Question about Sport & Outdoor - Others
Briggs/stratton 6.0hrp 22 in. cut model 917.385351 serial 092906m042891push mower. when pullig to start itwill not start. i replaced the spark plug and it still donot start any suggestions?
kel1guy2002
  • 3740 Answers
SOURCE: wiring for Briggs & stratton
Check out this Briggs and Stratton manual and see if it helps you sort things out:
http://www.mymowerparts.com/pdf/Briggs%20&%20Stratton%20Service%20and%20Repair%20Manuals%20Spec%20Charts/alternator_replacement%20with%20wiring%20diagrhams.pdf
Usually alternator wires are red and black. They also have an AC output that goes to a rectifier to make DC.
This is the standard B&S ignition:
http://www.mymowerparts.com/pdf/Briggs%20&%20Stratton%20Service%20and%20Repair%20Manuals%20Spec%20Charts/ignition_wiring%20basic%20wiring%20diagram%20BRIGGS%20&%20STRATTON.pdf
White wires can be for headlights or ignition kill. WHITE / Light wires usually come from the battery positive post.
Thanks for Choosing FixYa,
Kelly
Posted on Oct 09, 2010
  • 811 Answers
SOURCE: m 303447 type 1093-a2 code
  • Locate your lawn mower's ignition coil by opening the lawn mower's hood or removing the engine cover and locating the spark plug. Pull the spark plug wire off of the spark plug and follow the wire to the component mounted just below the motor's flywheel. This is the ignition coil.
  • Use a pair of needle-nose pliers to gently pull off the small "kill" wire that is attached to the ignition coil. This wire stops the motor by grounding out the ignition coil. Unbolt the ignition coil from the motor using a screwdriver or socket wrench, and pull the coil away from the motor.
  • Install the new ignition coil by loosely bolting it into place. Attach the "kill" wire to the coil and plug the spark plug wire onto the spark plug.
  • Insert a business card into the gap between the ignition coil and spark plug. Tighten the ignition coil's mounting bolts and spin the flywheel by hand. The business card should move along with the flywheel as it turns. If the card binds or prevents the flywheel from spinning freely, loosen the ignition coil bolts and reposition the coil slightly before testing again.
  • Lower the mower's hood or replace the motor cover.
  • Posted on Feb 11, 2011
    HansPP
    • 2510 Answers
    SOURCE: turned poulan pro 42 inch
    Check the valve clearances and especially the inlet valve to make sure that it is not riding (staying slightly open) B&S are notorious for valve problems as most of their motors do not have a valve adjustment on them, the valves stems have to be filed/ground down to get a clearance. Somewhere between 0.010 to 0.015" is near enough for the inlets and about 0.005" more for the exhaust. It is not critical.
    Posted on Mar 07, 2011
    KAComstock
    • 274 Answers
    SOURCE: briggs and stratton 5.0 hp
    It is not getting enough fuel. Check the lines, carb, and filter.
    Posted on Apr 25, 2011
    swefix
    • 21 Answers
    SOURCE: I HAVE A POULAN WALK
    YORE WELCOME http://www.briggsandstratton.com/engines/shop/parts-and-accessories/illustrated-parts-lists/?modelnumber=125k02-0457-E1
    Posted on Aug 05, 2011
    Not getting any spark
    Clean the Plug and replace the Seafoam gas with fresh. Althiough the Seafoam is a cleaning agent, it cuts back on the gasolines octane and it can slightly foul plugs.
    Aug 07, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
    Lawn mower won't start
    to check for firing remove the spark plug insert it in the plug boot and pull the rope while watching to see if the plug sparks be carefull not to touch the plug electrode while pulling the rope or it will shock you. If you don't have a spark, try a different plug. If still no spark the coil could be bad.
    Jun 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
    Oil appearing at exhaust, smokey, briggs and stratton lawm mower.
    You will need to replace or clean the air filter, and probably the spark plug. Do not operate the mower for some hours to allow the oil drain (inside the engine). Check oil level and fill it if necessary. Some oil remaining in the exhaust should be burnt next time the lawnmower operates.You will see smoke at the beginning, that will be normal (burnt oil). Hope this helps!
    May 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
    Not firing
    After you check the key and key way,Check the coil wire to see if it has any breaks in it,If no breaks are present,Replace the coil.
    Jun 02, 2009 | Briggs & Stratton Briggs Stratton Intek V...
    Replacement part for Craftsman 650 Briggs & Stratton 22" multi cut mower Model #917.376741
    You first need to locate the model number on the mower, not the Briggs engine. Then go to searspartsdirect.com and enter your model number on the right side of the web page. This will take you to a list of parts for your mower. Your model number should be located on the deck of the mower (you didn't say if it was a rider or a push). Rider model numbers are located on the rear of the body behind, on or under the seat. Push model numbers are found on the back of the deck between where the handles attach to the frame.
    May 25, 2009 | Craftsman Garden
    Need a spark plug size for a yardpro self propelled lawn mower model number yp6y22cha briggs and stratton 6hp
    If your mower does not have "OHV", overhead valves. You can use a Champion j19lm spark plug.
    If you discover you do have overhead valves; A Champion RC12YC, will work.
    Apr 28, 2009 | Mtd 22" Yard Machine Push Mower
    Sport & Outdoor - Others Logo
    91 people viewed this question
    Top Sport & Outdoor - Others Experts
    Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
