Westinghouse lcd 32 says no input signal for cable how do I fix
SOURCE: Westinghouse 32" LCD - Vertical Line across top of picture
I'm having horizontal lines appearing on the top of the screen. At first there were 3. Now there are 5. When playing DVD's, tehre are about 10. No help from Westinghouse since I've owned it for 2 years.
would love any help or insight.
Posted on Feb 23, 2008
  • 14 Answers
SOURCE: connect home theatre to 32" lcd to ps3
Depending on the year of your model of VIZIO your digital optical output may be tied to the DTV input only. Meaning the only time you will have audio coming out of the digital optical output is when your using the tuner and your on a digital channel. If your television is newer and the digital optical output is in white on the back of the television than it is tied to HDMI and the DTV Tuner and you will pass audio through the digital optical output when using HDMI or the Digital Tuner.
Now to get connect the HT: Normally you would run a digital optical cable from the source device to the home theatre system. Meaning if it was a PS3 you would run a optical cable from the Digital Out on the back of the PS3 to the Digital In on the Home Theatre receiver. If it was a DVD player than you would run the optical cable from the DVD player to the HT receiver. If you have a newer VIZIO and the optical output is in white and not black than you can run HDMI from the PS3 to the VIZIO and then run a optical cable from the VIZIO to the Home theater receiver.
You will have to adjust the audio setting in the PS3 to run audio out of the HDMI port if it is set to run audio out of the Digital Out or AV out. Also, if your going to run audio from the PS3 to the HT receiver through the Digital Out then you need to change the audio setting in the PS3 to Digital Out.
1. Select (Sound Settings) under (Settings) in the home menu.
2. Select [Audio Output Settings].
3. Select the input connector on the audio device.
Channel numbers and audio formats that are supported vary depending on the connector in use. AV is 2 ch. only, Digital Out is 2 ch. & 5.1 ch, and HDMI is upto 7.1.
Posted on Apr 05, 2009
SOURCE: can't progam my direct tv remote to operate my westinghouse 32''tv
I don't have DTV anymore, so I don't remember the exact code I used for my SK-32H240S, However, I do remember that I found one that worked at this site. Scroll down to locate your remote series # - it most likely will be printed on the upper left corner of the front of the remote - as an example, mine says RC64. Click on the corresponding listing, then follow the directions on the site. I tried only a few codes before finding one that worked correctly. Good luck.
Posted on May 08, 2009
SOURCE: Westinghouse SK32H240S 32'' LCDHDTV Picture appears and Disappears
This problem is caused from a problem with the main board. The main board will need to be replaced. It runs from $100.00 to $150.00.
Posted on Jun 10, 2009
dave1645
  • 834 Answers
SOURCE: my 32 inch westinghouse lcd tv's screen turned pink when on
your T-con board is failing you need a tech to replace it about a 150 dollar job
Posted on Nov 18, 2009
What do I do to get my signal back on my westinghouse TV that is hooked up to dish cable
If no signal via the cable fitting try hooking set via one of the sets of jacks on the back (audio/video or component) to see if coax input or tuner is bad.
If the set works with a DVD etc hooked to one of those inputs and your cable is good--maybe a bad tuner in the set---also if using a box try hooking cable direct to set to rule out the box.
Mar 17, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Sound but the screen on my westinghouse 32 inch flat screen is solid lime green
By "sound but the screen on my westinghouse 32 inch flat screen is solid lime green" Do you mean that you have sound but the screen is green? If yes it means that an analog signal is being fed to a digital input. Did you recently change the input cables at the back from one port to another? If not then please describe what are colors of the cabels you are using(Yellow, Red, White or Red Blue Gren etc.,) and what port they are connected to so that I can tell you whether its a problem with the connections or the tv itself.
Jun 15, 2011 | Westinghouse 32" Flat Panel LCD HDTV
No hdmi signal
Make sure that your cable is fully connected at both ends. If it is, then try using a different cable. If neither of those fixes the issue, then your HDMI input may be open/shorted/fried and will need repairing.
Jun 03, 2010 | Westinghouse LTV32W6HD 32 in. LCD...
I have a westinghouse 42" VK-42F240S tv. No input signal. I have reset factory setting, changed cables, and boxes. Any suggestions?
Normally it depends on what connection you are using to output a signal, all of the inputs on this unit are in one single board. What you need to do is to replace the main board because it sounds like your inputs migh have gone out. To check price and availability on the main board you can contact Westinghouse parts department at parts@wde.com, please make sure to include the model # along with serial # and TW# all loacted on the back of the unit. Hope this information was helpfull.
Jan 21, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse LTV32W6HD. Turned it on and video is
If the picture goes bad after about 15~30 minutes, then more likely to be bad LCD controller bd. See sample of the failed LTV-32W3HD here: http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Parts: http://www.shopjimmy.com/catalogsearch/result/index/?q=LTV-32W6HD&limit=200
You can try running the TV with the back open with a small fan blowing in the back to keep it cool just to verify that it is heat related.
Jan 05, 2010 | Westinghouse LTV32W6HD 32 in. LCD...
Westinghouse 32'' LCD TV Static
while you have warranty on the parts you should be getting it to a servicer to get it corrected
do not wait on doing this its not a hazard but it could be a signal board and that could be 300 or better for that part alone so you want to get something done straight away
Oct 27, 2009 | Televison & Video
No input signal
timberline did you reset the tv to factory setting this may solve the problem
Dec 26, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Green screen on Westinghouse tv LTV 32w6
green screen on hdmi is normally a defective hdmi cable. 1st try a different device , like a dvd player. if same problem try dif cable. if it still does not work you have a defective signal pcb otherwise known as a main pcb.
May 22, 2008 | Memorex MLT3221 32 in. LCD TV
Televison & Video Logo
341 people viewed this question
Top Televison & Video Experts
Electro Med Services...
