Question about Dryers
Manual for free kenmore elite smart heat quiet pak dryer
  • 1028 Answers
SOURCE: Kenmore elite gas dryer smart heat quiet pak 9 HE4
possible front control bd ..be sure there is 220 volts to rear connection first
Posted on Aug 04, 2008
blueextc3221
  • 15935 Answers
SOURCE: Clothes not dry and get F70 code
The F70 and F71 error codes on this model of washer indicates a communication problem between the user interface control board and the central control unit (main control board). These error codes can sometimes be caused by a power surge or glitch through the electrical lines. Try unplugging the washer to completely disconnect electrical power. Wait 1 minute and then plug the washer back in to the see if the fault code clears. If it does, then the washer may work normally.
If the code reappears, then you could have a wire harness connection problem, a failed user interface control board or a failed central control unit. I recommend calling a service technician to properly diagnose and repair this type of problem so that the correct component can be replaced.
Be sure your unit is plugged into a 3 prong grounded outlet as well.
F71 is a "heatbeat failure" which means that your front interface control board is shorted and will need to be replaced. it's actually fairly easy to replace and can definitely be done by yourself. To access the part, just pull the unit forward and remove the 3 screws coming in from the back of the top panel. Remove the top panel by pulling it back, up, and off. Then remove all the screws going into the top of the control panel. Remove the dispenser drawer and remove the screws coming in through the dispenser. Remove the screws coming from the inside of the dryer going forward into the control panel, then remove the control panel (it's just clipped in on the bottom. After that you can disconnect the wire harnesses to the front interface control board and replace that part.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 28, 2010
blueextc3221
  • 15935 Answers
SOURCE: kenmore elite he4 quiet pak 9 dryer display code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Posted on Sep 30, 2010
muffteck
  • 202 Answers
SOURCE: I have a Kenmore elite
ck breaker box ck to see if pluged in...heat element burnt out or a number of things
Posted on Mar 16, 2011
  • 160 Answers
SOURCE: Need replacement filter for my
You can order parts through this site. Make sure you have the complete model number.
http://www.searspartsdirect.com/partsdirect/index.action
If you need further assistance please comment.
Posted on Jul 28, 2011
My Kenmore elite smart heat quiet pak 4 automatic dryer model 110. 87872603 shut off during drying cycle and showed service code f23. The dryer was extremely hot.
call sears service . sounds like the exhaust blower has failed you or perhaps the filter us plugged and needs cleaned out which should be done before or after each use
Jun 16, 2015 | Kenmore Dryers
I have a Kenmore Elite HE4 smartheat quiet pak 9 that has power but will not start.
Sounds like the belt that turns the drum could be broken. I'd check that first.
Oct 12, 2017 | Kenmore Elite HE4 Electric Dryer
Need replacement filter for my Kenmore Elite smart heat quiet pak dryer. Dryer is approximately 7 years old.
Jul 28, 2011 | Dryers
I have a Kenmore Elite Heavy Duty King Size Capacity quiet pak 1 that is not heating up what could the problem be?
Jan 13, 2011 | Kenmore Dryers
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore elite he4 quiet pak 9 dryer display code
May 15, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore smart heat quiet pak 9, just beeps won't start
m dryer did the same thing tonight and it was the door switch luckly i wiggled it and it came back on
Feb 22, 2009 | Kenmore Elite HE4 Electric Dryer
Aug 03, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
259 people viewed this question
Top Dryers Experts
