Question about Swiss Legend Watches
What can you do to make the karamica ceramic watch smaller when there are no more links to take out? there bound to be something else you can do to the watch.
    Guru:
  • 732 Answers
Common solution, locally.... :)
Posted on Nov 04, 2017
  • 831 Answers
Im sorry but if you have taken out all the links, that is all you can do. Sorry.
Posted on Aug 21, 2010
Replace links on Swiss legend ceramic watch
here is a video that will show you how to remove links on your ceramic watch band
Jan 18, 2013 | Swiss Legend Karamica Chronograph Ceramic...
I have a swiss legend keramica and i cant ajust the bracelet
Most bracelet adjustments require a special tool that is only found in a jewelry store, or your watch can be shortened by the manufacturer. Many watches have pins that push out if you look on the back of the band there should be arrows the pins push in that direction if you have something small enough to fit it the hole, be very careful to put the pin back in the same way. Occasionally some watch bands are not pins they are screws and it can be very difficult to tell the difference between the two. If the watch band has a screw it requires a very small screwdriver and you must be careful NOT to strip the screwhead! You can also shorten some watches by just moving the pin in the band buckle if you have a small tool you should be able to do this yourself, BUT wear glasses because pins will spring out, keep pointed away from your face. Hope this helps!
Sep 13, 2011 | Swiss Legend Karamica Beige Ceramic Watch...
How do i remove links from a ceramic lucien piccard watch?
Browse through my Tips and Tricks. There you will find how to add or remove links.
Feb 24, 2011 | Lucien Piccard 26024 Wrist Watch
Can you please tell me how to remove links on my le cheatau ceramic watch?
Hi, sizing the bracelet on your ceramic watch may void its warranty, making it ineligible to receive service from the manufacturer. If you want to keep your watch covered under warranty, contact your watch manufacturer for information on their customer repair service.
If you want to remove it yourself, you need a watch pin removal tool. You can use a watch pin removal tool to remove the link pins that secure the clasp pieces to your ceramic watch band.
But if you don't have a watch pin removal, follow the instruction below........
  • Find a clean, flat, well-lit work surface where you can size the bracelet of your ceramic watch. For best results, spread a soft optical cloth over your work surface and perform your repair on top of the cloth. The cloth will help prevent you from losing any small watch components, like link pins, that may be freed during repair.
  • Wrap the ceramic watch band around your wrist and count how many links overlap. Use this as a guideline for how many links should be removed. Note that the actual number of links to be removed may differ slightly from the original estimate. Remove excess links from your watch band one at a time to make sure that you don't end up accidentally making the band too short.
  • Remove the excess watch links from the ends of the band with the attached clasp pieces. Look between the removable ceramic watch links to locate the silicone connector pieces that join the links. Use a pair of small, pointed scissors to make a cut between the link and the silicone connector, this will free the excess links. Cut on the side of the link that faces the watch clasp. Repeat the process on the other side of the ceramic watch band.
  • Remove the clasp pieces from the ends of the removed watch links. Examine the clasp pieces to look for the metal pins that hold them in place. Push out the metal pins with a push pin to free the clasp pieces. You can now reattach them to the ends of your ceramic watch band.
  • Examine the newly-shortened ends of your ceramic watch band. Without the clasp in place the silicone connector pieces will be exposed. Note the two small puncture holes that go straight through the silicone connector. Insert the teeth of one of the clasp pieces through the holes in the silicone connector from the bottom. Fold over the other side of the clasp piece, reinsert the metal link pin and push the clasp to click it into place. Attach the second clasp piece to the other side of the watch band using the same procedure.
Jan 06, 2011 | Watches
I cannot find an authorized Swiss Legend Repair Center or Retailer in the Pittsburgh, PA area. I need the band sized and no stores that I've been to have had the tool required to take the links out....
Thank you for contacting FixYa.
What kind of stores were you taking too?? If you were going to places like Sears, Walmart etc I can see this, And most retail jewelers.
Honestly, I would look under yellow pages for a watch repair store. They should have most watch tools. I googled and found plenty in your area.
If still no luck then send to Swiss Legend at:
http://www.swisslegend.com/
Best regards. Jewel
Sep 18, 2010 | Swiss Legend Karamica 1.00ct Diamond...
I have a michael kors white ceramic watch and the band is too long? how do i remove links?
Ceramic links break VERY VERY Easily!!! Take your watch to a reputable watch repair shop and have them adjust your watch band! :-)
Jan 15, 2010 | Watches
I need to have the bracelet of a Swiss legend Karamica,sized in Sacramento Ca
There is a store called Fast Fix jewelry and watch repair. I believe they have locations in california. They are usually in the mall. They can size watch bands. A good quality jewelry shop might be able to. And you might just look in the phonebook for a watch repair shop in your area.
Jul 31, 2009 | Swiss Legend SL-LUCERNE-ML134AC Wristwatch
Watches Logo
153 people viewed this question
Top Swiss Legend Watches Experts
Jimmy Accardi
deton8 von Splosion
Are you a Swiss Legend Watch Expert? Answer questions, earn points and help others
