Question about Kenmore 15516 Mechanical Sewing Machine
My Sears sewing machine will not sew with polyester thread. Polyester thread is the only kind of thread sold at Wal-Mart and fabric stores. The manual says to use cotton covered polyester. So now what do I do?
    Genius:
  • 1,788 Answers
I am sure that you machine will sew with polyester thread, I think the problem is with your threading of your machine. Read your manual
Posted on Aug 21, 2010
I cannot get the perfect stitch to sew cotton polyester. It seems like the red thread is loose loops
Check you tension if bottom thread loopy it's the spool try re threading machine. And change the needle
Jun 27, 2018 | Sewing Machines
I have a B350, i want to sew with just straight ordinary stitch, but the top stitch is too lose, the bottom stitch looks great. IN other words, i can pull the top thread out without any problem.
You need to tighten the upper tension--higher the number, the tighter the tension. Be sure you are using the appropriate needle and thread for the fabric being sewn.
If using 100% polyester thread, be sure it is a good brand--not Coats & Clark, bargain bin threads, or old thread.
Oct 08, 2017 | Sewing Machines
Why wont my Bernina Virtuosa quilt three layers of fabric including a polyester batting?
Depends what exactly is happening with your machine, not stitching? fabric not moving? pulling up polyester??? puckering?? tension issues?? Verify it is threaded correctly. It could be an incompatibility of the needle/thread/fabric sandwich. Be sure to use a brand new sharp needle. You may need a walking foot. If it is not a good quality of polyester batting, it could cause issues. Poor quality thread. Tension not adjusted. Etc...
You can probably narrow down the problem by trying different batting, different fabric, different needles, and different thread on scrap fabric sandwiches.
Aug 05, 2017 | Bernina Sewing Machines
Singer 99 not feeding heavy thread.
Unfortunately, your domestic machine was not made to sew leather. It can probably sew lighter weight leather with a lighter weight thread. Your thread is most likely too heavy for the machine you are using so it is not able to pick it up properly.
Apr 19, 2017 | Singer Sewing Machines
What kind of thread do I use for the Expressive 820
You would use sewing machine thread depending on what you are sewing. If you are embroidering, you'd probably want to use embroidery thread. If you are quilting, you would probably use cotton or quilting thread. If you are sewing garments, then you will probably want to use polyester or polyester-wrapped cotton thread.
Be sure you are using the correct needle corresponding with the thread and project. (You don't have to use Schmetz needles, but this is a great guide.) Also, change the needle often to avoid sewing problems.
Schmetz Needles Needle Guide
Dec 12, 2016 | Sewing Machines
Tension setting for sewing denim on brother LS 2125
Refer to 'Manuals Online', Brother sewing machine user manual. There is an excellent guide to tension settings for all fabric types. Also remember to check upper and lower thread has been wound through correctly and are using the same thread top and bottom. Ensure you have the correct needle size for denim ie 100/16 and the correct thread size ie 40-50 cotton or heavy duty polyester.
Nov 09, 2016 | Brother Sewing Machines
How can I stitch Stretchable cloth with this machine..
Be sure you are using the correct needle for stretch fabric.
All About Needles
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=5&ved=0ahUKEwjmkeKwzpbOAhVPVWMKHVBjAAQQFgg3MAQ&url=http%3A%2F%2Fwww.schmetzneedles.com%2Flearning%2Fpdf%2Fschmetz-needle-chart.pdf&usg=AFQjCNHTR52AmqwzvyCjbXmD5Ch52Va5_Q&cad=rja
Set your machine for a zig-zag (or stretch stitch if you have it) to accommodate the fabric stretch.
Use a good quality thread. Avoid old or bargain bin threads. Cotton thread will break easier than polyester.
You may need to adjust the tension for the fabric.
How to Sew Knits and Stretch Fabrics with Sewing Machine
3 Things To Know Before Sewing With Lycra SewsNBows
Sewing Spandex Tips
Jul 28, 2016 | Singer Sewing Machines
Needle stitch fine. Bobbin stitch loops.
First, try a brand new needle.
Second, consider using a better quality thread. By all means, AVOID old or bargain bin threads. Coats & Clark used to be a standard, but thread quality has improved over the past few years, so you may want to check out other brands like Aurafil, Superior, Isacord, etc. Also, cotton wrapped polyester thread releases thread lint that contributes to build-up of gunk in the machine. Some sewists have noted that they experience more sewing issues when using C&C threads. However, some machines will do better with certain thread brands than others, so some experimentation may be beneficial.
Third, check the stitch on your sample again. Generally, when thread loops appear on the underside of the fabric, it is the upper thread that is the problem. If loopy threads appear on the top of the fabric, it is the bobbin thread that is the issue. You can even use a different color in the top to help distinguish which thread is the problem.
Fourth, when threading the upper thread, Always Raise the Presser Foot during the threading process so the tension disk is released and the thread can seat properly. "Bird nesting" occurs when the thread is not seated in the tension disk.
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
Fifth, when the upper thread appears on the underside of the fabric, the upper thread tension is too loose. If the bobbin thread appears on the top of the fabric, the tension thread is too tight (or the bobbin thread is loose). Start out with the upper tension set at the midway point and tweak it from that point. The tension is ideal when both upper and bobbin threads meet in the middle of the fabric.
Also, remember that tension is not static--a tension setting for chiffon will most likely not work on cotton or denim. Get comfortable adjusting the tension to suit the project you are sewing.
May 24, 2016 | Sewing Machines
Sewing machine isn't sewing at all...got this 2 months ago, used it 4 times, began breaking thread..ready to sell.
Breaking thread could be caused by a couple of things:
1) top tension too tight
2) machine not threaded correctly
3) poor quality thread (don't use bargain thread)
4) needle not compatible with thread/fabric
5) needle installed incorrectly
First thing to try is remove all the thread from the machine, RAISE the presser foot so the thread will seat properly in the tension disk, then re-thread from the beginning--make sure you do not miss any steps.
Usually the factory standard tension setting is with the dial set at the mid-way point between the low and high number. The tension is correct when both the upper thread and the bobbin thread meet in the middle of the fabric.
As a reminder, since your machine is a mechanical, be sure that you are cleaning and oiling on a regular basis. Use ONLY fresh good quality sewing machine oil (not 3-in-1, WD-40, cooking oil, or the old oil from grandma's sewing basket). Follow the instructions in the manual. If you want to do a thorough job, open the top and free arm cover. Slowly hand rotate the handwheel and apply 1-2 drops of oil every place that metal rubs on metal. Do NOT oil rubber, plastic parts or belts. Be sure to apply a drop on the shuttle race every time you begin a new project. Oiling according to the instruction manual should be done every 40 hours of sewing time. If in storage, oil every six months.
Here's a web site that may be helpful:
Sewing Machine Problem 1 Thread Breakage
Here's a manual for your machine:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0ahUKEwjNgO6QxsDJAhXnjIMKHXzFABoQFggtMAI&url=http%3A%2F%2Fecx.images-amazon.com%2Fimages%2FI%2FB1dzfyluFLS.pdf&usg=AFQjCNEBTgKmXv2EyHiiw-px33CFogPHXA&cad=rja
Here's information about needles:
http://www.schmetzneedles.com/all-about-needles/
Dec 03, 2015 | Brother LS-2125 Mechanical Sewing Machine
Lost manual
  • I'd satisfied to sew cotton/polyester than silk fabric, match more commonly use needle for cotton is no. 14 and stich no.3
Mar 08, 2009 | Sewing Machines
Kenmore 15516 Mechanical Sewing Machine Logo
110 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
