Question about Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500
Poulan PPB200. There are two gas lines inside the tank. They have deteriorated and need to be replaced. One of them is supposed to have a fuel filter. The other one, I don't know. I'm also not sure which is which, as the fuel filter has fallen off. The parts explosions on repair part websites do not show the inside of the fuel tank. Can you help?
  • 20 Answers
The small one has the fuel filter. The other one is the return line to the tank. The return line is larger and usually have a fitting at the end of the hose and is inside the tank. Thread the new line ( large hose ) Through the hole on the right side. Thread until you can pull it out the filler hole. Install the fitting on the hose and pull it back up until the fitting hits the roof of the fuel tank (on inside of tank ) then that hose goes to the short fitting on the primer bulb. Then thread the small hose through the left hole going into the tank and pull it out the filler hole until you can install the fuel filter. Install fuel filter and pull it back until the filter rests on the edge of the filler hole. That hose goes to the right side of the carburetor. This is if you have a walbro carb. Zama also uses the right side for this hose. Hope my explanation helps. I'm working on one as well.
Posted on Oct 16, 2010
Starting problem.
Yes, that was the fuel filter. If it was loose then your fuel lines are probably bad. They will need to be replaced.
May 12, 2014 | Poulan Pro 25CC 2Cycle Gas Blower
I have a Poulan Pro leaf blower/vac. The fuel lines cracked inside the gas tank so I pulled them out & bought new ones. Now i can't get them back in to the gas tank. I understand there are
Make sure that you have the right size lines the smaller diameter line goes into the bottom hole of the tank cut a 45 angle at the end of the line as you put the line into the tank twist and push until you get enough line to pull up through the fuel filler hole then cut the line so that the 45 is no longer and slip the fuel filter on then pull back the line until the filter rests at the bottom of the tank. Do the same with the upper line except that line will only go in 3 to 4 inches. I hope this helps you.
Feb 29, 2012 | Poulan Pro Gas BlowerVacuum ()
Hi Sirs, I have a Poulan Woodshark model 1950. The gas lines deteriorated and I bought new ones, together with the primer bulb and the chain. Now I can't remember how to connect the lines. I need help....
The fuel line from the tank with the filter on the end goes to the carb inlet, closest to the metering cover usually a chrome cover held with four screws, the other conection on the carb goes to the suction side of the primer bulb, normally the shorter of the two conections, the pressure side of the primer goes back to the tank, this pipe just sits in the tank to act as a return, just remember the primer pulls fuel from the carb, into the bulb, and back to the tank.
Jul 23, 2011 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Need a diagram of fuel gas lines on a 131 poulan
Lots of research has shown a lack of diagrams on fuel line routing. Your carburetor has the purge/primer bulb on top of it. Just to help you understand how it works....the bulb uses a vacuum effect to pull fuel from the tank directly into the carburetor and the check valves in the plate under the bulb (known as the primer base assembly) push any air and old fuel inside the carb back into the fuel tank. On your model, the line inside the tank with the fuel filter on it will come out and go to the carburetor body BELOW the base assembly. The other line coming out of the tank (fuel return line) will go TO the nipple on the base assembly. The lines should be nice and soft and so should the bulb. They all have to be replaced periodically as alcohol, heat and age deteriorate them. Please post back if needed.
Nov 06, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
Trying to replace the fuel line and the primer hose both were rotted off not sure what goes where on my poulan pro ppb200 31cc string trimmer there are two lines into the tank the primer wont fill i have...
The smaller line is connected to the fuel filter in the tank and goes on the carb body opposite the end with the hole in the cover. A larger diameter line coming out of the tank is the fuel return line and has the little connector on it just inside the tank to hold it in place there
It goes on the carb body (if primer is on carb) by the bulb.
If there is an external bulb...the small line is the same...there would be a larger line going from the carb body (nearest the end with a hole in the cover) to the smaller nipple on the primer bulb. A third larger diameter line would be connected to the larger nipple on the primer bulb and running to the little nylon connector inside the tank. This is the fuel return line and the smaller diameter line is of course the fuel supply line.
Aug 07, 2010 | Poulan Pro Pp125 25cc Gas Straight Shaft...
Hello I'm fixing my poulan pro ppb200 gas
My service center told me that they are allowed only 2 of these adjuster per year. It has to do with the air quality issue. They don't want back-yard fixer-uppers to pollute the place up. True store - I could not believe it.
The BLUE wire-splice connector, the one that you crimp after you put a wire in each end, is supposed to fit snug around those screws and allow you to adjust them. However I could not get it to work.
If you take a hack saw and cut the lip from around the adjuster screws and then cut a slot in the adjuster screws themselves, you will be able to set those screws with a flat-head screwdriver.
The whole operation takes about 9 pushes of the hacksaw. The lip is aluminum and the set screws are a very soft steel.
Good luck
John
Apr 17, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
On weedeater blower and vac gas line is broke from carb into tank does it just connect to fuel filter in tank model 1925
Yes if your asking about the fuel line yes it hooks to the filter out thru the wall of the gas tank straight into the carb. if it broke out side the tank you can try a smaller plastic hose to stick inside to reconnect the two parts. if it broke inside the tank try to replace as one hose.
Jul 12, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan Pro Gas Trimmer Carb Problem...
try and adjust the fuel/oil mis screws
May 12, 2009 | Craftsman 25cc Gas Line Trimmer
Fuel lines
Line into tank isn't easy to pass. I made small hole in line near bottom, tied 30 pound fishing line to it (with knot inside of tube lumen), passed line through opening from above, and with fishing line pressure pulling gas line in, I squeezed tip of gas line entering tank from above with needle nose pliers until the line went into tank. Then i pulled excess through until i could trim tip (with knot) through gas tank opening, and then reversed line pull back into tank. Trim other end to fit onto primer exit port.
Apr 02, 2009 | Poulan Garden
Can't start my Poulan Woodshark Model 1950
Replace the fuel filter. Sounds like you have the primer lines hooked up backwards.
Part list have mod & ser #
http://www.ordertree.com/cms/Illustrated-Parts-List/64.html
Mar 25, 2009 | Garden
Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500 Logo
2,098 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
