Question about Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304)
Y router ip is 192.168.2.1 and wireless ip is 192.168.1.1. so whats my 10 pc ip and gateway plz tell me
  • Gateway Master
  • 6,487 Answers
IN order for you to check the IP address and default gateway of your computers it will be better if you check it under command prompt. To do that click Start > RUN then type CMD and hit enter then the command prompt will open type there IPCONFIG and hit enter and there you will see the information that you need.
Posted on Aug 21, 2010
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
No connection
Ok here is what you do
1.) disconnect your internet cable
2.) connect your router to your computer
3.) in internet explorer type 192.168.1.1
4.) enter your username and password
5.) click on Lan
6.) In the ip address box change your router ip to a new ip
e.g. 192.168.1.2
7.) Click on DHCP AND ENABLE THE DHCP SERVER
8.) Click on wan
9.) In Wan settings choose static ip address
10.) set the static ipaddress to the ipaddress you entered for your router
11.) set your subnet mask
12.) In the isp gateway enter your modem ip e.g 192.168.0.1
13.) as your primary dns enter your modem ip e,g 192.168.0.1
14 save changes and exit
YOU CAN HAVE THE ROUTER AUTOMATICALLY ASSIGN AN IP ADDRESS TO EACH SYSTEM OR YOU CAN SET IT AUTOMATICALLY
FOR AUTOMATIC ASSIGN JUST CONNECT THE CABKLE
FOR STATIC IP(recommended)
double click on the network icon to the buttom of your screen e.g LOCAL AREA CONNECTION
Click on Properties
Double Click on Internet Protocol(TCP/IP)
Enter the ip address you want the computer to have using the same 3 bloacks as your router e.g 192.168.1.10
Enter your sub net mask
Enter the ip for your moden in defaul gateway e.g 192.168.1.1
Enter the Prefered Dns as also your Modem ip 192.268.1.1
cheers
Jan 05, 2008 | Linksys Wireless-G WRT54G Router
I cant connect internet through hardwire(ethernet) but i can connect to internet by wireless... and it keeps on telling me Unidentified network.
Not really ...
1 thing that should not be in common between your wireless and modem is GATEWAY...
Your default modem gateway will be 192.168.1.1
change your router gateway to 192.168.2.1 or 192.168.3.1
to do this ...
1. click on start menu , type cmd , enter
2. COMMAND PROMPT dialogue box opens .
3. type . IPCONFIG
3. note your Default gateway.
4. open internet explorer
5. type your default gateway in browser address
6. it will prompt you to give user ID and password .
7 Your USER ID and password is ADMIN .
8. your router setup page opens .
9 change your local IP address to 192.168.3.1 .
10. Check mark on BRIDGING MODE .
11. Disable and enable your ethernet .
12 . now try connecting to INTERNET .
It should work . .
May 22, 2009 | D-Link Vonage-enabled Wireless Router...
Can't access Config Manager for Router - Zoom x6 5590
- Reset the router (10 seconds)
Access the configuration page (10.0.0.2)
or
Try to assign a static IP address to the computer (IP 10.0.0.52 Automated SubnetMask, Default gateway 10.0.0.2)
(Note: Make sure that your computer is physically connected to the LAN ports of the router and your modem is connected to the WAN or Internet port.)
Mar 08, 2009 | Zoom X6 Adsl Wireless Gateway Rohs Router
Cannot Access My DWL-3200AP
If you can browse internet via same device
Start/ Run/ CMD/ type "ipconfig" (w/o ")
Use default gateway IP address as your AP ip address..
Enable java and use IE (some devices prefere IE)
e remember to score this tip.
Jan 15, 2009 | D-Link AirPremier DWL-3200AP 802.11g/b...
How do I secure my DLink-524 wireless
In securint your wireless security try accessing the configuration page of the router. go the the window where you created your wireless netowrk connection.
On that Wireless window choose WEP for security.
By defaut WEP Encryption is 64bit.
Under Key1 erase what's on the box and type in the password for your wirelss network. It should be exactly 10 characters, You could use 0 to 9 or A to F then click on Apply >next.
Try Accessing your wireless networ.
Nov 19, 2008 | D-Link AirPlus DI-524 Wireless Router
Help plz
1. Click on Start Button
2. Goto Run
3. Type in cmd in the Run command box
4. Click OK
5. once black "DOS" box comes up type in ipconfig /all
6. Grab peice of paper and write down the Gateway IP address, should be 192.168.1.1 or something to that effect.
7. Open up Internet Explorer
8. In the address bar at the top type in the gateway ip address in this format (EXAMPLE) http://192.168.1.1 then hit enter
9. You should now be at your routers home page
10. Poke around and find the wireless security settings, you should have options like WEP/WPA/etc for encryption options.
11. The admin pw should be blank(nothing entered) or admin if it has never been set before.
12. If the routers admin pw has been set already and you don't know it, you can set the router back to factory default settings by grabbing a paper clip and pressing and holding the little tiny hole button on the back of the router.
Please rate this accurately and my instructions may not be EXACT, but use common sense.
Sep 10, 2008 | Belkin (F5D9230-4) Wireless Router...
How to secure my wireless
Goto Run
Type in cmd
Click OK
At prompt type ipconfig
write down what your gateway IP is
Open up Internet Explorer and type in gateway IP addy in the address bar
Goto Wireless security section and away you go...
Aug 28, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I can't access my router through the URL.
Open your router, in the IP settings make sure your IP range is set from 192.168.0.1 to 192.168.0.10 this will give you 10 different IP address so that all computers will be able to connect with their own individual IP's. provided you have less than 10 machines
This is unusual to have this IP, most have 192.168.100 Do this to confirm your IP, on the computer that you have the wireless router connected to hit start-run-type in CMD when the command prompt box opens type in "IPCONFIG" this will tell you what the computer has for all you settings if they do not match the router make the necessary changes in the router.
Aug 20, 2008 | Linksys Wireless-G WRT54GS Router...
Internet access problem with a Linksys 54g router
Try setting the default gateway on the laptop to the ip address of your ICS gateway machine. Some routers separate the wireless and LAN connections on different subnets.
Try comparing your laptops ip information with that of one of the working wired computers. You can do this by going to Start up to run and type cmd then click "ok"
At the black prompt screen type "ipconfig" without the "".
You want to compare the IP Address, Submet Mask, and Default Gateway.
If one has an ip of 192.168.1.* and the other has 192.168.0.* then the wireless and wired are on seperate networks.
If the subnet masks are something like 255.255.255.0 and 255.255.255.1 they are on seperate subnets. Both should be fixable by putting in the same default gateway.
For example if your ICS gateway is 192.168.1.1 then set that as the default gatway on the wireless laptop. This can be done by going to start >> Control Panel >> Network Connections then right click your wireless connection and goto properties then double click on the "Internet Protocol (tcp/ip)" option. This will list all of your ip information (if its static) if its dynamic (ip gotten from router) you can still click "Use the following DNS server address" and set preffered dns to the gateway ICS ip. Or click "Advanced" and click Add under Default Gateways and add the gateway ICS ip there.
Jun 20, 2008 | Computers & Internet
Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304) Logo
80 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
