found to be absent the fault is likely the ignition module but check all connections and the stop switch operation before replacing.
If the spark is present then the fault is probably fuel-related and is the sort of thing a tiny droplet of water in the carb could cause...
Jul 23, 2016 | Cars & Trucks
I have a kohler 23 hp command vertical brother hit something stopped deck and engine but started back up and ran good next day motor started fine half way through lawn lost power and will start but no
valve seats have come out do to hitting something motor starts and runs fine the slowly loses power from super heating and finally stops wont restart until cools down right valve jobs per cylinder 150.00 each
Sep 15, 2014 | Garden
Craftsman riding mower runs mows fine for about 10-15 mins then sputters out and wont restart tuill bout half hour later
two things can be doing this ,
(1) fuel tank pick up is broken in half and works till gas works it way down to break , proof of this is when u add more gas and it starts right back up
(2) breakdown in ignition system , this can happen in a few places (if I knew your model number I can tell u more) eventually It will fail and never restart
Jun 07, 2014 | Craftsman Garden
My gen starts and runs for 1 min or so then dies restarts then dies again and again. if i start it under load ( turn on air con) it will run for 10 min then die allen
Is there a fault?? All UL listed generators including Kohler are required to lockout on a fault on shut down. This really sounds like a problem with your 2-wire auto start connection between your automatic transfer switch and genset. RDT model automatic transfer switch it is the 2 middle wires on the green connector and terminals 3&4 in the generator. close to run and open to shut down. Any open at any time will cause the unit to shut down. The 12 will shut down instantly upon an open because your 5 minute cool down is built into the transfer switch.
Jun 27, 2011 | Kohler 12 kW Emergency Power System -...
My 17 kw gen start up easy runs about 5 min and then start to miss,let it cool down and then restart and does the same thing.
hi it sounds like to me that you need to check your valve clearances. It sounds like as the engine warms up, the metal expands and the valves then do not close fully, hence the miss. The engine cools and the metal contracts, valve clearance is good, engine runs fine. Check the tolerances right before you start the engine, then after it starts to miss.
JOe
Feb 05, 2011 | Kohler Electrical Supplies
Brother's Craftsman 22.5hp Kohler engine starts and runs for 10 mins. Ans shuts off. Will not restart.
Kohkler engine 22.5 hp will not restart in the morning,unless you shot some start fuild in the air cleaner
May 20, 2010 | Garden
I have a craftman lawn tractor with a 15hp kohler engine. Engines starts and runs fine After mowing for a while and then shutting it off the engine will not restart until it cool off completly. Any...
See if there as any difference in compression when the engine is cold verses hot. Also check ignition spark when it is hot. Unit could be vapor locking because of heat. Carb float could be suspect.
Sep 14, 2009 | Craftsman Garden
Motor runs for 5-10 min. then starts missing and quits.
Check your spark first,if you do not have spark your problem is the coils-if you do have spark the problem probaly lies withone of your valves getting stuck after getting hot and soonas it cools down a little it closes and then you can restart it till it gets hot again.Hope this helps
Jul 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
126 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
