LOCATION & REPLACING THE PCV VALVE ON A 2001 FORD EXPLORER XLS-4.0L
  • 92 Answers
SOURCE: 1998 Ford Explorer sport 4.0L 4x2 PCV Valve Location
the pcv is located on the rear(firewall) of the drivers side valve cover.turn counterclockwise and pull to remove be careful there are 2 small tabs inside the pcv hole in the valve cover(can feel with small finger) this is to hold valve in place so it wont leak.if you have a oil leak at the pcv a quick fix is to put a small amount of silicone around the pcv o-ring and install.wait hours for silicone to set up.
Posted on Oct 21, 2008
Handy Mike
  • 6 Answers
SOURCE: how do i replace the pcv valve on a 2000 explorer xlt v6 sohc?
On the passenger side of the intake manifold, coming off the bottom about the center of the engine front to back, you'll feel a hose that comes off a nipple. That hose makes a 90 degree bend and goes around to the rear of the motor. Where that hose meets the Y-connector from the other side of the intake you'll find the PCV valve. It's almost impossible to see it with the hood installed, and even tougher to reach it.
A good source of information for Ford Explorers can be found here
Posted on Oct 25, 2008
SOURCE: 2003 FORD EXPEDITION PCV VALVE LOCATION
show me a picture. everyone else says it's on the passenger side. nothing white on driver side of my 03 expedition.
Posted on Mar 07, 2009
SOURCE: pcv valve :where is it located on a 1999 ford explorer sport 2wd
It is located at the back of the engine near the fire wall. It is gray with a T connector at the top with two hoses coming off of the T and going forward into the intake manifold.
techbuster
  • 5081 Answers
SOURCE: location of pcv valve on 03 ford focus
http://www.focushacks.com/images/pcv.jpg
Here's a picture to locate it..
So, when looking at the engine from above, on the right of the exhaust.
Procedure to replace it
1) Lift and support the front end of your car, or drive up on ramps
2) Get under the front of your car. The PCV Valve is located behind the exhaust manifold, a few inches below the valve cover.
3) Push up on the PCV valve to pop it out of the tube, or pull. You can get it out of the rubber tube with some effort.
4) Remove the rubber elbow from the top of the PCV valve. This can be re-used if it's not squishy. It can also be replaced cheaply.
5) Put the elbow on the new PCV Valve
6) Re-attach the elbow to the PCV tube
7) Push the new PCV valve back down into the large rubber tube
Posted on Sep 25, 2009
How to replace Pcv valve
1) Locate it
2) unplug it
3) Disconnect from vacuum line
Reverse procedure with new valve.
Dec 01, 2015 | 2001 Ford Explorer Sport Trac
Pcv valve location ford explorer 1999 5 liter
The pcv valve location is in the rear of the lower intake. Somewhat difficult to get to.
Nov 27, 2015 | 1999 Ford Explorer
Where is the pcv valve at the engine ford explorer sport 99
PCV Basics
PCV stands for Positive Crankcase Ventilation.
All car engines have a PCV valve and it is located on top of the motor's valve cover. There is a vacuum line attached to it. It pulls out of the valve cover and if you shake it, you should hear a marble knocking inside it. If you shake it and don't hear anything, it's bad. It costs less than 5 bucks to replace.
Location
* 4.0L is located in the valve cover near the brake booster
* 5.0L is located behind the intake manifold (engine rear)
NOTE-Most people that are asking actually want to know not only where is it but also how do you get at it to replace it.
Often answers say that you need to dismantle the intake manifold to get to it.
This is a major and unnecessary approach, for example, on the 2000 Explorer with a 5.0 V8
Below is an additional suggestion on how to access a PCV valve on an 2000 5.0 V8 Explorer
The PCV valve is on the rear of the intake manifold (the intake manifold is also on top of the crankcase so PCV valve has direct access to crankcase)
To replace valve and/or its bushing:
  • Disconnect one battery terminal, unbolt/unplug the PCM cable (Powertrain Control Module connector located on the firewall) and firewall ground connection, depress underneath tab and slide the main cable connector (located to the right of PCM connector) off its mount.
  • Move the cables to the right and now you can easily reach down behind the intake manifold to the PCV valve
  • Service valve and its bushing if needed, reverse actions to reassemble
Hope this helped (remember comment and rated this). Good luck.
Apr 05, 2010 | 1998 Ford Explorer
Where is the pcv valve located on a 1999 ford explorer? Is there a picture?
PCV BasicsPCV stands for Positive Crankcase Ventilation.
Location
  • 4.0L is located in the valve cover near the brake booster
  • 5.0L is located behind the intake manifold (engine rear)
Oct 04, 2009 | 1999 Ford Explorer
Need location
The PCV valve for a 5.0L is located below the upper intake manifold in the rear. It is locate in the lower intake manifold in the rear right below the upper intake manifold. It is really hard to see but if you get a mirror you can probably see it.
Apr 12, 2009 | 1996 Ford Explorer
pcv is on the back side(firewall) of the drivers side valve cover.held in buy lock tabs,turn then pull to remove.
Nov 10, 2008 | 2000 Ford Explorer
2000 Ford Explorer 6 cyl
pcv is located at rear of valve cover on drivers side.to remove turn counterclockwise then pull.be very careful because there are 2 small lock tabs to hold valve in place.
Oct 21, 2008 | 2000 Ford Explorer
Sep 25, 2008 | 1998 Ford Explorer
Code #P0171 & code #P0174
The most common problem on a Ford with these codes is deteriorated PCV hoses. Check the hoses from the PCV valve to the intake manifold. Pay special attention to the rubber elbows. They often crack on the inside curve and the crack is hard to see.
May 19, 2008 | 1999 Ford Explorer
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
