Cars & Trucks Logo
Posted on Aug 21, 2010
My Mitsubishi Magna, has just had the battery replaced and the car won't start. On instaling the old battery, the battery light shows while the engine is running but the heater, stereo and rear stop lights won't work.
Anonymous
Level 1:
New Friend:
  • Contributor 20 Answers
  • Posted on Aug 21, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
20
Questions
0
Helped
4906
Points
44
Check the wirering and the ECU
My 2000 tj magna sat for 2yrs Replaced with new battery was hard to start...drove 50klms turned off....now all it dose is crank over and wont start
I think you should buy repair manual first for your vehicle after that it will be easy for you to solve the problem. Check the link may be you will find something useful here
Complete Mitsubishi Magna 1998 2001 TH Series 1998 2002 TJ Series Verada...
1helpful
How do i replace starter motor in mitsubishi magna TJ ive located it just need a run down how to do it
There are Magna workshop manuals readily available to show you how to do this work.
Buy one of them.
Where do I find the immobiliser on a 1999 Mitsubishi magna, and if I take the immobiliser out will the car start?
Hi good people, My TE Magna has been suffering the immobiliser no ... NO you can not bypass the immob, a gound or power will NOT give the ECU the correct code from the immob that it requires ... 1992 Mitsubishi magna.
www.ebay.com/motors‎
Find Immobilizer Mitsubishi for less.
eBay - It's where you go to save.
Can you show me how to replace the starter motor of my magna 4 cylinder year model 1988
dont know what the heck the other answers were trying to do fix
T he question was how to remove the starter motor on a 4 cyl magna 1988 mitsubishi .. that makes it a TN or first gen magna
ok TN can be either carby or an EFI setup
disconnect battery
14mm bolts two hold the starter on
undo the battery positive cable on the starter
and the ignition wire on the starter
On an EFI you have to go under the engine and undo the support bracket of the efi inlet manifold to get the starter out
underneath the car
the interim shaft is one of the bolts holding the bracket to the block
on a carby you can do it from the top
from the drivers side
1helpful
I have a Mitsubishi magna 2001 model and I'm having computer problems the battery symbol keeps flashing and it keep stalling and won't idall properly
You need to have the Alternator tested, the battery symbol indicates the system voltage is low. The other problems are due to the low voltage.
Why mitsubishi magna 1994 shows battery sign when running?
Malfunction in the charging system. Have your alternator tested, it's probably bad. Do it soon or your battery won't have enough charge to start the car.
2answers
Stalls when at idle after changing battery
When you changed the battery the computer must re-learn the setting again. If it continues have a OBD II reader plugged in and check for codes.
Car head light not working when engine start.
if both headlights are out, probably blown relay. user manual should show where it is located.
1helpful
Mitsubishi magna sterio wires
first of all you should always use a wire harness when installing a unit into a vehicle you should never cut the factory harness but guess you already did so here is the wire diagram for your car hope this helps http://www.installdr.com/Harnesses/Mitsubishi-Wiring.pdf
Top Mitsubishi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Mitsubishi Expert? Answer questions, earn points and help others
