Question about LG LMV1630 Convection/Microwave Oven
SET TIMER FOR 20 MINUTES FOR BAKED POTATOE.. CAME BACK AND FOUND POTATOES CHARCOALED. SMOKE AND SINGED INSIDE. MICROWAVE WILL NOT COME ON. CHECKED CIRCUIT BREAKER. POWER TO UNIT.
  • LG Master
  • 17,130 Answers
That was a very long duration to have set for potatoes. It would have made the magnetron burnt by exeeding the limit and findinf there was no conductive medium by moisture , it has ended up burning the magnetron.
First of all clean up the inside and clean up the point of the magnetron beam.Now confirm on the inside to be totally dry.
Disconnect power and check inside for break of fuse to the magnetron.If the microwave does not heat on testing with a cup of water , then it is possible that the magnetron is cooked.
Confirm the cost for the unit to decide on replacement.
Hope this helps.
Posted on Aug 21, 2010
I have a 3-year old Amana microwave installed above my stove. Last night I was baking two potatoes in the microwave. I noticed that the microwave sounded "louder" than normal. After about 13...
No! But it will need to be repaired. Did you wrap the potatoes in tin foil? The reason for the smoke needs to be found and repaired. Smoking means a short or a part shorted, failed, or wires touching another wire that did not blow any fuss.That is not good.
Trained technicians can help the mfg improve their products if they find the problem and report it to the Mfg.
LOL
Jan 28, 2011 | Amana MVH210W Microwave Oven
Sweet potatoe caught fire in my microwve
the magnatron super heated the paper combined with what we in the industry call super combust your micro should be ok to use just keep it clean and if you use toweling wraP it around rather than cover
Apr 21, 2010 | Amana ACO1860 Microwave Oven
Baked potatoes went up in flames now microwave has no power no lights. power outlet has 110v ac
Were the potatoes wrapped in foil? If so, the megatron tube was burned out. Replace unit.
Nov 06, 2009 | Kenmore 62622 Microwave Oven
I was cooking 4 potatoes for 14 minutes then put in frozen corn, started the microwave oven again and everything shut down.is there an internal fuse or breaker? or is it time for a new one.
Many of these ovens have either a humidity sensor or oven cavity sensor that will shut the oven down if the internal oven cavity humidity or temperature exceed a certain level. Baked potatoes are often a culprit as they retain a good amount of heat and generate humidity when they cook. In most cases, allowing the oven to cool down with the door open for about half an hour will restore operation.
However, there is also a thermal cut-out (TCO) on some models that will trip if the internal temperature of the oven cavity gets too hot. If the TCO trips, it must be replaced.
Since you posted no Brand Name of Model Number, I do not know how your oven is configured. If you post back with this information, I can verify and may be able to diagnose a cause of your problem.
Sep 16, 2009 | Microwave Ovens
My Frigidaire Microwave caught on fire
The owner's manual warns of the dangers of overcooking potatoes and similar foods and not to ever leave the oven unattended while it's running.
If for some reason you don't have your owner's manual, you can download Frigidaire owner's manuals and installation instructions here.
Are you looking for help to get your microwave working again?
Chances are it's just an opened flame sensor (cavity thermostat / thermal cutout / T.C.O.). Its job is to cut power if there's a fire.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Accessing some components for testing and possible replacement (like the oven cavity thermostat) will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Jun 07, 2009 | Frigidaire FMT116E1B Microwave Oven
Did I blow it up????
After washing you need to poke holes in potatoe skins or the steam can cause them to explode. Cook potatoes no longer than 6 to 8 minutes depending on your units power.
Microwave ovens can be very dangerous if damaged, so you will be safer to replace the unit. Better safe than sorry. Service on microwave ovens is not cost effective, and the newer ovens are very reasonable.
Ray
Oct 28, 2008 | GE XL1800 1100 Watts Microwave Oven
I bought a ge microwave 5/20/08. I have used it several times and it has worked well. Today I was cooking baked potatoes. I usually do them 1 by 1 and then put them in the oven for a crip skin. After...
It should default to the high power level without your having to select that.
But if you think it may have a problem, you could unplug it for a few minutes then plug it back in and try again.
After that, if it's not acting as it should according to the owner's manual, it may need service.
If so, since it's under warranty, I would let GE fix it.GE Customer Service is online here.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 25, 2008 | GE Microwave Ovens
Microwave Dead after burning up potato
Chances are the magnetron overheated and blew the thermostat / thermal cutout that monitors it. The magnetron itself may be bad, too. If Sears Service might consider this still under magnetron warranty, then they may replace the mag with no part costs (or just the thermal cutout part cost), but likely would charge labor. You can contact customer service or repair via http://www.sears.com Otherwise, if you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://www3.sears.com or likely cheaper here: http://tinyurl.com/gv383
Feb 06, 2007 | Kenmore 60659 Microwave Oven
LG LMV1630 Convection/Microwave Oven Logo
215 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
