Question about Microsoft Windows XP Professional
During installation of Win XP a fatal error occurs stating "an erros has been encountered that prevents the setup from continuing. One of the component of Windows needs to continue setup could not be installed." the parameter is incorrect.
    Sergeant:
  • 201 Answers
You need to ensure your hard drive is fully formated be for a fresh installation of xp windows as the corruption could be on the hard drive itself.hope this helps.
Posted on Aug 22, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 103 Answers
This is because of the Bad CD or Corrupted file. You need to use a different XP CD to proceed with the installation
Posted on Aug 21, 2010
I have XP with Service pack 2. On startup I have been getting warnings on OX0000007F. Now the computer won't start. It gets the Windows XP page with the bar in it and then goes to "setup...
The issue is some of the WinXP components are not getting loaded.
Solution
When computer starts, press F8, chose option Start in Safe Mode
let the PC come to the Desktop screen
then when stable, shut down and restart.....
if the solution above does not work then you may have to re-install WinXP again. you need to use a WinXP CD and do a Repair of Windows when the install feature askes for it....
all the best
Nov 24, 2010 | Computers & Internet
Setup did not find any hard disk drives installed in your computer. Make sure any hard disk drives are powered on and properly connected to your computer, and that any disk-related hardware configuration...
you didn't post the make and model of the system, but on most modern systems, this error occurs when the Hard Drive Controller for the system doesn't have a native driver on the Windows install CD. So you need to load the driver during the install. In XP this is done via a Floppy Diskette (XP setup will not recognise a USB Drive) Vista you can install from just about any drive (USB Flash drive generally easiest)
Mar 19, 2010 | Computers & Internet
Installation failure Error Situation Code 11612095
formet the hdd and install the win xp and after install the HP J4680 driver in pc and ....check
Jul 15, 2009 | HP J4680 Office Jet All-In-One Printer
Reinstalled Windows xp professional to my acer aspire 3610
1.change another Installation CD of Windows XP service pack 2 or install Windows Vista.
2. if any track of your CD is corrupted, then this type of error comes.
3. sometime if your hard is not formated correctly, then also some fatal error comes.
4. when formating always do full format, donot do quick format.
Jun 23, 2009 | Acer Aspire 3610 Notebook
Windows XP SP2 Repair
Solution: Rename the C:\WINDOWS\SYSTEM32\CATROOT2 folder to something such as catold to prevent WinXP's Setup program from locating the folder and halting the installation. If you are still in Setup, press SHIFT-F10 to launch a command prompt from within Setup. At the command prompt, type cd\win dows\System32 to open the System32 folder and then type rename CATROOT2 catold, press ENTER, restart the computer, and attempt the upgrade again.
If you cannot reach a command prompt from Setup, reboot the computer from a Win95, Win98, or WinMe startup disk and rename the folder from the command prompt. You can also launch a command prompt by booting from the WinXP installation CD and running the Recovery Console.
Mar 25, 2009 | Toshiba Satellite 5105-S501 Notebook
Windows setup fatal error
This can be caused by errors on the CD-ROM media, or by a bad CD-ROM drive. Try using a different CD-ROM drive if you have one.
Mar 11, 2009 | Microsoft Windows XP Professional SP2
Problem installing windows XP
This is going to be either a bad disc or a bad hard drive. Do a hard drive test in the bios, if any part of it fails, then you will need to replace the hard drive. If the hard drive passes, then try a different operating system disc.
Aug 13, 2008 | Dell Inspiron XPS M140 Notebook
Fatal error installing HP 3055 all in one
Try download he right software for your OS from HP.com, typically software issue. Be sure to choose the right language for your full software solution, get fatal error when trying to install software with wrong language support.
Aug 02, 2008 | HP LaserJet 3050 All-In-One Printer
Editing text
Windows
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
Macintosh
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Jun 13, 2008 | HP 4570C Flatbed Scanner
Microsoft Windows XP Professional Logo
54 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
