Question about Sony SLV-779HF VHS VCR
Cannot set channel 3 on sony slv-779hf. Channel starts from 4
3 Suggested Answers
jdrrwoods
  • 82 Answers
SOURCE: Sony SLV-798 HF VCR
on alot of vcrs if you already have a set time for one channel to record at a later time if you dant set the earliest first it wont let you change it but im not sure if you already have one set ahead of time or not
Posted on Feb 09, 2008
najah
  • 180 Answers
SOURCE: Sony SLV-778HF won't change the channels for
You have to tune all the chanels first, then only chanel will change.
Posted on Jun 12, 2009
How do i set up my tv with my sony vcr
Hi Katie.. If you are using a coaxial cable to connect your TV and VCR, the TV needs to be tuned to channel 3 or 4. If you are using the Yellow, red and white cables, your TV should be on video mode to work.
Sep 14, 2015 | Toshiba 24AF42 24" TV
Have Sony VCR model SLV-N80/N70 . Cannot get it to record using Samsung TV model SLV-N80,N70.
The television has nothing to do with recording. It is only required for playback. There are a number of possibilities depending on what equipment you have. Do you have cable, satellite, antenna? Your signal source has to be connected to the VCR either through the cable connector, or RCA video jacks.
If you have straight cable, connect the cable to the "ant in" connector on the VCR. The VCRs tuner will select the channel you want to record. If you are on antenna, you will need a Digital set top box (STB) to receive any channels.
If you have a satellite, cable box or digital STB, you must go from the output of the box to the input of the VCR. You can use the standard coax cable,but I would recommend using the audio/video cables for better quality. If using coax, the VCR will have to be set to either channel 3 or 4, depending on the boxes output setting. Using A/V jacks, the VCR will be set to "Line" or "Video" input.
Feb 26, 2011 | Sony SLV-N70 VHS VCR
Want to record a television program on a channel higher than 16.
there must be a setup feature on the sony for channels that you get in your area?
Dec 18, 2009 | Sony SLV-D370P DVD Player/VCR
Sony SLV-D360P DVD Player/Video Cassette Recorder
make sure the tv is on channel 3. i had the same problem and it fixed by going to channel 3.
Jun 29, 2008 | Televison & Video
Sony SLV-798 HF VCR
Feb 09, 2008 | Televison & Video
Intermittent tuner operation
have you tried to move the switch to channel 4 on the back of the vcr ( you will have to watch the vcr on channel 4)
Jan 28, 2008 | Sony SLV-998HF VHS VCR
Recording
First make sure you are hooked up in back. You can go either way. Cable out to tv, Cable or RF in from antenna should be from what you are using like cable, satellite, or just antenna. Then you should have set put on channel 3 or 4 and you can switch that in back of VCR also. Then if you don't see picture on screen with vcr on then find channel that you are coming in on like for satellite you need it to be on 3 or 4, cable you can just put it on the channel you want to record. The other way are from Video Jacks the red, white, yellow. If this is the way you are hooked in then you should look for video 1, 2 or which ever you are hooked into and find on set. then look on vcr for video or aux 1, 2 or depending on the one you are hooked in to. Hope this helps. If not then tell what you are using and what you have done so far!
Aug 16, 2007 | Sony SLV-998HF VHS VCR
Sony SLV-779HF VHS VCR Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
