Question about Sony VAIO VGN-C140G/B Notebook
My HD crashed. I replaced it with a new one. I cleared the BIOS by disconnect and reconnect the MB battery. When I try to reinstall the OS (XP, Vista and windows), it got to the point where it partitioned and reformatted the HD and start the installation, then the screen goes completely black, no cursor. The HD continued to run for a while before it come to a dead stop. Any idea? Please Help.
  • 6,826 Answers
I had a similar problem to this when installing windows 7 to my netbook with an external DVD drive.
I discovered that after getting to a certain point of the installation where it reboots, to remove the DVD for the installation of windows, so that it can proceed with the installation, instead of trying to partition and reformat the drive again which it does when the disc is in the drive.
It sounds, however, that your problem may be different than the problem I had. But, I thought I would share this with you.
Posted on Aug 21, 2010
I'm faced with a black monitor, no boot beep, with an operating fan and green light on. XP OS with an ASUS P5P800S motherboard, Thanks Jose
Remove all components from your mb and bios battery. Place jumper to clear cmos and make short to battery cmos. Leave 1min and after place cpu and one ram in mb. Replace jumper from clear cmos in normal position and verify. If not display, change ram.
Sep 26, 2014 | Computers & Internet
I have a HP G7-250CA in which the Hard disk crashed during a bios update. I have put in a new hard drive and now want to do a fresh install of Windows XP as I do not have the recovery disks. I keep...
Hi
can you please explain to us how the hard drive crashed during a bios update ?
or how do you know that the hard drive crashed during bios update
many thanks
And did you try to reinstall windows while original hard drive was still in the laptop
did you press the F11 key as soon as you pressed the power on key
Mar 07, 2011 | HP G70-250us Notebook
Trying to boot a d845pebt2 intel mb it came to shop with an error disk read error ran diag. and hd failed cloned drive to 320 gig old drive was 200 and got same error tried to run xp repair and got error...
as what i understand you have a failing HDD came from an old unit and trying to repair or reinstall O.S.? was your testing equip ment is the same as the harddrive you tried to replace and check. if it so. tried to replace the data cable of HDD you are using. and if you have another extra power supply try to test it with differrent PSU
Jul 13, 2017 | Intel Desktop Board D845PEBT2 Motherboard
Sata hdd recognized intermittenly and installation sometimes sata hdd detected and sometimes lost halfway
Hello
Try disconnecting the hd from the motherboard,then reboot.
Shut down all power to pc unplug from wall,then reconnect hd,restart pc.
Be sure that in the bios settings your hd is set for autodetection,if there is a sata option just use auto.
Nov 29, 2010 | AMD MB TUL | AX480A-GF XPRESS200P RT...
Can not reboot: i have set cpu's clock i added some more MHzs like: 133Mhz to 160Mhz CPU's clock in cmos and save. when it restart again it not boot, do you know why ?
Try to clear CMOS settings using following steps:
Turn off the system
Disconnect power cables
Open the case and locate the CMOS batery on the motherboard
Take out the battery and wait for about 10 minutes
Reconnect battery
Reconnect power cables and turn on the system.
Mar 07, 2010 | PC Chips M756LMRT+ PII/III/Celeron...
Gateway E3600 (Intel D845PT MB) won't boot after MS Update
This error comes when your motherbord not read properly harddrive.
for that first reconnect both connection to harddisk.Power cable and ide or sata cable.
Change SATA or IDE cable then check.
Pull cmos cell from motherbord for 10 minutes so all settings are factory defaults.
Then when you power up the computer press F1 or F2 or "del" key then you can see bios screen.
Make sure hardddrive detect in bios.
Set first boot device as harddrive.
Then check.
Let me know if you need further assistance.
Thanks.
Nov 06, 2009 | Intel Desktop Board D845PT Motherboard
Motherboard replacement instructions vaio vgn
IF YOU CHANGE THE MB.. SHOULD THE PCU IS COMPATIBLE WITH THEN MB.. ABOUT THE RAM SHOULD BE COMPATIBLE ALSO...LOOK THE COMPATIBLITY OF YOUR SPESIFICATION OF YOUR SYSTEM.... THE VIDEO GRAPHICS ACTUALLY IS BUILT IN THE MB JUST INSTALL THE RIGHT DRIVER.. ABOUT THE BIOS NO NEED TO RESET.. AFTER THE FIXING THE MB..FORMAT YOU HDD. OR INSTALL NEW ONE NOT OLD.. BECAUSE NEW MB.. IF YOU USE THE OLD OS YOU WILL MEET A LOT OF PROBLEM,, LIKE BLUE SCREENN,, AUTOSHUT OFF,, SOUND NOT WORKING, OR ANY POSIBLE BECAUSE OF FEATURES SOMTIMES.
Jun 24, 2009 | Sony VAIO VGN-FZ230 FZ Series Notebook
Boot Problem
Your Hard Drive is getting weak replace it with a new one , sometimes when it gets weak and get bad sectors it does not take up the OS and Boot bcoz the data written get lost so replace it or do the double check as follows
check ur hard drive is it showing u in Bios the main culprit is ur Hard Drive try re loading ur operating system by formatting ur hard drive otherwise Change ur Hard Drive it has become weak , there is a hard drive checking utility like HDDLIFE try connecting it to another desktop and scna it thru this software see the strength of the hard drive ur self download the trial version from website www.binarysense.com and let me know if it helps ,
basically if u computer boots ok and goes in bios when u press key that seems like ur whole pc is working ok incl RAM the only thing that is responsible for the operating sys is Hard disk it is where all files reside so when it crashes or get weak it doesnt give up files to boot so pc is unable to boot forward
pls do vote me if u find me helping and fixya problem
Feb 23, 2009 | Gateway 310 S PC Desktop
Dell Latitude will not boot
Reseat the hard drive and then get into bios and check if the hdd is detected ,if not you need to replace the hdd ,if detected reinstall the OS.
Apr 03, 2008 | Dell Latitude C600 Notebook
Sony VAIO VGN-C140G/B Notebook Logo
35 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
