Question about Kenmore Dishwashers
Hello! I have a Kenmore Dishwasher Model # 665.15805890. The dishwasher came with the house and I'm guessing it is around 10 years old. My toddler was having a great time flipping the door to the soap dispenser back and forth until he pulled the door off of the pin. Now, I can't seem to position the spring in a way so that the door will spring back. I never looked closely at the hinge before, so I don't know if that is the only reason the door will not release the detergent, or if something else is also wrong. Because the soap isn't released at the right time, my dishes aren't coming out clean. Can you help me? Thanks, Karen
  • karenozley Aug 21, 2010
    Yes, the diagram shows the spring, but not how it is positioned for use. Do you have any other suggestions?
  • Kenmore Master
  • 19,396 Answers
Hi.
Please see if the diagram here can help you.
Check if the spring is that indicated with nr ten in diagram.
Posted on Aug 21, 2010
  • Ginko
    Ginko Aug 21, 2010
    The spring is positioned inside the little dispenser door panel (pt 9 in picture), it works as a flipper leaning on the panel dowel pin(prt11). The two ends enter into two holes, the square sized part is in contact with the door panel to push it out. Check the dowel pin, if it is loose, then that goes inside the spring, otherwise on top.
Dishwasher will not start. All option buttons light up except the Start/Stop button and the cancel button. I have turn the power off and on but still no wash cycle. Inside float is clear and so is spray...
Hello, I am sorry that your dish washer isn't working. One of the biggest problems with these new dishwasher is they install the control on top of the door and the operational circuit board below the control panel. Inside the door is acceptable to moisture which creates all kinds of problems. It not the spray arm or the float, or the pump. it is where they put the circuitry to control the dish washing machine.
I hoping that all you will need is a push button control strip for this dish washer. moisture get in the micro switches and make them inoperable. These button in the control strip are hermetically sealed against moisture....for a while.
Remember, it depends on how long has the dishwasher been working and what will be the cost to repair your dishwasher. Dishwasher are really good for 10 to 12 years of service. I worked on a Kenmore that was 25 years old. I told the lady of the house it is time for a new dishwasher. I could have repaired it, but really it not worth it when it is this old. GB...stewbison
Sep 06, 2011 | Maytag Dishwasher
Older dishwasher is leaving a white film on the glasses. Have checked the water (125 at the sink) cut down on detergent, used "dishwasher cleaner" a couple of times. Any Ideas? It is a Kenmore...
If your model has a JETDRY rinse agent dispenser be sure to use it..if it does not have that dispenser and just only the detergent dispenser use the JETDRY in the dry version that is in a little basket and hangs on the upper rack.
GENE
Aug 31, 2011 | Kenmore 24 in. 15689 Built-in Dishwasher
I have a Kenmore dishwasher, not sure of the model or year (less than 10 years old) but water constantly flows into the dishwasher. So much so that it leaked all over the floor because the bottom filled up...
Hello.
If it's filling all the time when dishwasher is not even running? The water inlet valve that the house water supply connects to at the dishwasher,is sticking open and needs to be replaced..what you can do now to stop it from constantlu filling is turn off water supply to the d/w from under the kitchen sink.
Typically the model number is on a label on the egde of the door inside or on the rim of the tub..it would be needed to order a water valve
Gene
Aug 24, 2011 | Dishwashers
Dishwasher detergent door won't release soap
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
l
Apr 06, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Dishwasher leaks during the wash and rinse cycles from the front
Without knowing the model number of this Sears Kenmore dishwasher, it is difficult to be specific in a solution.
There is a float/switch that controls the amount of water added before each wash or rinse cycle. Replacing that float would be the first step.
Can not be more specific without knowing the model number.
Apr 04, 2009 | Kenmore Dishwashers
My dishwasher
sounds like the fuse on the control blew. you can replace the fuse for around $20 or you can cut and splice the wires for free. If that doesnt work then you may have a loose conection in your junction box under the dishwasher.
Nov 27, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
DISHWASHER NOISE
A noise could be created by something getting down into the motor-pump assembly piece of glass, piece of bone, wire tie anything really. If this is the case and you can remove it before it causes further damage problem solved. At ten years old the problem may be the motor and or pump one thing to consider before putting money into it is disheashers average 7-10 years these days. Good Luck.
Jun 02, 2008 | Hotpoint 24 in. HDA3400G Built-in...
Leaking door (Running Water)
being in the uk i dont know this appliance, but the fault is probably that it is overfilling caused by crap in the airchamber or the hose leading to the pressure stat blocked or a split in this hose
Apr 15, 2007 | GE 24 in. GSD4630Z Built-in Dishwasher
Dishwashers Logo
54 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
