Question about Dryers
The start push button doesn't work kenmore 80series
  • Dryers Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
Will the power cord on my Kenmore Washer 80series work on a Frigidaire front loader
If you are referring to the 3 pronged 110volt black electric cord, the answer is yes. If you mean an extension cord, the answer is yes if it is heavy duty. ( 15 Amp.)
Be sure to hook it up correctly, with the hot wire going to the correct connection inside the machine.
God bless your efforts.
Apr 15, 2016 | Kenmore Washing Machines
Is there a how to fix and take apart 80series dryer?
Hello;
My name is Peter. I am a retired field service appliance technician.
Be careful. Do not start spending money replacing components when you are not sure of what the problem is.
Post your problem and I will walk you through the fix.
You can go into the following website and search your problem.
kenmore dryer 80 series diagram Google Search
Feb 19, 2015 | Kenmore Dryers
Control panel buttons no longer work.
Hello ...
I tried to look up your model numbers here (usa)...
with no success... (Kenmore 13742 / 13744 / 13749)
I rarely (ever) suggest owners go direct to Sears...
but this would seem to be.. appropriate...
(I my opinion they are rude & pushy to sell parts
(good news ... here... their guaranteed fit/fix)).
Before doing so...
Check your water, drain & power at the appliance.
With the breaker turned of...
open the appliance cord JUNCTION BOX and assure the
wiring devices (usually "wire nuts") are still tight and secure.
Finding nothing... you are at the UNHAPPY JUNCTURE
where you need to use SEARS PARTS DIRECT...
http://searspartsdirect.com/dishwasher
Aug 01, 2017 | Kenmore 13742 / 13744 / 13749 Built-in...
Kenmore Elite Heavy Duty King size capacity Quiet Pak 1 dryer doesn't turn on
Check to see if the door switch is working. When you push and release it, it should click. If not, it will need to be replaced.
If the switch is good, then the only other component that would cause that problem is the thermal fuse. If you could post your model number I could direct you to the part you need.
Oct 15, 2012 | Kenmore Dryers
HE3 doesn't respond to any button. Time light keeps flashing time. Pause cancel button does nothing, Cycle doesn't start. The only thing that will change is if you push a different mode ie, heavy,...
Unplug the machine for at least half an hour to eliminate the possibility of an electronic glitch. Then upon plugging in back, close the door then push CONTROL/ON (if present on this model). Select the DRAIN/SPIN cycle then select NO SPIN by pressing the SPIN SPEED button. Push PREWASH OPTION four times within five seconds. If PREWASH OPTION is not present on this model, press EXTRA RINSE four times within five seconds. C:00 will light up on the display. If the Starting procedure fails, push the PAUSE/CANCEL button then repeat the starting procedure.
In order to advance to the next step of the test procedure, push PREWASH OPTION button two times. If PREWASH OPTION is not present on this model, press EXTRA RINSE two times. The test program goes from C:00 to C:08 and should flash an error code when a problem is present. Post the code back for further troubleshooting, including the exact model number of the machine.
Sep 20, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washer Kenmore 80series Doesn't want to drain the water after it's RINSE CYCLE. No sound from motor or pump. It just stops. does it drain after the wash cycle? if it does, then I don't think it's the...
Solution for Washer Kenmore 80series stopped on SPIN CYCLE and no Drainage or motor running.
** What was stopping it to drain was the defective limit switch which when the cover lid is closed starts the spin and the drain at the same time. I jumped the wires to get my close washed and I have to replace it for security. I had to unscrew the front control panel and remove the casing that wraps around the washer to have access for the limit switch wireing harness. I cut the two black wires and joined them with a wirenut so that I was able to continue my wash and draining the water leftt over.
Sep 06, 2009 | Kenmore 22422 Top Load Washer
Kenmore 23812 80series washer will not agitate or spin. Makes horrendous clicking sound. I can't afford new one right now need help to fix ASAP, please.
The clicking is probably the motor trying to start. If it has a belt, try to remove it to see if the motor can run alone. If the motor cannot run alone, it will have to go to a motor rewinder for repairs. If the motor runs, turn the next part by hand to see if it has a problem.
May 04, 2009 | Kenmore 23812 Top Load Washer
When my washer spins, it sounds like somehting is loose. kenmore 80series , model#11020802990 type111
does it continue to spin and make noise when you open the lid?
could be the drive block.
Mar 30, 2009 | Kenmore 24032\24036 Top Load Washer
Dryers Logo
44 people viewed this question
Top Dryers Experts
