Question about Dolphin Maytronics Advantage
I have a dolphin wave with a 4 prong plug that goes into the caddie there are 3 wires red,white and black the prongs are numbered 1 2 3 4 I cant find anything that tells me what wire goes to what prong
    President:
  • Dolphin Master
  • 1,378 Answers
4 is actually not 4 but a symbol for ground. The red wire goes there, the white to 2 and the black to 3. Nothing is in the one hole.
John
Posted on Aug 27, 2010
I need to change my 3 prong to a 4 prong
Unplug the dryer then remove the terminal block cover and disconnect the 3-prong cord from the dryer. Note that the cord has red , black, and white wires but sometimes the red and black wires are both replaced by same color wire, usually gray and can switch places. There's also a ground strap wire also connected to the center terminal together with the white (neutral) wire.
Get yourself a 4-prong cord and note that it has red, black, white, and green/yellow wires but sometimes, like the 3-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect the 3 wires in the same manner they are connected as 3-prong cord to the terminal block. The ground strap wire now just need to be connected to the remaining 4th wire, the green/yellow wire instead of the center terminal together with the white (neutral) wire. Reinstall the terminal block cover and it's done.
It can be observed that converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4 whereas, on the other hand, converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3.. The links below might enlighten you further on this matter.
Four-prong to Three-prong Electric Dryer Conversion
Three-prong to Four-prong Electric Dryer Conversion
Aug 21, 2011 | Kenmore Dryers
I have a four prong clothes dryer plug that needs to go in a three prong outlet - 220v. Any ideas?
It's either you convert the 3-prong outlet to 4-prong or the 4-prong cord to 3-prong. But the latter is easier and more feasible. Unplug the dryer then disconnect the 4-prong cord from the dryer. Note that it has red, black, white, and green/yellow wires but sometimes the red and black wires are both replaced by same color wire, usually gray. The red and black wires are lines L1 and L2 reversibly, meaning they can switch places, while the white and green/yellow wires are the neutral line and ground, respectively.
Get yourself a 3-prong cord and note that it has red , black, and white wires but sometimes, like the 4-pronged one, the red and black wires are both replaced by same color wire, usually gray and can also switch places. All you have to do now is connect these 3 wires in the same manner they are connected as 4-prong cord to the terminal block. The wire strapped to the dryer cabinet and connected to the green/yellow wire of the 4-prong cord wire is now left hanging. The last step is to connect this hanging strap wire to the same terminal on the terminal block (center) where the white wire (neutral) is connected and it's done.
It can be observed that converting a 4-prong cord to 3-prong cord is merely joining the neutral line (white) and the ground (green/yellow) thereby reducing the number of prongs from 4 to 3. On the other hand, converting a 3-prong cord to 4-prong cord is merely splitting the neutral line and the ground thereby increasing the number of prongs from 3 to 4. The link below might enlighten you further on this matter.
Electric Dryer Prong Conversion
Aug 20, 2011 | Maytag Dryers
I have a FEQ1442es dryer. I need to change it from a 4 pronged plug to a three prong, as that is what outlet my condo has... Is there any special order etc. in which to attatch the connections on the...
The 4-prong plug has red, black, white, and green/yellow wires while the 3-prong plug has red, black, and white wires. The only difference is the green/yellow (ground) wire of the 4-prong plug which is attached to the dryer cabinet. All you have to do is connect the wires of the 3-prong plug in the same way the same wire colors are connected with the 4-prong plug then connect the terminal on the cabinet, where the green/yellow (ground) wire of the 4-prong plug is formerly connected, to the white wire of the 3-prong plug.
Feb 12, 2011 | Frigidaire FEQ1442ES Electric Dryer
Can you take a dryer that has a 4 prog plug and put a 3 prong plug on it?
Yes, you can put a 3-prong plug in place of the 4-prong plug.
Feb 04, 2011 | Maytag Dryers
Dolphin Dynamic pool cleaner-when turning around it locks up?
My 4 prong ( numbers 1 2 3 4) with 3 wires red black and white got pulled out and i cant find anything that tells me how to match what color to what number
May 24, 2010 | Dolphin Maytronics Advantage
Dryer cord
Your four prong cord has 4 wires. Black,Red,Green and White.
Remove the 3 prong cord from the dryer.
The Black and Red wires go to the outside terminals on the dryer. The White wire goes top the center terminal. The Green wire goes outside the terminal cover to any nearby screw for grounding.
Jan 03, 2010 | Roper REX4634KQ Electric Dryer
I have a 3-prong plug on a 14-year-old dryer. Now must change to 4-plug. Is that possible ... and if so, how?
A three Prong contains L1 (Line1), L2 (Line2) and N (Neutral). A four prong will contain L1 (Line1), L2 (Line2), N (Neutral) and G (Ground) typically a green wire.
Connect the three wires as normal, connect the green wire to the screw provided on the cabinet.
Jul 04, 2008 | Dryers
I am trying tochange my
This is common issue. Due to some building codes the 3-prong configuration is no longer used in homes. The wiring is similar with one exception. The 4-wire plug uses an additional (WHITE) NEUTRAL wire.
Here's a brief explanation of how the plugs are configured:
Dryer 3 prong wire configuration:
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
Dryer 4 prong wire configuration:
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
WHITE - NEUTRAL
BOTH plugs provide the SAME source voltages to your appliance:
220 VAC - provided across the RED and BLACK leads are what drives your heating circuitry.
120 VAC - usually tapped of the BLACK wire is used to run the drive motor and timer on MOST dryers.
The wire terminal block in the back of the dryer should have a black, white, and red wire running to it from the dryer wiring harness. With the 4 prong plug, simply attach the BLACK, WHITE and RED wires at the terminal block ensuring that you match the RED and BLACK wires as they are configured and attach the WHITE wire at the remaining terminal lug. Make sure you screw them all down securely. Attach the remaining GREEN wire to chassis (dryer frame) ground. I hope this helps you.
Feb 29, 2008 | Dryers
REPLACING DRYER 4 PRONG PLUG
This is common issue. Due to some building codes the 3-prong configuration is no longer used in homes. The wiring is similiar with one exception. The 4-wire plug uses an additonal (WHITE) NEUTRAL wire.
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
WHITE - NEUTRAL
The wire terminal block in the back of the dryer should have a black, white, and red wire running to it from the dryer wiring harness. With the 4 prong plug, simply attach the BLACK, WHITE and RED wires at the terminal block ensuring that you match the RED and BLACK wires as they are configured and attach the WHITE wire at the remaining terminal lug. Make sure you screw them all down securely. Attach the remaining GREEN wire to chassis (dryer frame) ground. I hope ths helps you.
Feb 14, 2008 | Dryers
Dolphin Maytronics  Advantage Logo
137 people viewed this question
Top Dolphin Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Are you a Dolphin Pool and Spa Expert? Answer questions, earn points and help others
