Question about Dishwashers
I need to know how to use my Eco1 glass washer
  • 1,476 Answers
Annmarie,
I have a tip at http://www.fixya.com/support/r5441537-get_free_manual which should help you locate a manual which should explain the operation of your unit.
Thanks for using FixYa and for the great rating!!
hardrocko
Posted on Aug 21, 2010
Tip
I replaced the valve prematurely! Check the power to the valve FIRST! My had no...
Your washing machine will not fill up with water. You have checked the hoses, cleaned the screens, and still no water. Now what is next?
First make sure that you unplug the washer to prevent a shock. Then you will have to get to the valve. For some washer this can be done by an opening in the back panel. And for other you may have to remove the entire top of the washer to access the valve body.
Hopefully you can get there without removing the wiring, so that you can check to see if you are getting power to the valves. Once you can get to the valve body, then carefully get a meter on the connection to the coils, then plug in the washer and start the cycle where the water would normally flow. If you have power at the coil and the water does not flow then you know that the coil is bad or the valve is stuck. There are ways to clean the valves but usually a new valve body will be under $40.00 and it is not worth the mess and the possibility that the valve will soon get stuck again. If you find the problem there, just replace the valve, it is much easier.
If you are getting no power to your valve then you know to look back in the wiring further. You may have a bad switch in the timer. Follow the wires and trace the back to see where the power is stopping at. If you have power going to the timer and no power coming out then you have found your problem there.
Troubleshooting appliances is often just a matter of following the problem back to where it starts. Be patient and be very careful when working with electricity. Always make sure you have the appliance unplugged when you are not actually checking for voltage. Also be aware that some appliances have power on what you would think to be the neutral.
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
on Jul 04, 2011 | Washing Machines
Light changing
The frosted glass cover over the lamps in your video is held in place by the knob / nut at the very bottom. Support the glass with one hand, and loosen the knob / nut with the other by tunrning in a CCW direction. There will likely be a flat washer or decorative trim between the glass and the knob (be sure not to lose these parts). The knob / nut should only be hand tight, but that doesn't stop some people from using tools to tighten them.
Once the nut has been spun off, the weight of the glass will be in your hand. Gently lower the glass. Inside, you may find a washer and felt. Depending on yur particular glass, it may have neither - but if it does, you should reassemble the washer & felt in the same order as it is designed to help prevent cracking the glass if the knob / nut is overtightened.
Relamp, repair & clean as needed and reassemble in reverse order of disassembly.
I hope this was helpful!
May 16, 2013 | Air Purifiers
Glass separating from lid
Replace with steel lid. Parts below but first I have to get my 2 cents in!
I bought the replacement glass lid and it broke within the first week. Terrible design! They are using double sided tape to hold the glass to the hinge. There is too much spring tension to be held with tape. Way to go whirlpool engineers. I'm just a welder with 1 year of school and I figured that out? Hmmmm?
Steel lid retro fit
Whirlpool will tell you it can't be done. However I did and it works and looks perfectly.
here's the parts you need
All from a WTW8200 series washer
Part prices from Sears. I'm sure you can find them cheaper elsewhere if you look. I bought from sears to utilize the return policy while figuring out what parts to get. Thanks Sears! Give them the business if you can!!
1 pc 8572026 Steel lid $40.90
2 pcs 8563964 hinge $6.99 ea (hinge from the glass lid are different and the screw holes won't line up)
4 pcs W10119828 $3.99 ea (could probably get from the hardware store for half the cost.
Solution 2:
buy a replacement glass lid from whirlpool and send them your broken original glass lid and get a refund for the one you just bought. Repeat as needed until they figure out they need to produce a quality product.
Keep your whites...White and your colors bright America!!!
Nov 20, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
How do I replace glass bowl on a Bosch wfmc2201 clothes washer?
Hello, welcome to FixYa.
I'll start by saying your post indicates it is a Bosch Nexxt 300 washer wfmc2201 that you would like to "replace glass bowl".
I don't know what research you've done to bring you to the place you are now, but hopefully I'm not the first to tell you. If you are referring to either the glass inside the door or the plexi-glass outside the door, that comes as all one component.
The Bosch part # 249080 is available at several retail locations online such as "repairclinic.com" "searspartsdirect.com" to name a couple.
Unfortunately this has always been the case with Bosch/Siemens built full size laundry products when it comes to the door components (at least in the time I've been working on them, 15+ years)
Let me know if I can provide help in any other manner and I'll be glad to assist you going forward in any way I can.
Regards,
Macmarkus :)
Jun 30, 2011 | Bosch Nexxt 300 Series WFMC2201UC
Washing machine won't drain. What does the hour glass symbol mean. It is defined in the owner's manual
From <http://support-us.samsung.com/cyber/popup/iframe/pop_troubleshooting_fr.jsp?idx=419733&modelname=WF409ANW&modelcode=&session_id=V5mMmkpq72BqyQB5Lny5vwblqvWTyT6hLbGQypLMbhMpMhlQBdfJ!-943087853!1669102353!1442424460210&from_osc=&homeid=2217>: "The hour glass is displayed to let you know the washer's timer is counting down. This is normal, and does not require service."
Dec 16, 2010 | Samsung WF337AA Front Load Washer
Need to replace broke window on 93 ford tempo.Pass. side
Door Glass, Front Removal
  1. Remove door trim panel and watershield. Refer to Section 01-05. ani_caut.gif CAUTION: Prior to removing center pins from the rivet, it is recommended that a suitable block support be inserted between door outer panel and glass bracket to stabilize glass during rivet removal. Remove center pin from each rivet with a drift punch. Using a 1/4-inch diameter drill, drill out remaining rivets as damage to plastic glass retainer and spacer could result.
  1. Remove two rivets attaching glass to run and bracket assembly.
  1. Remove glass.
  1. Remove drillings and pins from bottom of door.
Installation
  1. Snap plastic retainer and spacer into two glass retainer holes. Make certain that metal washer in the retainer assembly is on outboard side of glass.
  1. Insert glass into door.
  1. Position glass to glass bracket. Install two rivets to secure glass to glass bracket. NOTE: Two 1/4-inch-20 x 1-inch bolts and two 1/4-inch-20 nut and washer assemblies may be used as alternates for glass retention. However, torque must not exceed 4-7 Nm (36-61 lb-in). Equivalent metric retainers (6mm) may be used.
  1. Install door trim panel and watershield. Refer to Section 01-05.
2-Door Vehicles
4-Door Vehicles
May 29, 2009 | 1993 Ford Tempo
Front glass window seems loose
When the machine is spinning, place your hand gently against the glass and check for a vibration. Do not push on the glass.
This is to check and see if the vibration is from the door or from somewhere else.
The front door comes apart. Disassemble the door and check the seal where the glass sits. If this seal is worn or out of place it will allow the glass to rattle against the rear panel. When the machine is spinning, place your hand gently against the glass and check for a vibration. Do not push on the glass
Jan 12, 2008 | Bosch WFMC 3200 Front Load Washer
Dishwashers Logo
Top Dishwashers Experts
