Question about Maytag Neptune MDG5500AW Gas Dryer
Help solve my dryer will not dry my clothes what can i do?
Help fix my dryer to get hot again it is taking to long to dry
  • 3 more comments
  • Anonymous May 04, 2008
    dryer wont dry clothes drier runs but heater does not heat drum
  • Anonymous May 10, 2008
    The heat does not come on anymore. It was slowing not heating over the past few months and now seems to not heat up at all.
  • Anonymous Feb 01, 2009
    Whirlpool model geq8858hq1dryer will not tumble but the light will come on inside
  • gillcurr Feb 13, 2009
    Dryer heat become more inconsistant...from no heat (1/3 time) to
    weak heat (50% time) to normal again (25%)...
    3 yrs old..heavily used appliance
    repair man cleaned/chkd vents etc but couldnt find anything wrong & problem remains..should he replace any parts??
    my warranty is up in few months
    What are my rights if there unable to fix problem if I had it few yrs but still under warranty?
  • Anonymous May 21, 2009
    My heating element was changed from the top panel of the dryer. But when I close the panel down, my heater element won't heat! I have to leave the panel open to dry my clothes! What gives?
  • 413 Answers
LONG dry time is an indication of a clogged or restricted exhaust. Clogged or restricted exhaust is the primary cause of failure in all residential dryers. Blowing the the system with a shop vac is only a temporary solution. The system needs to be cleaned (2 to 3 times per year) with a rotary brush to scrape lint collecting from the sides of the pipe. Suggest going to Lowes and purchasing vent cleaning kit. Read instructions CAREFULLY. Also consider replacing flexible plastic or foil pipe with rigid metal type. Dryer will vent 30% to 40% better. If condition persists for too long, a high limit fuse mounted on the heater will open causing the heater to no longer operate.
Posted on Jun 01, 2008
Have a industrial type dryer jla t50, runs as normal but wont heat at all. had a gas enginer look at it. something is stopping the gas valves from opening. no fault codes showing either. what can it be. if i contact jla they will charge a complete fortune. any ideas
Posted on Mar 14, 2010
Wrinkles clothes terribly. Solutions.
Check your settings on your dryer. See if it's on a longer duration of time to dry. Dryers have different wording depending upon the make and model. If you're trying to dry smaller loads the heat settings s
does not have to be set for very long. Heavier, loads with thicker clothing will need to dry a little longer. When you take the clothes out of the washing machine, do you shake the clothes before putting them in the dryer? And do you use dryer sheets? Believe it or not, they're not only used to help make your clothe's smell fresh but they also help elevate static and a few wrinkles.
Mar 23, 2015 | Washing Machines
After a drying cycle the clothes are still wet. We set it on the normal cycle and switch it to Extra dry so it is running for about 59 minutes. After the dryer stops the clothes are still very wet. It...
sounds like an air flow problem meaning the dryer is not exhausting the hot air. Best way to check is to disconnect exhaust tubing from dryer and run a cycle. If the clothes dry normally the vent to the outside is plugged. Hope this helps
Mar 17, 2010 | LG Dryers
My electric dryer heats up but doesnt dry the clothes
If your vent hose is more than about ten feet long, your dryer may not have enough pressure to keep the air moving sufficiently to dry the clothes. Is it possible you are simply over loading your dryer?
Jan 25, 2010 | Kenmore 63942 Dryer
Dryer is hot, but not drying clothes. taking a
You have a plugged or resrticted exhaust flow. Remove the dryer and clean out the vent hose from the dryer all the way out of the house.
Jun 30, 2009 | Whirlpool Dryers
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
Dryer won't dry
Remove the rear connecting vent and try it again.
If it dries correctly...and it probably will. , clen the connecting vent and the vent in the wall.
Mar 27, 2009 | KitchenAid Dryers
Dryer not heating
THE PROBLEM IS YOUR WALL VENT CLOGGED OR THE BACK OF THE DRYER VENT HOLE IS CLOGGED,IT KEEPS THE MOIST HOT AIR IN THE DRYER SO YOUR CLOTHS TAKE FOREVER TO DRY,THEY MUST BE CLEARED FOR THE DRYER TO WORK AGAIN-MIKE
Jan 05, 2009 | Kenmore Elite HE4 Electric Dryer
Kemore Elite Oasis Dryer Error Code "AF?"
Problem solved! We read on here about someone else addressing the AF code by removing the back panel and fixing the pully that had come off. Belt was fine, with pully back in place dryer now works perfectly again. Thank you for saving us so much time and money!
Jun 14, 2008 | Kenmore 67082 Electric Dryer
Dryer heats up but clothes won't dry
Sounds like to me, that you need to check the vent going outside from the dryer. I had the same problem, and found a birds nest in the dryer vent on the outside of my house restricing air flow. If that doesn't fix the problem, look into a new heating element and or thermostats for the dryers. The old ones could just not be getting hot enough anymore. Good luck.
Apr 08, 2008 | Whirlpool LER5636P Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
1,694 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
