Question about Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver
I cannot open a Dewalt 954 cordless drill chuck. My socket adapter is stuck in the chuck. It is a borrowed tool and I need to return it in the same shape that i received it. Help. No TWO men can exert enough twisting pressure to open it to remove it. It just "clicks".
  • 90 Answers
If it is a keyless chuck soak the inside of the chuck with oil. charge the battery so you have max power. put a cloth around the chuck and use a pair of channel locks to hold the chuck and put the drill in reverse. good luck
Posted on Sep 02, 2010
Chuck is stuck OPEN black and decker power drill
Try beating on the side of the chuck with a rubber mallet and then try and close.
Oct 25, 2013 | Dewalt DW056 18 Volt Cordless Impact...
Have a screw head stuck in the chuck .. it was a small bit and now wont pull out.... help
Just took apart a DeWalt, the chuck has a left hand scew that holds chuck in place, may be the problem
Jan 20, 2011 | Dewalt DW056 18 Volt Cordless Impact...
Removel of chuke
Open your chuck as far as it will go and look inside. If you see a screw go to www.ereplacementparts.com/article/890/How_to_Remove_a_Drill_Chuck.html for a good how to on this.
If there is no screw inside the chuck you have to take the drill to a Dewalt service center and have them remove it. It takes a special jig to remove it and I don't think you want to spend over $200 to remove one chuck. Do not try to use the taper-fit tool on a cordless drill, they do not use the taper fit chucks.
Sep 09, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
My drill bit has stuck in the chuck of my dewalt sds chuck ,have tried wd40 but still stuck
I had the same problem. I put the drill onto Hammer/Chisel action and it helped release the bit.
May 16, 2010 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
How to remove a chuck from a DeWalt hand drill
Open chuck all the way (like for a large drill bit). There should be a set screw at the bottom (where you would put a drill bit). Don't turn too hard - it may be a left handed screw (I don't remember if it is a lefty for sure but try gently each way then with a bit more force each way until it moves).
Good luck.
Mar 19, 2010 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
My dw056 breaks bits can you change the hammer to a 1/4" or 3/8" hammer they look the same on the manual
in order to make the 1/4" hex drive impact drive 1/4" or 3/8" sockets, you need a 1/4" hex adapter for sockets.
They are available at most hardware stores. While i've broken several sockets, and many screwdriver bits, I've never had an issue with with the socket adapters.
You can also get an adapter that gives you a chuck like a conventional drill.
If you've been working them hard, it's not a bad idea to remove them, and put them back in. this reduces the chance of getting the bit stuck from the repeated impact.
As far as changing the chuck of the unit to another one, i'm not sure if it's possible.
Help me support children’s cancer research CLICK HERE!
Mar 08, 2010 | Dewalt DW056 18 Volt Cordless Impact...
How do i remove the chuck from dewalt dc925 cordless drill, dosnt have a screw inside the chuck, read somewhere that i need a special tool but no instruction or picture of the tool. please help., thank you
The dc925 and the current model dcd950 along with several other models of Dewalt 's line of cordless hammer drills DO NOT have a screw inside removal requires a CHUCK REMOVAL FIXTURE part #
233804-40 also you can't use a generic replacement chuck. As of 2/2/2010 the prices on the Dewaltservicenet web site are $72.74 for
the tool and $69.70 for the chuck, part # 330075-90.
Oct 17, 2009 | Dewalt Heavy Duty Xrp 1/2" 18V Cordless...
Cordless Drill, Keyless Chuck stuck in full open position.
if chuck is wide open ,look down inside there should be an allen screw or bolt at the bottom of the chuck it should undo anti clocwise and the chuck comes off
Aug 18, 2009 | Dewalt DW056 18 Volt Cordless Impact...
Dewalt 18 volt cordless drill the chuck is stuck in the fully open position and wont close
Use a pipe wrench on it to give yourself a little more leverage. It is simply jammed all the way open and it will release when you apply enough force.
Apr 30, 2009 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver Logo
879 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
