Question about Maytag Neptune MDE7500AY Electric Dryer
I have a Maytag MDE7500 dryer that the timer won't cycle. The dryer just runs and runs and cooks the clothes. I replaced the timer but it still dose the same thing. Any suggestions ?
  • 10,319 Answers
The timer relay is shot whichs turn the timer off
Posted on Aug 21, 2010
Maytag quiet series 200 dryer, runs.dries cloths,but timer does not move to time out through its cycles,like cool down and complete or finished.?
It sound like a bad timer motor.check with a local parts store for the replacement part and remove the screws from the top rear housing and you will see how to replace it
Feb 28, 2015 | Maytag Dryers
Maytag Dryer
HI,
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Aug 28, 2008 | Dryers
Not catching lint or drying clothes
Hi Diane
Sounds like you have a clogged vent
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
Bud
Oct 12, 2013 | Maytag Dryers
Electric Dryer starts and runs but won't heat.
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag Neptune MDE4000 Electric Dryer
I have a Maytag Legacy Electric Dryer Model MED5570tq0. It turns, gets heat, but does not dry the clothes. It would take 2-3 cycles to dry clothes. Any suggestions?
Hi jamesholl456...
Sounds like you have a Clogged Vent
Heating Element
Cycling thermostat
This is a Free answer, Please rate me.
Apr 20, 2011 | Maytag MED5770TQ Electric Commercial Dryer
My maytag neptune dryer is taking twice as long to dry cloths. i've had it 5 years & it's gas.
Clogged Vent
Cycling thermostat
This is a free answer, Please rate me.
Oct 05, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer won't shut off automatically
Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Thank you!
May 09, 2010 | Maytag MED5800TW Electric Dryer
Dryer not turning off when clothes are dry (model LDE 400ACL)
Normally if you have an automatic cycle that turns off the dryer when the clothes are dry, it will do it with a special thermostat or moisture-sensing system. The thermostat tells the dryer to heat until the interior of the dryer reaches a "pre-set" temperature.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. If there is a moisture sensor, the timer advances only if the moisture content of the clothing is low enough. The timer advances until the interior cools, then the termostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But... if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix this problem, clean the vent and/or internal ductwork and make sure the vent is not compressed or kinked. If that doesn't work, then your thermostat, moisture sensor or timer could be the culprit.
Jul 15, 2009 | Dryers
Maytag atlantis dryer model # mde6400ayw
sounds like the timer is not completing the cycle in this mode will the dryer shut off if you manuelly advance timer in that mode
Oct 21, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Neptune MDE7500AY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
