Question about Pool & Spa
How to install a titanium no-heater to jetsetter tub
  • 2 more comments
  • hammond_nick Aug 21, 2010
    shouls read no-fault heater
  • hammond_nick Aug 23, 2010
    how to fit a titanium No-fault heater to a jetsetter spa
    jet setter 2002...J O3 3B1054
    HEATER 6000
  • hammond_nick Aug 24, 2010
    watkins no fault 6000
    no heat
    pump is working
    ready light on display unit not working
  • 19,396 Answers
Hi.
I could not track " titanium no-heater" as device. Can you please give us make and model of the unit.
Exact info on tube model would also help.
Posted on Aug 23, 2010
  • 2,272 Answers
What is the exact model number of Jet-setter tub and the Titanium no-fault hear.Because there are various types of jet setters and titanium no-fault heaters.And has different different fittings.So the exact model number will help. Please keep updated.Thanks.
  • 857 Answers
Http://www.hottubsbarn.co.uk/hot-tubs/hotspring/jetsetter-hot-tub-installation.asp
Please go through the link Above for the installation instruction.
Posted on Aug 22, 2010
New replacement in-line heater (C3B54P0-3002AU0) inop.
Bath tub heaters will only maintain the water temperature in the bath. They will only heat the water approximately 1-2 degrees an hour.
Whatever water temperature you start with is what you will be able to maintain.
There is a red indicator light on the front of each heater indicating whether or not there is power to the unit when the tub is full of water and the water pump is turned on.
If there is a red light on then it has power to it and is working.
This heater will never feel warm to the touch.
There are three different styles of Bath Heaters available.
  • Tee Heater - installs on the discharge fitting on the pump
  • In-line Pressure - installs anywhere in the plumbing line before any jet.
  • In-line Vacuum Heater - installs before the suction of the pump
If the heater you purchased is installed in the wrong place it will not operate.
Rod
US Parts Center
Dec 04, 2013 | Maax Calla 6042 Bathtub - 101058-000
Heater
Water heater can be added to any incoming water line, either on hot or cold.
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Under-counter water heater located near tub will supply hot water just like ordinary household water heater. But it will not reheat water that circulates inside the spa tub.
Otherwise, a spa heater is made with electric element that can work with 120V or 240V. Water from tub circulates through tank that holds element. Element must be fully immersed in water.
To retrofit spa tub with this heater would require cutting water line near pump, running both ends of water line into tank with element.
Then of course you would need to retrofit adjustable thermostat to control when element is on. And integrate element operation into air control switch at tub that can override thermostat so element is not heating when tub is not in use.
Unless there is a pre-packaged kit to retrofit heater, I think adding heater would be difficult.
Jun 05, 2013 | Maax Crescendo - 100085-000 Bathtub
H400 manual h400ped2
I have a 2005 Hayward H400PED2, I want to know if it's a titanium exchanger beause I want to add a salt system?
Thanks
May 08, 2013 | Hayward H Series Pool & Spa Heater 400k...
MY JACUZZI DOESN'T SEEM TO HAVE ANY PLACE TO PUT A HEATER AND IT IS TOO COLD HERE TO USE IT VERY MUCH. IT IS AN OLDER MODEL. IS THERE A HEATER THAT WE COULD USE TO PUT HEAT IN OUR JACUZZI. AM I MISSING...
In line heaters will not HEAT the water, they will only maintain the temperature inside the tub within a few degrees. You should not try to install the heater yourself, it would be best to have a plumber come over and give you a quote on how much it would be to install it. A plumber can look at the tub, see if there is a place that the heater can be CUT IN to the pipes, and install it. You likely won't get it to work. The inline heaters are required to be put on a GFCI circuit because they are powered in a wet environment. Unless your tub is not hardwired in to the house, and you actually have a GFCI circuit under the tub. But like I said, these do not heat the tub, they only maintain. And the life of these is not very long if you use soaps and shampoos in the tub while the heater is on. It won't take any time at all for the oils to build up on the elements, rendering it useless.
Apr 28, 2011 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Hello, a few months ago I installed a jacuzzi tub with a Rapid Heat heater. I'd like to clean the tub either by the bleach/detergent method or the granule cleaning packet method. My question is should I...
Any recommended (see the tub instructions) cleaning product should be fine in the heater -- and the higher temperature of the "cleaning solution" should enhance the process. Just be sure to flush the tub's entire system with clean water before you bathe in it again!
Dec 01, 2017 | Jacuzzi S750000 Black RapidHeat In Line...
I just installed a new whirlpool jacuzzi tub with an Eljer inline heater. The pump in the tub is shooting water out all the jets I even blew the jets out with air to make sure they were clear. The first...
if the light on the heater is not coming on when the tub is full of water and the pump is on then the heater is not working.
check the circuit breaker to make sure it is on.
the heater and the pump cannot be on the same circuit. They have to be on separate circuits.
Make sure they are on separate circuits.
Check to make sure you have the heater installed in the correct place.
there is a pressure heater that mounts anywhere after the discharge of the pump.
there is a vacuum heater that mounts in front of the pump in the suction line.
if you put on or the other in the wrong place it will never come on.
Jan 17, 2011 | Whirlpool Home
I have a new Jacuzzi tub with a Rapid In-Line Heater. When I fill the tub the water the initial temp is 67 degrees. The heater only increases the temp to 71 degrees. What is wrong with the heater ,if...
The bath heater you have is not designed to HEAT water - they only Maintain what you start with.
You need to start the bathtub with the hot water you want. It will only heat about 1-2 degrees an hour.
Jan 08, 2011 | Jacuzzi RapidHeat In-Line Heater U395000 [...
I have an air tub with and aquaflo tub master pump
probably already solved this but yes, you can put a heater on any bathtub that has water jets.
Feb 02, 2010 | Aqua Flo Aquaflo Tub - Master Tmcp 3/4 Hp...
Whirlpool Duet: "remove the heater..."
don't know the whirpool duet cos i'm in uk not us.
i assume your machine is a front loader
places to look for heater are
remove back plate and look for heater at bottom of rear face of tub
sometimes heater is mounted on front plate of tub in which case tilt machine backwards and see if you can see heater mounted towards bottom of front face.
most likely place however is on the rear plate of the tub
Jul 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Pool & Spa Logo
155 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
