Question about Gateway 500GR PC Desktop
TURNING ON PROBLEM
HI WHEN I TURN MY PC ON THE BLUE GATE WAY LIGHT DOESNT COME ON BUT THE FAN COMES ON
AND THE PC DOESNT COME ON I HAVE TO TAP IT PLAY WITH IT THEN DISCCONNECT THE HARD DRIVE AND KEEP PRESSING THE G BUTTON TO TURN IT ON AND DO IT FOR A WHILE THEN IT COMES ON ?? ITS DOING IT FOR THE PAST FEW WEEKS WHAT SHOULD I DO?
  • 2 more comments
  • Anonymous May 19, 2008
    I have the same problem. I've replaced the motherboard and the power supply, but it still doesn't work.
  • keith2598 Nov 30, 2008
    I have the same problem. I changed the memory, but nothing. I cleaned the fan and cpu, but nothing. computer works for a couple of hours then nothing. i think it is overheating. am trying to get a new cpu and fan for system.
  • Anonymous Apr 15, 2009
    same problem but a little different blue light comes on and then goes right back off and then the little orange lights underneath the blue light blink really fast.... any idea what this could be?
  • supremebtchs Apr 26, 2009
    I have the same problem. I turn the computer on and the blue light doesn't come on, only the orange one under the power button. However I can not get the computer to come back on so I can update anything. Anyone have suggestions?
BIOS update. Go to Gateway.com and update your BIOS. Do this very carefully.
Posted on May 13, 2008
Hi! Having some trouble with a friends laptop here. I have it on AC power and the battery is now charged (middle light has changed from amber to blue). So when I push the power button, the top light...
Hi.
Try unplugging AC power lead and then take out the laptops battery, plug the AC power lead back in and try turning it on, see what happens. If the laptop turns on then there is a problem with the battery.
Good luck and let me know how you get on.
Regards.
Jan 29, 2013 | Computers & Internet
I turn it on and the fan begins to spin up, blue power light comes on and then after about 30 seconds it shuts down
hi, probabily the procesor fan does not works , other options is your opering sistem is bad, format and reinstall windows , other option is your hard drive is bad , try with another hard drive
Aug 12, 2010 | eMachines T5224 PC Desktop
Blue power light does not come on when i turn the comp on
there is either a motherboard/cpu issue (worst case), or a power supply issue (best case, cheap and easy fix)...
without being there looking at it i can't really tell you more. if you happen to have a spare ATX power supply, open the machine and plug it in to the system instead of the old one to see what happens.
if you don't have a spare, you obviously have another working computer you're posting from so maybe borrow it's power supply and see what happens.
Jul 30, 2009 | Gateway GT5242E PC Desktop
GT5220 won't turn on
My motherboard was replaced twice by the gateway people. Luckily I bought it at costco and it has a two year warranty through them because gateway didn't want to deal with me until costco techies made them. I have the same model and had the same problem
Jun 24, 2009 | Gateway GT5220 PC Desktop
Fan is running, power button with blue light is off, cpu won't boot up
Your cpu might have died. As the computer is starting tap F8 and choose last known good configuration to see if you can get it started.
Apr 26, 2009 | Gateway 500GR PC Desktop
Computer isnt running
If that is the case your system need to check the battery for fault and does it happen with the power source too i fthe same problem check your processor fan if its bad when you on the system and is not blowing that might have cause the processor itself to get bad you will have to change this ones and then your system will be ok right rate this solution.
Nov 27, 2008 | Toshiba Satellite A205-S4617 Notebook
Turning on
take out the battery
remove the power lead
press and hold the power button about 20 seconds
replace power lead only
try and turn on
if this works - then you can replace your battery as per normal
Aug 13, 2008 | Acer Aspire 3690-2196 Notebook
Cold water only very slowly trickles into the washer. Hot water works fine. Cold water has very good pressure and volume at all other sources in the house. The cold water hose at back of washer is clean...
there can be 3 reasons for this I will tell u the easiest way to test this first
Problem1)turn the water off at the blue tap fitting that is proberbly under your sink take the blue pipe off at the washer end and place it into the sink turn the blue tap back on if the water comes out quick then the problem is more then likely your cold water solenoid that is either slightly blocked were it fits to the washer,But if it doesnt come out quick then the other 2 problems are as follows.
Problem2)the blue tap that u turn the cold water on to the blue pipe undue the little screw in the middle of the tap and pull the blue fitting off now with a pair of pliers turn the square metal fitting that was under the blue fitting making sure that the end of the pipe is in the sink if it comes out quick then that is the problem the blue tap fitting is rounded off when ot should be square turn the water of and replace the pipe and turn the water back on the cold water should be better now.
Problem3)the blue tap that u turn the cold water pipe of at the copper pipe is blocked or it has a broken shut off valve inside it this will need replacing these are the only problems that it could be let me know if this is any help to u peter
Jun 09, 2008 | Whirlpool Washing Machines
Possible PSU problem?
sounds like a bad power supply to me.
Oct 21, 2007 | Gateway GT4016 Desktop PC
Gateway 500GR PC Desktop Logo
168 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
