Question about Cutler Hammer 100 Amp Main Breaker Resident Load Center
Have older, J51006 Cat # xo52 100 AMP circut breaker box
  • 760 Answers
Ok what is the problem?
Posted on Aug 24, 2010
I have a Charmglow electric fireplace that does not heat nor does the blower work. The flame light does turn on and turns. Model # 6901050100 Cat # 409896 It worked then quit. tore it apart, it wo
Did your circuit breaker blow.in your electrical box. Check that first before anything else. Sometimes if you have anything else on the same circut as a heater the breaker will shut down.
Jan 05, 2015 | Heating & Cooling
Cost for a 200 amp circut breaker
Any home supply store can give you the local cost. An additional cost will be even greater than just changing breakers. You must also change out the incoming service drop conductors. There may also be a need to have the power company's transformer supplying you home changed out. Check it out to be sure.
May 31, 2014 | Cutler Hammer "WESTINGHOUSE" MAIN DOUBLE...
14 in. saw with leeson motor
To start with what size circut are you trying to run the saw on? What ever the amperage is on the saw will draw almost 3 Xs the amperage rating of the saw on start up. If the circut is a 20 amp the breaker should hold long enough to start the saw. Also the saw should be the only thing running on the circut at the time. A 1-1/2 hp motor is a good size one aproximately 15.2 amps If you circut breaker is twenty amps and you still pop the breaker you may want to convert the motor to run on 220 volts as that will drop the load to approx. 7.6 amps Youcan run the saw on a 20 amp. 220 volt circut with no problem unless there is a problem with the motor. If the outlet is the only outlet on the circut it is an easy change to convert the circut.
Mar 02, 2013 | Target Portable Masonry Saw PS1411S...
When the air conditioner runs after a while it flips the breaker even if its on its own breaker.
Hello
Either the circut breaker is too small or there are too many other things on the same circut as the a/c.
Another possible solution is the breaker itself may be bad.Or the compressor in the a/c unit is going bad.
Usually a 20 amp breaker will be good for a window a/c unit under 16000 btu.
Jul 21, 2011 | Heating & Cooling
Were would I find the fuse for an AC Blower Fan on a 1995 Ford Explorer ( 4.0) 5 speed
The fuse(Circut Breaker 30 amp) can be located in the fuse box located in the engine department.( I had a 94 with a similar problem. The fuse box on that explorer was in engine comartment)
Jun 17, 2011 | Ford Explorer Cars & Trucks
It works only 10 min and then stops the energy in the house. whats the problem?
Hello
Either the circut breaker for that receptacle is too small,or you need to unplug somthing in the washine machine circut,lamp,iron, what ever.
If it continues you may need to upgrade your circut breaker to a 2o amp.
Apr 04, 2011 | Washing Machines
Compressor will not start without tripping breaker?
Circut breakers trip due to a short circut or an overload. In this case the likely cause is an overload. If your compressor is drawing more amperage than the breaker is designed to allow, the breaker trips for safety. Possible solutions. Try using a different outlet with fewer appliances or tools on that circut. If the outlet you are using is on a circut that also has lighting, appliances etc, each item is drawing amps, the addition of the compressor to the circut is pushing the amp limit over the top. You can also try a heavier duty extension cord. If you are using an extension that is rated too low for the required amperage your breaker will trip. If you are not using an extiension cord you may need to talk to an electrician about adding another circut to service your tool and garage needs.
Another possiblity is that your service is not upgraded enough. If you have a 60amp service for the house you might want to talk to an electrician about upgrading to 100amp or more.
Jan 04, 2011 | Garden
Need location of the blower relay for a 1999 ford escort zx2
If you have your owners manual look at the fuse box under roadside emergencies on page 105, using the picture shown of the fuse box, locate the circut breaker, marked in pic as Heater should be a small black box that plugs in, this is the 30A circut breaker for the blower motor test with a meter to see if it is good, if you do not have an owners manual go to fleet.ford.com an download one for free, hope this helps, let me know
Sep 15, 2009 | 1999 Ford Escort
Cutler Hammer 100 Amp Main Breaker Resident Load Center Logo
98 people viewed this question
Top Cutler Hammer Electrical Supplies Experts
Hippy_dd
Gene Haynes
R Buschy
Are you a Cutler Hammer Electrical Supply Expert? Answer questions, earn points and help others
