Question about Whirlpool GEW9250 Electric Dryer
Light on panel says control locked, shook, hit, and light went off, dryer worked. Now its on again, I think I have a bad connection, but for the life of me I cant remove the panel on front to check connections.
  • gordenwingfi Aug 21, 2010
    I asked how to remove panel!!
  • gordenwingfi Aug 22, 2010
    Control lock light stays on. need to check connections to control panel, How do I remove panel cover? Whirlpool GEW9250PWO
  • 1,998 Answers
Two screws down the very bottom also 3 screws on the back of the machine top lid area when u get these three off slide the lid backwards then work on the bottom panel after you remove the lid then you will oh just thought of something you wrote did you try holding the control lock button down for 5 seconds this usually releases the lock on the machine if this opinion has answered your question please remember to rank how this helped in your appliance situation and if you have any further questions please message me back have a great day
rickead1
Posted on Aug 22, 2010
This diagram is not for mod GEW9259PWO
  • Whirlpool Master
  • 19,396 Answers
Before removing the panel, if machine is still control locked, follow instructions here.
If you loose power during control lock, the machine will stay control locked
To find diagrams Enter the model number on one of the websites listed at this link
Posted on Aug 21, 2010
  • 1 more comment
  • Ginko
    Ginko Aug 21, 2010
    Click here to open the diagram, click on the picture to enlarge
    You will have to remove top panel nr 2, and all the knobs. There should be no retaining screw for the front panel nr 4. Try gently prying it off, if it does nont come off don't force it, find out the point where it is stuck. Behind that you find the control assembly held by screws.
    this diagram is not for mod GEW9259PWO
  • Ginko
    Ginko Sep 07, 2010
    Hi.
    The diagram is for GEW9250PW0.
    Click here to open all diagram for this model: GEW9250PW0
    I spent my free time to find the diagrams and follow your problem. Now I will be grateful if you change the bad rating given. Many thanks.
    Ginko.
Whirpool Fronload Dryer has power, timer cycles through, but it is not running. The dryer worked two days ago when I ran a load. I went to dry a load this morning and it turns on, everything lights up...
The reasons can be a fault on the program controller unit but as the door does not close the program also will not move further. This must be the clue to the fault. Remove and check the lock and the settings. manually close the door with force and see if the program cycle starts, if not check the door switch and the control panel. Also check for output when the timer counts down. If not the controller unit must be checked for possible problems.
Nov 14, 2011 | Whirlpool GEW9250 Electric Dryer
Nothing works on control panel except control locked sensor light. The buttons were working fine then I went to add more drying time and the buttons do not light up or work.
From the details of your symptom you're indicating a possible intermittent loose connection between the user interface (touch panel) and the machine control board or the voltage supply to machine control board at P1 connector.
Disconnect the power cord from the power source.
  • Disconnect P3 and P4 connectors from the machine control board and then reconnect them.
  • Disconnect P1 connector and then reinstall the P1 connector and then recheck operation.
If the wires are good then you will need to replace the control board on your unit.
Here is a link to the part.
Jan 09, 2011 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
My dryer will dry a load and then the control panel will not light up and the dryer will only work again sometimes when I unplug the dryer for a few hours
I can honeslty tell you that the control panel is going bad. I have already replaced mine once and it is acting up again. Just today it would not light up at all.
Aug 05, 2010 | Kenmore Elite HE4 Electric Dryer
Control Panel Kenmor Elite HE4
that sounds weird to have all those lights on...
first thing is to try and remove the "lock"light...
push and hold the button, for 5 seconds, below the "lock" light,
that should get the control back to normal operation. then if you still cant get the unit to turn on, try to unplug the dryer for a few minutes.
if you still cant get it to turn back on, call sears "customer service" and complain since your machine should not have failed at this early in its life.
Sep 15, 2009 | Kenmore Elite HE4 Electric Dryer
My Kenmore Elite Smartwash control locked light went on after I finished a load. Now no buttons work. How do I unlock the controls?
Just remember, the instructions are printed near the button. This features locks and unlocks the control panel as a designed safety feature to prevent small children from manipulating the controls. In addition, if you get error codes, or the panel starts flashing or freezes up, sometimes these errors can be erroneous. Unplugging the unit for 30 minutes will reset the Central Control Unit (CCU). This is the main "brain" of the washer. Any error code following a computer reset, is usually a genuine problem. If you ever have questions about this washer in the future, please keep me in mind. Congrats on getting it working again!
Mar 03, 2009 | Kenmore Elite HE4 Electric Dryer
Whirpool GGw9250Pw3 no power on Control Panel Inside light works
In my case, the problem was a dead main board. The board cost $190 and the overall repair cost $335. I will never buy another Whirlpool due to this experience.
Dec 11, 2008 | Whirlpool GGW9250PL Gas Dryer
Control locked on, can't release it
find button with lock emblem hold 3-5 secs if will not clear suspect either bad interface(buttons ) or bad connection or broken wire between front panel and interconnect on main control
Nov 26, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool YGEW9250PW1 Electric dryer control locked problem
I had the same problem, but my husband, who is an engineer, figured out that if you pull out the light bulbs that are not reading the correct volts on his volt meter, the control lock light will shut off and the dryer will start working. If you do not know how to do this, you can always buy a new control panel. I know this sounds to simple to be true, but we have bought several new "brains" (control boards), tried unpluging the dryer for days at a time, had an certified whirpool technician come out (who recommended buying a new control board), and nothing worked.
Sep 01, 2008 | Whirlpool GEW9250 Electric Dryer
Control panel locked light is on
ck for a button with hold to lock under it hold button 3-5 sec
Jul 02, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
88 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
