Question about Pioneer DEH-P8000R
Face plate comes down but does not go up right away also canot extract cds in deck it has 4 or 5 cds in it
    New Friend:
Got the same problem ... any luck ?!
Posted on Mar 21, 2015
Kenwood kdc-mp522 face plate goes out when pushing on buttons
Clean the contacts on the back of the face plate and where it connects to the deck.
Mar 17, 2016 | Kenwood Car Audio & Video
I have a Jensen VM9312 and got it installed in my 2006 Yukon and I'm having problems ejecting CDs or DVDs. I had my stereo in my Dodge Charger and it worked fine. Both cars I had it installed...
I've had the trim ring that goes around the face plate make CDs not eject before, try removing this trim ring and see if the problem is solved. If it is not, I'd suggest contacting your installer, although you may have a problem with the deck now.
Feb 23, 2011 | Jensen Car Audio & Video
I have a 2000 Chrysler auto 4 disc changer and it reads err & I have 4 cd's in it and can't eject them. I was playing the cd's when it quit and read err. How do I remove the cd's and possibly solve...
pull the surround off around the 4 disc changer, and radio deck; when you do this the heater control unit will come out with the bezel which is okay. there are two philips screws to remove on the 4 disc once you pull the suround off. carefully pull changer out once srews are removed and remove the black face plate (4 gold screws on side). once that is off you need to remove the top metal part with the part nu,ber label on it...should be 3 silver screws, once this is off ou should be able to with your fingers, one by one remove the cds by pushing them out of the slot opening, there is a white gate though that you need to push down, hard to explain just be careful, and you will figure it out.
Jan 08, 2011 | Car Audio & Video
Russell Hobbs RHM200 microwave, turntable not working
replace the motor located , down the plate,
1st-take out the plate out the microwave
2nd-face up the down side of the microwave
3rt-remove the three screw or cut metal at 120degree you will see these points.
4- disconect the two cables connected to the motor
5-remove the two screw to extract the motor and go to a near shop to buy it. have a good luck.
Jan 05, 2011 | Microwave Ovens
When I load papers into the document feeder on top of my HP Officejet 7210 All-in-One printer to scan these documents, the PDF file (scan results) have a multi-color series of lines from top-to-bottom on...
  1. Remove all originals from the document feeder tray.
    NOTE: It might be easier to work with the automatic document feeder if the document feeder tray is removed first.
  2. Lift the cover of the automatic document feeder. Figure 1: Lifting the ADF coverc00222493.gif
  3. Lift the lid on the HP all-in-one, and locate the notch near the top right edge of the lid backing. Figure 2: Locating the notch near the lid backingc00222494.gif 1 - Notch 2 - Lid backing
  4. Place one or two fingers in the notch, as you lower the lid of the HP all-in-one. Keep your fingers in the notch until the lid is almost closed. Figure 3: Inserting fingers into the notchc00222495.gif
  5. Push against the top of the face plate with your thumb as you pull the bottom away from the right side of the HP all-in-one with your fingers. Use a slight twisting motion to help release the face plate on the right side.
    CAUTION: Do not pull the face plate all the way off yet. There is a plastic catch on the far left inside of the face plate that helps secure the face plate in place. If the face plate is pulled straight off, the plastic catch on the inside of the face plate might be damaged. Figure 4: Releasing the face plate from the right side of the HP all-in-onec00222496.gif 1 - Releasing the right side with a slight twisting motion
  6. Slide the face plate to the left until the plastic catch on the left side is not touching any part of the HP all-in-one, then pull the face plate away from the device. Figure 5: Removing the face plate from the HP all-in-onec00222497.gif 1 - Sliding the face plate to the left 2 - Pulling the face plate away from the HP all-in-one
Cleaning the rollers or separator pad Follow the steps below to clean the rollers or separator pad.
  1. Once the face plate of the ADF is removed, use the blue-green handle to lift the pick assembly. Figure 6: Blue/green handle and the pick assemblyc00222498.gif 1 - Blue-green handle 2 - Pick assembly This allows access to the rollers and the separator pad. Figure 7: The rollers and the separator padc00222499.gif 1 - Rollers 2 - Separator pad
  2. Lightly dampen a clean, lint-free cloth with distilled water, then squeeze any excess liquid from the cloth.
  3. Use the damp cloth to wipe any residue off of the rollers or the separator pad.
  4. If the residue does not come off using distilled water, try using isopropyl (rubbing) alcohol.
  5. Use the blue-green handle to lower the pick assembly.
Reattaching the face plate of the ADF Follow the steps below to reattach the face plate to the front of the automatic document feeder.
  1. Hook the face plate onto the left side of the HP all-in-one so that the plastic catch on the far left inside of the face plate catches on the notch on the front of the automatic document feeder. Figure 8: Hooking the face plate into the left side of the HP all-in-onec00222500.gif 1 - Notch 2 - Plastic catch
  2. Line up the right edge of the face plate with the right side of the HP all-in-one, and then press on the right side of the face plate until it snaps securely into place. Figure 9: Snapping the face plate into the right side of the HP all-in-onec00222501.gif
  3. Place your hands towards the center of the face plate, and press until the center of the face plate snaps into place. You should hear two clicks; one when the left side snaps into place, and one when the right side snaps into place. Figure 10: Finishing re-attaching the face platec00222502.gif
  4. Close the cover of the automatic document feeder.
  5. If you removed the document feeder tray, reattach it.
Dec 07, 2010 | HP Officejet 7210 All-In-One InkJet...
How to install memory in G4 iMac 700mhz
Lie the imac down on a soft serface with screen facing down. At the bottom of the base they will be a round silver plate, you will have to undo the four screws holding it in place.
Dont unscrew any more, you will affect the computer cooling, and it may over heat.
The silver plate should come away, on the right you will see the memory slot, with your two thumbs pull the clips away and up at the same time, insert the memory module lining it up with the slot just off centre, gently press it down and it should click into place.
Feb 11, 2010 | Apple iMac G4 Desktop
I have a dual xdmr7700 stereo and lost the manual need to get the face plate off
Same problem as yours with my deck. Bought the deck a month ago, turned car on in the morning face plate does not move down, music plays everything ok but can not access the cd or move the plate regadless button pushing.
Have you tried the reset button? Hold it for 3 seconds ( ball point pen to press the button above power button) U will lose the presets but Oh weel.
I am going to remove power completey from the unit later on today, and if it still has issues I am returning it for a replacement ( Bought it form Best Buy)
L8R
Nov 09, 2008 | Dual XDMR-7700 CD Player
CD changer will not accept CD's
I got the ERROR 3 on my Lexus RX330 2004 CD changer, and fixed this problem myself. My CD changer now works fine for more than one month after the repair, and hopefully will continue to work in the future )))) First, I opened top cover of changer ( about 8 screws ). Next step is most difficult - need to detach 4 tiny springs on top corners that hold metal top plate and keep them in the same place not allowing them to fall down (detach the spring, then hook the top with paper clip as to not let the bottom come detached and lose the spring inside). I used paper clips for holding the springs on the coners of the metal frame. Next need to take the metal plate out and then all plastic CD trays with CDs, the plastic trays may jam a little when being lifted out, but they will come out. Take all CDs and don't use them in the changer anymore. Seems the CD changer doesn't like CD-R's. So, use original CDs. Actually I an going to record new CD's using good blank media from good manufactures, will try to see whats gonna happen. So, take out all plastic CD trays keep them in order and facing the right way. After removing all CDs put all things back. Do everything very gently because all parts very precise and easy to break. The cd changer showed "Error 3" for the rest of the evening but then next day was fine and has been working fine since then. I think the computer had to be reset overnight to clear that error. If you have any questions, do not hesitate to PM me.
Oct 08, 2008 | 2005 Lexus RX330
Nothing works
try taken face plate off if detachable then put back on sounds like the face plate clip might be weak and or missing spring inside
but if face plate stays attached just need to clean and put back on right to deck no easy way to say that
May 09, 2008 | Pioneer DEH-P850MP CD Player
TEAC model A1500 tape recorder
What i did to solve this problem on my A-1500 was to remove the tension arm, the pinch roller and the front face holding screws , pull off the rubber faces from the reel hubs and remove them, remove the front metal face plate... in back remove the wood backing panel... inside the deck rear, remove, (without letting them fall into the mechanism) 4 screws that anchor the heavy front cast piece that holds the capstan flywheel...carefully lift the cast piece that holds the flywheel. away from the deck face just enough to allow the old belt be removed, and the new one installed...ensure the belt is installed and goes all around the flywheel..and is not pinched when you push the casting back against the deck face and reinstall the 4 rear anchor screws. place the belt around the upper drive motor pulley wheel.. small diameter part on motor pulley and large diameter part on flywheel for users of 60 hz. Ensure 60hz is selected on switch..or 50hz if that is what you need.(for 50hz ensure belt is on large motor pulley part and smaller flywheel diameter part. with deck lying down or leaning, place a few drops of light lube oil into the felt at the bearing hole for the flywheel. Give the deck a test playback before completely reassembling and putting all the parts back where they were.
Nov 18, 2007 | Audio Players & Recorders
Pioneer DEH-P8000R Logo
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
