Question about Kenmore 24032\24036 Top Load Washer
Kenmore washer it will fill agaite, drain the water out but will not spin
    President:
  • 1,554 Answers
This is a clear evidence of a broken motor coupler. It is the one that connects the drive motor shaft to the transmission assembly and transfer the mechanical energy of the motor. The mechanical energy is not transferred to the transmission and therefore result in the agitator not to agitate and the drum not to spin. The drain pump works because it is directly coupled to the rear spline of the motor. Replace the motor coupler to address the problem.
Release the console from the top of the cabinet depending on the model of your machine then pull forward and up on the console and lay it back on the hinges.
9dec9akenmore washer it will fill agaite, drain the - 5b4b40f.jpgs=
e5a5ab8.jpgDisconnect the lid switch harness connector by pressing on the tab located in the middle and pulling it up.
The cabinet is attached to the rear of the washer by two brass-colored retaininkenmore washer it will fill agaite, drain the - 4e2277c.jpgsert a flat blade screwdriver into the turned-up edge of the clip, located on both sides, and then pry back to release the clip from the slot in the cabinet.
Open and hold the lid while grabbing the cabinet front opening then tilt the top of the cabinet toward you by pulling the cabinet away from the base. This releases tkenmore washer it will fill agaite, drain the - 8df0387.jpgd back slots of the cabinet from the tabs in the front and back of the base. Using the side of your leg and/or body as a support for the front kenmore washer it will fill agaite, drain the - 362516f.jpgbinet, carefully lift up and set the cabinekenmore washer it will fill agaite, drain the - 8f6d9e3.jpg />8df0387.jpg
With the cabinet removed, pry the clips securing the pump to the motor off and remove the pump.
Disconnect the motor harness then remove the screw securing the bottom clip holding the motor and remove the clip. Hold the motor from the bottom kenmore washer it will fill agaite, drain the - 029e147.jpgning the screw securing the top clip holding the motor. Remove the clip then pull the motor out of the washer.
Remove the broken coupler parts from the transmission and the motor shaft then tap the new coupler parts in place or until the splines are even with the edge of the coupler.
Remove the motor mounting plate to remove the coupler part in the transmission side more easily.
Once the coupler parts are properly installed, put the rubber grommet into the coupler in the motor then line up the remaining slots on the grommet with the coupler prongs in the transmission and put them together.
Secure the motor with the clips and the clips with the screws then reconnect the motor wiring harness to the motor terminals and reinstall the pump in reverse order of the removal steps.
Bring the cabinet to the front of the washer then slide the front bottom rail of the cabinet under the rail at the base of the machine then lay down the cabinet into position. Make sure the slots in the cabinet sit into the tabs at the base of machine.
Reconnect the lid switch harness then push the retaining clips back down into position to secure the cabinet to the rear of the machine. Reinstall and secure the console to complete the repair.
Posted on Aug 21, 2010
5 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Kenmore series 80, fills and agiatates, but stops before if drains and spins
This is a common symptom of a defective lid switch. If you try opening and closing the lid and do not hear a distinctive "clicking" sound, your lid switch may need to be replaced. Some lid switches are located on the right-hand side of the lid opening with a small slot. It is activated by a plastic piece called a “lid strike” on the lid itself. Make sure the lid strike is not broken off. This will keep the switch from not working. On some model washers the lid switch is located on the left-hand side, in the rear, mounted under the casing near the lid hinge. It is activated by a rod on the lid hinge. Sometimes the rod can be adjusted if it is not making good contact with the switch. In either case, if the switch is not activated, it will allow the washer to fill and maybe agitate, but will not start the rinse or drain cycles. If you diagnose it and wish to attempt the repair yourself, the switch costs about $35 and is fairly simple to replace if you follow the steps below:
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. I believe your washer has release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. Or, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame. Just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle and close the console.
I hope you find this helpful. If you have any questions please let me know by posting comments. Parts can be found at searspartdirect.com or repairclinic.com.
Posted on Mar 17, 2008
SOURCE: Kenmore Washing Machine
Replace coupling
Posted on May 10, 2008
kachbibi1
  • 979 Answers
SOURCE: kenmore elite washer
Assuming you have a top loader, because a front loader does not have an agitator, the spindle that holds the agitator securely in place has worn down to the poing that it won't turn. They are usually made of rubber and has grooves in it and fits into a the agitator. The grooves are worn out. Replace them from an appliance store and you should be in good shape.
Posted on Feb 24, 2009
SOURCE: Washer fill or drain but does not spin
It's not supposed to spin during water fill and draining, if I understand your post.
Charlie
Posted on Aug 23, 2009
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
How does the soak cycle work. Does it start at the end of the wash cycle, or does it drain the soap and soak in clear water
typically on the soak cycle it will fill with water..pause and soak then at the designated time it will advance into the regular agaitate/spin cycle
Aug 26, 2011 | Fisher and Paykel GWL11 Top Load Washer
Charlie
Aug 23, 2009 | Kenmore 44102 Front Load Washer
Have whirlpool LSR7233B top load washer. It fills and agaites but will not drain all the way and spins slowly on slowly on spin cycle
THE BELT THAT DRIVES THE DRUM MIGHT BE WORN, THE BELT IS NOT UNDER A LOT OF STRAIN WHEN WASHING AND MAY WORK FINE BUT WHEN IT GOES INTO THE SPIN CYCLE THE WEIGHT OF THE CLOTHES AND THE WATER WILL CAUSE THE BELT TO SLIP . I WOULD START THERE FIRST
Aug 23, 2009 | Whirlpool Washing Machines
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
Kenmore elite washer
Feb 24, 2009 | Kenmore Elite 45986 Front Load Washer
I hear noise but the drum will not spin in spin cycle.
when you spin it by hand dose it feel free or restricted? if rstricted you may have a peice of clothing between the two tubs.if free you can have a worn clutch.but it would agaitate fine.if wont agaitate or spin it may be your drive coupler.and if the drive coupler failed your washer will still drain.if you need more help you can email me thru FixYa God bless ,tom
Jan 30, 2009 | Kenmore 24032\24036 Top Load Washer
Unit filled, but now will not operate
so it dosent make any noise?your lid switch will stop it from draining and spinning but it will agaite on most kenmore waskers.if i came to repair that would be my starting point
Jan 01, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
423 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
