Question about 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
My viper remote, no matter what button I push on it just beeps and an icon that looks like a antennae flashes but nothing happens.
The Viper remote needs to be programmed properly. It didn't take. I have a Viper 488V remote. What worked for me?
Get under the dash on the driver's side and find the Viper module. Attached to it is a wire (might be coiled with a tie) that has a little black button on the end of it. This is the Valet/Program button.
1. Leave the driver's door open.2. Put the key in the ignition and turn the ignition on without starting the vehicle.3. Press the Valet/Program button six times and hold.4. Press the remote * button and release.5. Release the Valet/Program button and wait for the beeping to stop.6. Turn the ignition off and close the door.7. Test the function buttons on the remote.
Posted on Sep 25, 2012
    New Friend:
  • 103 Answers
Try this first, unplug the 2-way antenna on your windshield. Let it sit for at least a few minutes. Try recoding the remotes after you replug the antenna back in. This is an issue i have seen on some of the Viper units. Usually they never have issues, but here and there they need reset.
Posted on Aug 21, 2010
How do I reprogram a viper 5101 remote starer
on remote press the middle button for 15 sec. after three flashes on remote, put key in ignition and turn ignition on but dont start it. press button on antenna, release and then hold until horn honks or led flashes on antenna. lastly press lock within 5 sec
Jul 30, 2014 | 5101 LE 1 Way Car Remote Starter System
Viper alarm
What's the year, make and model of the vehicle?
Feb 10, 2014 | Vehicle Parts & Accessories
Need to fix problems with 5104 viper remote
It is possible that you need to reprogram the remote.
1st you need to enter the remote into programming... Hold the Function button until the remote gives a long beep and LED light comes on the remote a (it takes about 8 sec.) Then press and hold the remote start buttom until the remote beeps 3 times and LED lights up. Now your ready to program the remote
One of the door has to be open . Insert the key - turn the key to the On position then press the button on the antenna once and then press it again and hold it
You hear a chirp and then you press the lock button on the remote and then you hear a second chirp to receive confirmation and then release the button and the turn off the key .
Remote should be program
Jan 21, 2013 | Viper Televison & Video
Hi I have a viper 5701 it was working fine for about 2 years and today the car just stop beeping when I lock or unlock the car please help
Was this "beep" from the horn or a siren? The unit could be in valet. Look at the LED on the antenna. Is it on solid? If so the system is in valet. To remove valet, turn ignition on then off, press and release programming button on antenna.
If the LED is not on and, the "beep" came from the siren then, there is an issue with siren itself.
Jan 16, 2013 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
How to program a 7752V VIPER REPLACEMENT REMOTE
Open driver door.
Push and hold "f" key until remote beeps.
Push remote start button once so "pair" appears on screen. Push and hold "f" until remote beeps three(3) times to select pair mode.
Insert key into ignition an turn to "ON" position.
Push and release "valet" button on antenna, push again and hold until remote emits a series of beeps and displays "passed"
Feb 08, 2011 | 7752V Replacement Transmitter Supercode...
Hello, Everytime I press a botton on my viper alarm remote I keep getting this beeping sound a couple of times and nothings happening. What can I do?
what you need to is push the button on the back and hold it until it beeps. then press the lock button and let it sit there until you hear a long beep. then it should work
Jul 25, 2010 | Remote Start System
Viper 5701 remote issue
sounds like the remots have lost two way communication. try to disconnect the windsheild antenna.try remotes again after pluging antenna back in.
Feb 07, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Remote has red light flashing and beeping?
i have this alarm also.... for starters your batteries are dead, so get those when you get a chance. (best buy or radio shack) for now you can manually over ride your alarm... what you when need to do is get into your car by using the key, and the alarm is going to go off
1. locate your antenna, which is going to have your blue LED and a square push button. usually at the top of your windshield
2. while the alarm is going off, you will need to put the key in the ignition and turn to the on position, ofcourse it isn't going to crank.
3. within 5 sec of turning the key on, you will need to push the valet button( button on the antenna next to the blue LED) 1 time, release, then push it a 2nd time but hold it down until the alarm shuts off, this will allow you to start the car with the key. if it doesn't work the first time, turn the key off and try it again
the default is 1 press, the pushing it one more time and holding, but it can be programmed by whoever installed to be 1-5. hints, pressing it 2X the holding on the 3, or 3X then holding on the 4 ect
Aug 15, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Got a new remote for my viper 791XZ and reprogrammed it .
this usually means that the remote did not recieve a signal back from the module or the module did not recieve the remote signal
have you tried repeatively to press the unlock button? does the remote starter work or aux( trunk ) ?
also when putting the battery in the remote , be easy because there is a connector plug soldered on the board real close to where the battery is , and if it is hit by the battery hard enough it will cause those solder connections to disconnect and you will get the beeps and or other malfunctions
Jan 31, 2009 | 791XV The 791XV is a 2-way Security and...
5701 VIPER 5701 2-WAY ALARM w/REMOTE START Logo
946 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
