Question about Electrolux AWF1220 Front Load Washer
Smelly cloths and on the fast wash did not rinse well
  • Electrolux Master
  • 17,130 Answers
Use good quality soap power , if possible soak with power prior to wash on such dirty clothes.
Also use the regular wash for a good wash as there will be more rinsing and a long wash cycle.
Hope this tip helps.
Posted on Aug 21, 2010
  • 92 Answers
Change powder or clean your filter and if it continues then call an expert rate : )
  • Electrolux Master
  • 909 Answers
Check the drain pump motor. if partially blocked it will restrict the outlet. Open the thumbwheel and remove the lint. Chech the 2 pipes for any blockages
Why does my whirlpool model WTW57ESVW1 starts to rinse toward the end of the spin cycle?
The rinse is supposed to start during the spin...it's what removes most of the soap from your clothing! The spin forces the water through the clothes, flushing all but a small amount of the detergent away. The rinse cycle itself is more to remove solid debris that may have become trapped in the folds of cloth. It does so by floating and agitating the clothes.
The quick wash cycle is only for things that aren't soiled much, that you need to be done fast. It's not for everyday washing, just for things that maybe need no more than a freshening up. It makes it faster by cutting corners.
Sep 06, 2014 | Washing Machines
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
The clothes come out smelly mouldy and I want to clean it out
Just a suggestion but if you let the water level to the lowest level and then use several gallons of bleech in the water, it should kill any mold that is growing in the unit. And you won't have to take things apart to see if it works.
I would run the bleach solution first, and then run another load with just rags or something and see if there was an improvement or not.
Then do another load (without clothes) with a lot of lemon juice to finish the cleaning process.
Jun 10, 2011 | Maytag Neptune MAH5500B Front Load Washer
Hi, I've got a hotpoint WF000G which wont rinse properly on a fast wash, still soap suds on the clothing and have to put it on a full rinse cycle to get rid of them. Have tried clearing the filter (which...
Use very little detergent (HE) on a fast wash, about half the amount you usually do and set the machine to heavy instead of nomal, if yours has the settings for water level.The heavy setting uses more water. If your model does not have the normal/heavy settings, wash only very small loads on the fast cycle so that there is more water for the cycle. Also, be sure you are rinsing in cold, since cold water dispurses suds. You should also be sure that your rubber seal is very clean. I use a cloth and plain hot water and clean the seal weekly. It can build up alot of detergent residue as well as mold, etc.
Dec 18, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Smelly front loader washing machine. Clothes come out smelly too. How did I fix the problem???
You may have to do this 2 times and you will never find this in any manual. Use 1/4 cup "Powdered" Dishwashing soap and 1 cup of bleach in an empty tub cycle. Run a load of older dark clothes or non flammable rags FIRST after doing this the first time. If they come out with streaks run the cycle of 1/4 cup Powdered dishwashing soap and 1 cup bleach again. Same routine after 2nd cleaning cycle... dark clothes check for anything out of the ordinary. You should not have to do it a 3rd time unless your machine is really gunked up. Hopefully your using HE type soaps in your front loader. Non HE laundry soaps will cause the smelly machine also.
Thanks for using FixYa.
Kelly
Mar 29, 2010 | Washing Machines
SMELLY WASHER
pouring .5 cups of bleach directly into the machine works great for me. I have tried other techniques, but they all failed. (I HIGHLY RECOMMEND WASHING A LOAD OF WHITES AFTER THIS JUST TO BE ON THE SAFE SIDE!)
Dec 06, 2008 | Kenmore Elite 45986 Front Load Washer
Smelly washer
Try Putting Lemons in the washer once you done the washing gets rid of the smelly oder
Jul 19, 2008 | Whirlpool Washing Machines
SMELLY GLASSES
Suggest running a rinse cycle once or twice, if this does not help, try mixing one or two table spoons of baking soda into 500 ml - liter of warm water and wipe down the interior of your dishwasher.
After wiping down, run the rinse cycle again before attempting a normal wash.
Try to avoid washing pans with glassware, as some coatings ( that may be dishwasher safe ) have a tendency to react with the detergent, thus creating an unclean smell on other utensils, plates or glass.
Wash pans on their own, or in a conventional sink.
Jan 12, 2008 | Dishwashers
Electrolux AWF1220 Front Load Washer Logo
94 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
