Question about Cameras
Nikkor 105mm Ai-S micro lens aperture seems stuck
I bought this used lens for macro work with my new Nikon D300. The lens will mount and I have set the non-CPU lens data. The problem seems mechanical with the lens itself. Off the camera, I can click the aperture ring but the actual aperture does not change from f/32. Ditto when mounted onto the camera. When I try to use aperture priority, the image is properly exposed, obviously only at f/32; since the lens will not open any wider, when I turn the ring, the camera properly reduces shutter speed, letting in less and less light. The image gets darker and darker; when the lens should be wide open at f/2.8, it is still physically at f/32, letting in little light, and there is no image at all. Am I correct in assuming that the lens is defective or broken? The little manual flip lever near the rear of the lens does open the blades smoothly; they are not stuck when I flip that little lever. But the aperture does not change when I manually change the ring. Thanks
  • Anonymous Mar 16, 2009
    Same problem... with a 50mm lens. Did youget it fixed?
  • 37 Answers
It does sound like your lens diaphragm/aperture ring coupling mechanism is in need of repair.
Posted on May 04, 2008
What type of lenses fits this camera
Lens mount Nikon F mount (with AF coupling & AF contacts)
Lens compatibility • D-type / G-type AF Nikkor (except IX-Nikkor): Autofocus and all functions possible
• PC Micro-Nikkor 85mm f/2.8D: Usable in Manual exposure mode
• AF Nikkor other than D-type (except AF Nikkor for F3AF): All functions except 3D Matrix Metering possible
• AI-P Nikkor: All functions except 3D Matrix Metering and autofocus possible
• IX-Nikkor: Cannot be used
• Non-CPU: Usable in Manual exposure mode (exposure meter cannot be used)
Electronic Rangefinder usable with lens with maximum aperture of f/5.6 or faster.
Jul 04, 2011 | Fuji FinePix S2 Pro Digital Camera
Hello, I just brought my sigma macro 105mm lens and Im having trouble getting it to work probably on my nikon d90, they only way I can get it to work is turn the aperture on the lens to f32 I cant change...
Turn the aperture ring to f/32 and leave it there. After that, forget the lens has an aperture ring at all. You can let the camera control the aperture in any mode except the M and A modes. In the M and A modes, you control the aperture by turning the command dial on the front of the camera, the same way you control the aperture on a lens without an aperture ring.
Mar 06, 2011 | Sigma Telephoto 105mm f/2.8 EX Macro...
I used the Nikon D90 with Lens Kit 18-200 mm, and I also bought the new Lens call Nikkor 75-300mm. But when I connected the new one (Nikkor 75-300 mm) in my camera and took some pictures, after that I...
That's the Nikon error message for a lens with aperture ring set to something other than the minimum (i.e. highest number).
The camera insists on controlling the aperture ring, and to do so, the ring must be set to the minimum setting.
Unless it is a "G" lens, which has no aperture ring whatsoever.
The camera body sets the aperture of the lens wide open while auto-focusing, and displaying through the viewfinder. When it comes time to flip the mirror up and take a picture, the camera dials the aperture to the setting you (or the camera) have selected.
Dec 22, 2010 | Nikon D90 Digital Camera with 18-105mm...
I set this "Nikon 105mm f/2.8G ED-IF AF-S VR Micro-Nikkor Lens" or tried to set it to F2.8 in full manual mode. the F-Stop wandered from F2.8 to F3 / F4.5 depending on where i pointed the lens. I...
You have described Aperture priority mode: you set the f/stop and the shutter speed changes to make the exposure correct.
Full manual mode requires you to set both the shutter speed and the f/stop. You are seeing the recommended f/stop for the shutter speed you have selected.
Sep 25, 2010 | Nikon 105mm f/2.8G ED-IF AF-S VR...
According to the manual for my Sigma 105mm f2.8 EX DG Macro lens with my Nikon D90, when using P or Sutter priority auto mode the diaphragm control ring needs to be set to the smallest aperture(f32) and...
In all modes the aperture ring on the lens should be locked at the smallest aperture. In the M and A modes you control the aperture by turning the command dial on the front of the camera. In P and S modes you control the aperture indirectly by turning the command dial on the back of the camera.
Aug 04, 2010 | Sigma Telephoto 105mm f/2.8 EX Macro...
ON DISPLY, APERTURE SHOW fEE AND DONT SHOOT
In all but aperture priority mode and manual modes you must set this lens to it's minimum aperture setting (i.e. highest number) to allow the camera body to fully control the aperture for you.
You'll also get this problem when using certain Nikon bodies which rely solely on electronic communication of the lens settings to the camera body (e.g. Nikon F75) as they lack the ability to read the mechanical linkages on the rear of the lens.
Oct 04, 2009 | Nikon Telephoto AF Micro Nikkor 60mm...
Lens will not open up all the way
Is the maximum available aperture dependent on the focus distance? Many macro/micro lenses "dim" slightly as you focus in close.
See if you get 2.8 focused at infinity.
May 22, 2009 | Nikon Telephoto AF Micro Nikkor 105mm...
Sigma 70-300mm DL Macro Super Lens compatibility for Nikon D40X DSLR Camera
Here is Nikon's specs of lens compatibility for the D40X:
Compatible Lenses*: Nikon F mount with AF coupling and AF contacts Type G or D AF Nikkor:
1) AF-S, AF-I: All functions supported;
2) Other Type G or D AF Nikkor: All functions supported except autofocus
3) PC Micro-Nikkor 85mm f/2.8D: Can only be used in mode M; all other functions supported except autofocus
4) Other AF Nikkor*â¹/AI-P Nikkor: All functions supported except autofocus and 3D Color Matrix Metering II
5) Non-CPU: Can be used in mode M, but exposure meter does not function; electronic range finder can be used if maximum aperture is f/5.6 or faster
6) IX Nikkor lenses cannot be used
*â¹ Excluding lenses for F3AF
They do not recommend 3rd party lenses, ever
Feb 01, 2008 | Cameras
Aperture cannot open fully
As you have found out, it is not a lubrication issue. It would seem that your lens has a problem with the linkage arm inside the mount. The arm that extends out of the mount could be bent or misaligned. It would be fixable, but the parts are somewhat delicate. Best to let a good repair person have a look.
Dec 29, 2007 | Nikon 105mm f/2.5 Nikkor Ai-S Lens
Cameras Logo
591 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
