Question about Yahoo Messenger
I used dial-up connection aircel i can't sign in yahoo messenger. what i do.
Sign in using http proxy. it will work definately
Posted on Sep 04, 2010
I cannot sign in into yahoo messenger,but i can sign in into my yahoo mail
First, go to you IE, Click on Tools, Click on Internet Options, Click on Connections, then check "Always Dial my Default Connection. Click Apply, Click OK.
When Yahoo detects that you've already signed into Yahoo Mail, it will disconnect you when you try to sign into messenger or vice versa - thus, the message that you are signed in to another computer.
To get rid of your problem simply disable chat in your mail account by clicking the smiley and following the prompts.
Yahoo remembers your settings until you change them.
Hitting the X on the Contacts page in Yahoo Messenger does Not Sign you out of Yahoo Messenger, it merely closes the contacts page. Always Click "Close & Sign Out" for your Y!M.
I hope this solution will act as an insurance upon soling this problem of yours
Jun 16, 2011 | Yahoo Messenger
Cant sign in in yahoo messenger at mozilla fire fox
Click the Messenger menu in Yahoo! Messenger and select "Connection Preferences."
Enable the "Firewall with no proxies" option.
Select the correct Internet connection type and country from the pull-down menus.
Click the OK button at the bottom of the window.
Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the OK button.
Enter your Yahoo! ID and password and click the "Sign In" button.
The above configuration works in most situations. (However, if you connect in this way, you won't be able to use the Voice feature.) If this configuration doesn't work, follow these steps:
Enable the "No network detection" option and then click the OK button at the bottom of the window.
After this steps and this still not solve it. You can check and set your I.S.P and Proxy Server. here are the steps.If neither of the above options work (sorry), you're probably behind a firewall or proxy server that requires you to enter its address. Follow these steps:Click the Messenger menu in Yahoo! Messenger and select "Connection Preferences."
Enable the "Use proxies" option.
Enter your firewall or proxy server's address and port number. Contact your network administrator (if you're at work), or your Internet service provider (if you're at home) to determine the correct firewall and proxy settings.
Yahoo! Messenger will ask you if you want to sign in with your new proxy settings. Click the OK button.
If you try all of the steps above and Yahoo! Messenger still can't connect, contact your network administrator, Internet Service Provider (ISP), or the person who initially set up your computer to ensure that your firewall and/or proxy settings are correct
Aug 04, 2010 | Yahoo Messenger
I just came up to download yahoo messenger version 10.0 beta but it wont work out . Ofcourse I do have uninstalled my old yahoo messenger version 8, After several of trials signing in on the yahoo...
well..this problem occurs sometimes with yahoo messenger 10. so you need to know how can you sign in,
when you try to sign in on yahoo messenger 10, please go to messenger settings and then in the connection settings tab, please select your network type, i mean if your network connection is broadband, select broadband..if you are using dial up modem, select it or if you are using lan..select it...then try to login again..
i think your problem has been solved.
thaks for using fixya
Feb 28, 2010 | Yahoo Messenger
I m not able to sign in my yahoo id.
go to messenger, click connection preference, change to connect via a proxy server and scroll down to internet connection. Change it to High speed (T1/LAN) or Dial up.
Test either of the two and one should work.
Best regards.
Feb 15, 2010 | Yahoo Messenger
Cant log in to yahoo messenger
Try creating a new account, or try the forgot password link.
Jan 21, 2010 | Yahoo Messenger
Yahoo messeger cannot sign network encountered a coonection problem
May be u using any kind of proxy...to check it open IE ...click Tools>Internet options> Connections> Lan settings > Unchecked the Box written for [Use a proxy server for you LAN(This setting will not apply to Dial-up or VPN setting)]
or
open Yahoo messenger click Messenger> Connection Preferences>In the Network or Internet connection >select Connect directly to the Internet> Apply > OK.....
If you still facing the connection issue ..try uninstall yahoo messenger, download and install latest version of Yahoo messenger ..if that doesn't help ...may be that is blocked by your network administrator or ISP ..contact them for solution...Good luck
Sep 18, 2009 | Yahoo Messenger
Connection problem 81003004
To solve this kind of network connection in your yahoo messenger, just click on your yahoo messenger, select the connection preferences in the menu and then select the proxy server as the connection preference other than the internet one. then select from either the dial-up, broadband or the high speed t1 lan connection. it's up to you how you connect.
it works for me. hope this can help you.
cheers,
argion
Jan 19, 2009 | Microsoft Windows XP Professional
Login error 81003004 from Yahoo Messenger
as far as wat i did to my YM.
i simply checked the connection preferences and turned
"Connect via a proxy server."
then select
"HTTP proxy"
after that take a look at your internet connection dropdown list..
some mistakes are seen here.. instead of having the "broadband" connection selected the "dial-up" connection was chosen by YM itself..
hope that helps ya ^^
Dec 16, 2008 | Yahoo Messenger
There was a problem signing into yahoo messenger please try again a little bit later
throw your laptop to the bathtub with water and let it dry for 5 minutes and make sure that you plug it right away then turn it on.
Nov 03, 2008 | Yahoo YHT-630 System
Problem in Signing
i cant connect to yahoo messenger, when i put username & password it tells me that i have to change proxy settings. when i go to connection i can see that it has internet connection by dial up , as i have dsl, but it dont let me change it, it is gray where do i have to change this setting.
Jan 18, 2008 | Yahoo YHT-630 System
Yahoo Messenger Logo
70 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
