Question about Kenmore Dryers
Gas dryer cycles are longer than normal with no heat
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Posted on Sep 12, 2010
Gas dryer burner lights then go out after about 20 to 30 seconds then lights again is this normal
normally they dont cycle that often,sounds like a weak cycling or high limit thermostat thats heat sensitive from age,its on the burner housing the cycling switch is on the blower housing
Dec 01, 2012 | Whirlpool WGD5200TQ Gas Dryer
Gas dryer/ has just started taking long time to dry each load needing multible cycles of time. Is generating some heat, vent is clean, trap iis clean. What is keeping the dryer from heating up?
I suspect your gas valve coils are going out and need to be replaced. They can work when first used but later in the cycle one of them quits.
Sep 23, 2011 | Roper RGS7745PQ Dryer
I khave a Kenmore gas dryer 110-90 series. It no longer clicks off when the timer is set. Now, there is no heat coming from the dryer. The drum turns with air drying but no heat from any of the cycles.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 19, 2011 | Dryers
My Hotpoint electric dryer no longer heat or shut down during the drying cycle. What is the possible problem?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 02, 2011 | Dryers
Dryer is no longer heating on any cycles. What is the problem?
heatman101
Dec 10, 2010 | Kenmore Dryers
Dryer making clicking noise when running. Heat no longer working. Gets "stuck" in a cycle continues running and dial not moving.
Based on symptoms, this is a gas dryer. The clicking that you hear is the solenoid opening so that gas can flow and be lit. Except that gas isn't flowing, or the igniter is burned out (if or pilot is blown out if so equipped).
It is normal for the dial not to move unless it is in a timed dry mode (like air or freshen mode) because the moisture level of the clothes is not changing.
Jun 13, 2010 | Kenmore 63942 Dryer
Whirlpool Dryer LGQ9508PW0 flame comes on and shuts off after 30 seconds.
this might actually be normal, whats the complaint??? to long to dry clothes maybe 2-3 cycles??? would be a common complaint. in which id check to make sure vent is not clogged anywhere, especially where exiting the home if he venting is ok id replace the coils atop the gas valve, possible and common for that matter that after running for 20-30 min they do not reopen and dont allow flem to reignite... part number 279834 retails for about $20 easy enough repair.... reason for flame to go on and turn off after only 30 secs is that in an empty dryer 30 secs of heat may be enough to satisfy the thermostat, that's alot of heat for an empty dryer, it would remain on for longer with a load of wet clothes absorbing the heat
Nov 05, 2008 | Whirlpool LGQ9858P Gas Dryer
Dryer will sometimes start to heat, then stops heating altogether.
There are always more parts to replace. From the sounds of it though, it sounds like one of your gas coils are going out. Normal gas dryer opperation is your unit will heat up, cool down, heat up, cool down, etc thorugh the course of the cycle. Usually when one of your coils are going out, it sticks after the 1st, 2nd, or 3rd cycle and the gas will no longer come out. So the cycle will continue just without heat. Another less likely possibility is that you have a restriction in your ventalation causing one of your heat safeties to open and not let the machine heat for most of the cycle. This can generally be checked just by placing your hand under the vent hood outside where your dryer vents to. You should feel air pressure on your hand while the unit is running. If there is not pressure or you are hearinf some whisling noise, it might be restricted in which case you'll need to have your vents cleaned/ repaired. Now since you are going through an extended warranty company, here's a couple other thoughts. They contract companies to provide service to thier customers. Do they have another authorized company in your area that can look at it? Do they have any kind of lemon or excessive repair policy? Many companies will replace a unit after so many repairs in a given time frame.
Jun 25, 2008 | Maytag MDG7757AW Gas Dryer
Dryer runs-no heat
I had a problem once with a gas dryer that would come on, the pilot would glow and the flame would run on a shortend cycle. The coil that opens the gas valve had a short circuit that would only short out when it heated up. It would drive me crazy since it appeared to be working. The short cycle time the first time, and then maybe not at all once it was warm gave me mixed signals.
May 15, 2008 | Dryers
No Heat on Whirlpool Gas Dryer
The timer should advance in the time dry cycles if it does, it is fine Its common for them to not in automatic cycles when there is no heat I would call for service unless you have basic gas appliance knowledge , as it is dangerous If you decide attempt i can tell you what to look for Please rate my help .....Thanks
Oct 02, 2007 | Dryers
Dryers Logo
24 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
