Question about Vacuums
SMC Ceiling Fan Model T52 electrical wiring diagram
2 Suggested Answers
jim4984
  • 797 Answers
SOURCE: Reinstalling a hampton bay ceiling
The black and blue wire should conncect to the black wire in the electric box and the white wire should connect to the white wire in the box. This assumes the wiring was correctly installed.
Jim
Posted on May 12, 2011
The light on a fan is flickering. It doesn't appear to be the light bulbs. This fan has a remote control and it controls the fan OK and turns the light on and off but it flickers. What could be...
Try changing or testing the batteries in the remote or take the remote out of the fans range. See if this stops the flickering. It can also be the individual bulb. Sometimes the monofillament wires become loosened. It won't hurt the fan to use a broken bulb but it will shorten the life of the bulb. They do get the daylights shook out of them! If all the bulbs flicker it can be the twist connects. These are located under the ceiling plate cover. To check, shut off the fan or turn off the braker switch to make sure you don't get a shock (but I really doubt it). Remove the face plate ceiling screws to expose the wiring. There should be a black and a red cap that holds wires together. Black is ground red is power. One at a time hold the wires of the black cap with one hand and give the cap a gentle clockwise twist with your other hand to see if they need tightening. Repeat with the other colored cap. Push the wires back up inside the housing if needed and replace the cover.
These are the simpelist things to try before calling an expert. I hope this helps?
Sep 22, 2011 | Vacuums
This fan will not run. We do not have a model # but the numbers on it is:LOT NO. T-163 P/N 2030016H. Is there a wiring diagram we can get for this? It is a fan withat goes in a window and has an exhalst...
This is used in a Lasko 2155A window fan. It is best to buy an entire new unit. The motor does not seem to be available anywhere.
11/20/2015
Feb 26, 2011 | Dayton Vacuums
I have a model 484 709 UPC 792145330547 The fan/light is close to ceiling (instalation). Their is supposed to be an "o" ring to remove the fan/light from the celling. I cannot find it!!! ...
Remove the cowl at the ceiling by removing the screws in the cowl (very close to the ceiling). Use caution in removing them as the weight of the fan may be carried by these screws. Depending on the style, though, the weight may be borne by supports beneath the cowl. Either way, this will get you access to the wiring, allowing you to change out/remove the fan. If the fan and cowl are together, and close to the ceiling, there is usually a method of hanging the assembly while the wiring connections are made during installation. Look for a hook that the screw hole will go over, supporting the fan.
Best regards,
--W/D--
Jan 19, 2011 | Vacuums
The switch on the wall only works to control the fan and not the light- it won't turn off the ligght. I replaced the switch but it did not solve the problem
If this is a new installation and there was only one switch on the wall, say to control a light that was once there, then you have that switch hooked up only to the fan. If you want to control the light as well, it has to be wired up at the box where the fan attaches to the ceiling. HOWEVER, with only one switch, the light and fan will always be ON or OFF at the same time. You would need to wire in another switch to control the fan and lights independently.
Oct 03, 2010 | Vacuums
I have a ceiling fan with 3 lights. We do not use the remote control and did not install it. The lights stopped going on today. The fan works, but the lights do not. I have tried changing bulbs, but...
Sounds like a loose wire. If you turn the lights on via a wall switch or a pull chain, I would start where you hooked the wire for the lights to the house electricity, most likely where the fan meets the ceiling. Pull the "bell" part of the fan down that covers the ceiling box and see if there is a loose wire inside. There should be a plastic cap called a wire nut that covers the wire connection. Make sure it is secure and if possible, put some electrical tape around it. Please let me know if you have questions.
Sep 12, 2010 | Vacuums
No manual with my fan, trying to put the fan up, please advise
Kind of hard to help you with this little information you have provided, but this is what I would do. FIRST and most importantly, you MUST use an approved box hanger to hold the (I am assuming a ceiling fan) fan to the electrical box for connection. BE SURE THE POWER SOURCE TO BE USED IS TURNED OFF!!!!!! Determine the power wires for the fan unit (most likely a black, white and green wire) and, observing the proper polarity, connect to the house wiring. Make sure you are using an equipment ground to the fan. This is usually a bare or green wire. If these instructions are not clear to you, you may want to have a professional install the unit. You should also check with your local municipality about the need for a permit to do this installation.
Aug 27, 2010 | Vacuums
The ceiling fan does not shut off wire colors: blue,black,gray,white
If the fan will not shut off it is most likely not a wiring problem, but a problem with the switch not working properly...
the switch is stuck in the on position even though it may sound like it is working...
use an ohm meter to check the switch out...
heatman101
Aug 05, 2010 | Vacuums
Who makes Heritage Ceiling fans?
unfortunatly there are many manufactures that have a "heritage" model fan ... like casablanca, minka aire, concord and emerson ... even Kmart sells a fan called Heritage (not a bad fan) ... of the above, casablanca has a high end model called "heritage" and that name is likely the domanant brand .. if you can find a model number then it can be isolated better ... .
here is info on that one
Casablanca Heritage Ceiling Fan
http://www.carolinarustica.com/product.asp?pn=CB-C19624F&sid=BECOME&utm_source=Become&utm_medium=cse&utm_campaign=MerchantAdv
Apr 15, 2010 | Vacuums
Electrolux canister vacuum
The easiest solution would be to call your local Aerus/ Electrolux representative, because the corporation doesnt publish diagrams.
Sep 15, 2007 | Electrolux Lux 5500 Canister Vacuum
Vacuums Logo
418 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
