Question about GE Dryers
My GE dryer model DWLR473ETOWW is making a sound like the drum is rubing on something. It's rather loud almost like a sound you would get in a washer if all the clothes were on one side. I can't figure out how to get the front of dryer to open where I can look at the drum. Is there some screws I need to take out. The only ones I see are on the very top of the dryer.
4 Suggested Answers
SOURCE: GE Dryer model#DWSR483EA1WW
you need to replace the inner plastic "shell" and the teflon pieces that the drum rides on. The dryer drum has eaten thru the teflon slides, and has probably started eating the shell away also.
About $40 in parts available on line will fix the problem.
Posted on Jun 21, 2008
pumpkinman
  • 1147 Answers
SOURCE: Ge Dryer making loud rumbling noise
drum bearings are going up
Posted on Jun 19, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I have a loud squeaking noise from a GE electric dryer drum..
UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
I am not sure what plastic part you have, but there should be no small plastic parts in your dryer drum or at least not the ones I have worked on before.
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine,
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Posted on Oct 28, 2009
GE front load washer makes a loud slapping sound during the spin cycle and it sounds like something heavy is in the drum that keeps falling to the bottom of the drum when the spin cycle ends
You did not post the model number and that would be a must. However this sounds like the bearing or the pulley on the drum may have broken.
Dec 18, 2017 | GE Washing Machines
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Electric Dryer Model DCSR473EVOWW has loud scraping sound when drum turning .... sounds like metal on metal
There is likely to be something stuck between the inner drum and the outer casing. In my experience this is most commonly the wire from an underwired bra! (belonging to my wife!)
If the inner drum has holes in it feel the surface carefully all over to try to detect a wire or other object protruding into the drum. If you find something it can often be pulled free with a pair of pliers or pincers.
Jan 04, 2011 | GE Dryers
Dryer - GE model DRSR483 ED2WW Worked fine a few days ago with a light load. Now, just a loud beep when I try to start it. It doesn't come on. I can turn the drum manually (slowly) - almost sounds like...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 01, 2010 | GE DBSR453EBWW Electric Dryer
GE profile electric dryer, sounds like something is stuck in drum
Heating problem is most likely caused by one strand of your heating element is burned out. Heating element will have to be replaced if that's the case. Noise you are hearing is most likely coming from worn front and / or back bearing. Dryer has to be completely disassembled for either repair.
Aug 28, 2017 | GE Profile Harmony DPGT750EC Electric...
Loud rumbling noise with slight vibration
Normally the noise you hear is caused by the drum rollers having flat spots on them or needing lubricant.
If this is what is wrong It will make a kind of thumping noise.
When they need lubricant they will normally make a squealing noise also. You would lube the shaft and bearing area of the roller, using a good machine oil...something like "3 in One" oil.
Sep 26, 2009 | GE DBXR463ED Electric Dryer
New GE Profile Dryer makes intermittent loud squeeking or rubbing
Your drum may be out of round. The drum belt on the outside of the drum may be rubbing against the cabinet. When the cabinet heats up, the side walls of the cabinet may be bowing inward, thus making contact with the belt on the drum. This would explain why it is intermittant. When the heater turns off, the cabinet cools and the sides bow back out.
Jul 11, 2009 | GE Profile Harmony DPGT750EC Electric...
Loud squealing noise from Drum belt looks fine other solutions
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 06, 2009 | GE Dryers
Dryer makes noise as drum rotates on ge profile gas dryer
Solution: the drum slides were worn out and needed replacement.
Jan 13, 2009 | Dryers
VERY noisy GE profile electric dryer
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=DPSQ495ET4WW&mfgModelNum=&fkMfgID=2 The problem you are having is with the front glides and the back bearing . # 316 on the door diagram.& # 543 on the drum diagram. those are the parts to replace.
Dec 22, 2008 | Asko T701 Electric Dryer
Dryers Logo
282 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
