Question about Microsoft Zune JS8-00001 Digital Media Player
My zune 120gb has got stuck at contact support and i have tried to restart it but it would not even go off until the power is dead
  • 502 Answers
If you hear clicking or grinding from the Zune it's a broken hard drive. If the drive sounds normal, you most likely need a new logic board which can be replaced without problems. There are third party Zune repair services, that will fix it for cheap. Even better, I found an DYI Zune repair guide, soyoucan do it yourself too, not that difficult. Part is availableon Ebay. If you can't do it yourself, have a tech savy friend do itfor you.
Posted on Aug 24, 2010
I want to know if the Zune 120gb can be fixed will not charge and wont power on
When you can't charge it, it can't power on. Check the charger, but also the cable and cable connectors. Perhaps you even can borrow a charger with a cord to check what is wrong. The charger to the player.
Oct 07, 2014 | Microsoft Zune 120gb 80gb
Does anyone know how to fix error 5 code?
Many Zune users will tell you of the dreaded error 5.
When the error occurs it means that the Zune has encountered a problem that it cannot recover from and informs users to contact customer support.
Usually to fix this error, the Zune must be sent to Microsoft. If the Zune is under warranty and the owner is within the US, this is little more than an inconvenience.
If the owner is outside of the US this is not and option and if the warranty has expired, the fix can come at a high price.
However, before sending a Zune off to Microsoft for fixing, there are a number of things to try.
The first thing to try would be to restart the Zune.
The steps to restart the device vary based on Zune model. For the Zune HD player, the user should press and hold the on/off button for roughly ten seconds and the player will reset.
For the non-touchscreen models of Zune, the user should unlock the hold switch.
Then, press and hold the back button and the top button of the Zune pad. The device should restart and the user can release the buttons.
If this does not fix the error, then the user should try reinstalling the software on their Zune device.
To reinstall the software on a Zune HD, the user should press and hold the on/off button for about ten seconds.
When the device restarts, the user should press and hold the "Media" button until the message "Connect Zune To Your PC" displays on the screen.
The user should make sure they have the most up to date Zune software installed on their computer and connect the Zune.
Update the Zune and it should be ready for use again. If the user continues to experience problems, then the Zune HD software may have to be completely deleted and reinstalled. Doing this will completely delete everything on the Zune, so anything that has not been backed up will be lost, including purchased items.
To do this, the user should hold down the on/off button again until the Zune HD restarts.
Upon restarting, the user should immediately press both the "Media" and the "Home" buttons until "Connect Zune To Your PC" displays.
The user should then connect their Zune HD to a computer with the most up to date Zune software and update the Zune.
For the non-touchscreen Zune models, the following step will erase user data (including purchased items), so a backup is recommended.
First, the user should unlock the hold button.
Then the back button and the top button should both be pressed and held down.
The next step varies by model. For owners with a Zune 4GB, 8GB, 16GB, 80GB, and 120GB, the Back button, Zune pad, and Play/Pause button should all be pressed and held down.
The user should continue to hold them until they get a "Please wait" message.
For owners of the Zune 30GB, the Back button, the left side of the Zune pad, and the center of the Zune pad should all be held down until "Please wait" displays.
After data is cleared, the message "Connect Zune To Your PC" will appear.
The user should connect the Zune to a computer with the most recent version of the Zune software installed on it.
After the software is installed, the Zune should be ready for use.
If these measures fail to fix error 5, then the Zune owner will likely have to send the device to Microsoft as the problem is deeper than a software issue.
Sadly, it is not always clear what causes error 5 to occur. In these cases, there are few other options than to leave it to the experts.
hope this helps
Oct 05, 2012 | Microsoft Zune JS8-00001 Digital Media...
Mi zune 120, modelo 1376, marca error "5", y que contacte el servicio de soporte, Como se soluciona eso?? MEx D.F. Bryan M
  1. Restart the Zune player. To restart the player, follow the instructions for the kind of player that you have:
    • Zune HD player: Press and hold the on/off button for about 10 seconds until the player restarts.
    • Non-touchscreen Zune player: Set the hold switch to the unlocked position, and then press and hold the back button as you press the top of the Zune pad. When the Zune device begins to restart, you can release the buttons.
  2. If you receive the same error message when you restart the player, try reinstalling the Zune player’s software.for more information go to
http://support.microsoft.com/kb/926993
Jun 27, 2010 | Microsoft Zune JS8-00001 Digital Media...
My zune 120gb stuck on contact support page and can't pay 18-30 u.s dollars to get help from support, should i throw mines away i'm fed up with problems comming up where i have to pay MORE money to fix.
no, dont just do the following On your zune make sure the hold button isn't on
At the same time hold down the back button and upwards on the directional pad until the screen goes black
then use your left hand and press the back button while using your right index finger to press the middle of the zune pad use your middle finger (on your right hand) to press play pause button. All of these need to be held at the same time. You should get a please wait message. follow the instructions on screen.
Jun 06, 2010 | Microsoft Zune JS8-00001 Digital Media...
Zune freezes and says contact support
in order to fix this . you have to restart the device. to restart the device you press and hold back while also pressing and holding the top part of the zune pad until screen goes blank and zune logo appears this should work. if contact support comes back up try restoreing the device.
for more info on how to restore the zune go to zune.net/support and press technical issues and a list with how to fix any problems will appear
Jan 09, 2009 | Microsoft Zune JS8-00001 Digital Media...
Stuck on startup screen.
pull the case apart and pull the battery out for about thirty seconds. put it back in and back together and it should work.
http://www.rapidrepair.com/guides/zune/zuneassemblyguide.htm
Dec 31, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My zune stopped working and now will not turn on
I figured out the solution by just getting upset.
Hold the Back arrow (<-) and Up on the touch pad and it will restart the Zune. This works for the 8gig and 80gig Zune.
Oct 20, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune will not power up or show device connected when in zune software
Zune won't turn on or charge
man i have the same problem, i was listening to my black 120gb Zune & i just upgraded to firmware 3.0 & now this s*** wont turn on! i been using it 3 days fine, but now it just shut off like its completely dead. i have been charging it for hours & hours & it just doesnt even turn on or have a battery icon or anything! i have it plugged in now too. restarted the computer, everything.... i tried to restart it by pressing back & up... are there any other shortcuts i can try? computer doesnt detect it or ANYTHING!!! HELLLLLP
--biancapassion@yahoo.com
Sep 02, 2008 | Microsoft Zune JS8-00001 Digital Media...
Microsoft Zune JS8-00001 Digital Media Player Logo
144 people viewed this question
Top Microsoft Audio Players & Recorders Experts
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
