Question about Dell Dimension 3000 PC Desktop
My dell was working fine, went to restart it and it won't power up.Help
  • alilewis1205 Aug 21, 2010
    thank you so much for your quick response, I have no idea what a cpu, nor a ATX is and how I find it, or a cmos , sorry
    Thank you so much for your quick response, I really appreciate it, but I don't know any of the techinal terms.
  • 2,973 Answers
Disconnect the power cord from the back of the computer and re connect it. Check the wall power socket for current in it. Check the power on switch. Check the power supply unit (SMPS). It could have gone. Does the fan of SMPS work. If no, then the SMPS may be at fault.
Posted on Aug 21, 2010
  • 4,281 Answers
First make sure power cable connected to computer is working fine try with another power cable. Then if still same issue then open cpu cabinet cover then make sure smps power supply of cpu is fine it is square box on the top of cpu reconnect ATX cable from smps to mother board then check.Pull cmos cell from mother board for 10 minutes then put it again then all settings default then check. If still not work then replace smps unit. Then it will power up again. Let me know if you need further assistance. Thanks for using FixYa.
Shut down, black screen
It may be. Were you enabled hybernation for closing lid, this situation wouldn't have arises. You closed the while on means heat transmission may have caused this situation.
Apr 13, 2017 | Dell XPS M1530 Laptop
Daughter's TV was on during bad electrical storm. Screen went black and made high pitched sound. cable, internet and telephones all digital through Time Warner Cable. Now TV will not even turn on;...
Ur Main Fuses in the circuits breaker box must be to be restart it back.Turn off/on all the fuses on the main circuits breaker box to all the fuses in the box of the box to restart.All ur electical power outlets should work again.If not those power plug in outlets are shorted and dead must have to be replaced.
Aug 22, 2011 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Restart the computer when dell does not restart botton and a bue screen?
You need to elaborate the issue a bit.
what exactly went wrong with the computer.
When was the last time the computer was working fine
did you installed anything in the computer after which it went into blue screen
Is it a blank blue screen or is there any writing on it.
If there is any writing on it then what is it
Is there any error code mentioned on the blue screen
Feb 05, 2011 | Dell OptiPlex GX280 PC Desktop
Dell 4400 Main power in house went off while using my computer and then went back on about an hour later. Now when I try and restart the PC, the power button light turns yellow like it is in sleep mode...
The power supply or mother board probably went out. Did any other items in the house stop working? This happened to me years ago and the electric company reimbursed me for damages.
You can try unplugging the power cord for a few minutes, then retry listen for any beeps from the computer. If it is powering on but nothing on the screen and no beeps *********** board is probably toast.
Dec 10, 2010 | Dell Dimension 4400 Power Supply ** FREE...
Dell inspiron screen went black when i booted up the system
check it with external monitor if you get display then lcd is gone bad otherwise if you get dell logo then restart the system , press Fn key and power on the button it will start psa test
check for any hardware failures.
if hardware is working fine hen you will have to reset the system back to factory settings or reinstall fresh operating system.
Mar 06, 2010 | Dell Inspiron 2200/6000/9200/9300 8x DVDRW...
Storm caused power outage. When computer restarted no sound but everything else works fine. Dell 4100 desktop XP-pro
right click my computer and go to manage. Once there click on device manager and check your sound audio drivers. If it is yellow or missing then your sound card might of went dead. good luck
Jan 20, 2010 | Computers & Internet
Dell Insprion 530--No start up. Just hum.
Try this link....!
http://forums.techguy.org/windows-vista-7/787925-solved-dell-inspiron-530-frozen.html
Good luck,
Hank
Jun 11, 2009 | Dell Inspiron 530s Desktop Computer...
Video problem on my Dell Dimension 4600 PC, HELP ASAP.
the resolution set by default when you load your graphics driver is outside the range of your monitors capability.
try starting in safe mode then adjust your resolution to 640 by 480 then restart.
if this works, adjust upwards to 1024 by 768
then up again till the screen blanks.
when it does, dont panic, wait 20 seconds and the settings will restore - you then have the optimum settings for your monitor.
good luck
Nov 18, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 5150 starts up on its own!!
Check the power cable for some defect. It may have been twisted and the wires inside broken. Try using an alternate power cable and see how it goes.
Sep 01, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Inspiron 2200 laptop Display Problem
just open your laptop battry and give its power by addepture and on it.if the problem is not solved check the addepture,after that change your laptop motherboard.layes69@yahoo.com
Apr 22, 2008 | Dell Inspiron 2200 PC Notebook
Dell Dimension 3000 PC Desktop Logo
24 people viewed this question
Alun Cox
