Question about Jacuzzi Home
My commode seat slides from side to side constantly. I will tighten the fitting on the connection of the seat and it will last a little while and THEN it will slide from side to side and I have almost fallen several times. I need help before I fall and break my neck! and THEN ----HELP!
SOURCE: alarm blinking
unplug from the computer...unplug from wall..press on button while plugging back in wall(no computer) and see if that helps you
http://tinyurl.com/6qcpgy
Posted on Aug 18, 2008
  • 3 Answers
SOURCE: belt sander adjustment
There should be a knob on the front of the sander which adjusts the front roller on the sander. If the belt runs off in the same direction each time try turning the knob as the sander is running and while watching the belt. If turning the knob one direction does not work try turning the other direction. If turning the knob does not have any affect on the way the belt tracks on the sander then you probably have a broken or missing part on the front of the sander. This may require taking the sander to a service center.
Posted on Oct 08, 2008
SOURCE: side kick slide unlock code please
Follow the instructions below:
go to phone messaging
then picture messaging
press jump button,
go to settings,
go to accounts,
press jump button again, (or press jump+n)
select new account,
insert these settings in the feilds provided
apn: wap.cingular
proxy blank
port blank
username:WAP@CINGULARGPRS.COM
password:CINGULAR1
server blank
mmsc: http://mmsc.cingular.com
mms proxy: wireless.cingular.com
mms port: 80
:D
enjoy picture messaging on the sidekick slide with att :D
Posted on Sep 09, 2009
Phantomgreen
  • 128 Answers
SOURCE: Item: Kohler toilet seat. 4734-0, Rutledge Quiet
I would stack washers on the underside of the nut.
Posted on Mar 21, 2010
SOURCE: HOW DO YOU TIGHTEN A VITRA TOILET SEAT THE CHROME
need lock washers.
Posted on Oct 27, 2010
Loose toilet
Get a package of toilet shims from a hardware store. Look at the bolts on both sides of the commode that mount to the floor. There may be covered with a cap. Slide shims under the ceramic until the rocking stops. Carefully tighten the bolts until the unit is solid.
If the flange bolts are no good, you can change them (again the hardware store), but you will have to remove the commode and replace the wax ring before resetting it.
Apr 07, 2015 | Home
The mullion is broken in my Lg refrigerator
I have a related question. My lower spring broke and I have the replacement spring. How do I put it into both plastic fittings at the same time. One arm on the spring goes on mullion while the other arm goes into a fitting on the door. Please help!
Aug 15, 2012 | LG 4-door French Door Refrigerator...
How to fit a fuel pump in golf mark 3 cl
REMOVAL & INSTALLATION NOTE: On CIS systems the main fuel pump is located under the vehicle in front of the rear axle or in front of the tank on the right side. 1990–92 Cabriolet, Golf, Jetta and Fox TRANSFER PUMP
  1. Remove the rear seat and the access cover.
  2. Disconnect the wiring and hoses and unscrew the lock ring.
  3. Carefully lift out the pump and gauge sending unit assembly.
  4. When installing the assembly, use a new seal.
MAIN PUMP
  1. Disconnect the negative battery cable.
  2. Relieve the fuel system pressure.
  3. Raise and safely support the rear or right side of the vehicle on jack stands.
  4. Disconnect the wiring from the pump. Clean any dirt away from the fuel line fitting.
  5. Use locking pliers to pinch off the fuel line from the transfer pump to the main pump. If the fuel line is metal, remove the rear seat and access panel and disconnect the line at the transfer pump.
  6. Place a pan under the pump and disconnect the fuel line fitting from the pump.
  7. Remove the retaining ring screws and slide the pump out of the reservoir. To install:
  8. Moisten the pump O-ring with a little fuel and slide it into the reservoir. Install the retaining ring screws.
  9. When connecting the fittings, use new copper washers and tighten the fittings to 15 ft. lbs. (20 Nm).
1993–99 Cabrio, Golf, and Jetta
  1. Remove the negative battery cable.
  2. Raise and safely support the vehicle.
  3. Relieve the fuel system pressure.
  4. Remove the rear seat and the access cover.
  5. Disconnect the wiring and hoses.
  6. Remove the fuel lines from the pump.
  7. On 1993–99 Golf, Jetta and Cabrio vehicles, unscrew the fuel pump retaining ring.
  8. On all other models, remove the mounting bolts and the fuel pump.
  9. Carefully lift out the pump and gauge sending unit assembly.
  10. Empty the fuel pump into an approved container. To install:
  11. Installation is the reverse of removal. Be sure to use new sealing rings and/or gaskets.
Aug 19, 2010 | 1993 Volkswagen Golf
My drivers side power seat moves slides back and
No the adjusters for power seat are made from some steel and a lot of aluminum parts. Replacing the seat tracks are your only option to be safe for they are riveted together
Apr 03, 2010 | 1999 Dodge Durango
Just bought a cedo rue soft close. any idea of order of washers going on etc as instructions unreadable
Metal peg fixing goes "into" large plastic "cup" washer. Metal fixing now goes through holes in toilet pan sitting in the "cup" washer. From the bottom push up the thin round plastic washer, convex side towards the hole. Next the oval shaped thick washer flat side towards the hole. This has a cup shape into which the final plastic screw fitting pushes into (like a coax plug on the TV aerial). This will push up the thread into the cup where the sides force the thread to grip. Finger tighten so that you can still move the metal fixings from the top. Line up the toilet seat holes and push fit onto the pegs. It may take a smart thump to get them fully seated. Before tightening with the supplied black plastic spanner" make sure the large "cup" washer on top has not got trapped under the metal fixing. If all is ok line up the seat and tighten.
Dec 24, 2009 | Home
Power sterring hose leaks. how is hose connected to pump
Most of the PS pressure hoses are Compression Fittings. If the fitting is straight on and is clean on the inside before you seated the hose, there may be a burr of the pump side where the fitting sits. Some of these fittings are replaceable and others require a new pump. Check your new hose also for cracks where the pipe section of the hose is that looks sort of like a trumpet end. If the fitting is in good shape, the pump fitting is clean and unmarred, you may need to tighten the hose a little more.
Jul 22, 2009 | 1989 Toyota Celica Liftback
How to loosen the straps on envenflo tribute carseat?
This is about all I could find for you. Hope it helps.
Had one - its a huge pain in the **** and I always busted my fingernails doing it. The metal clips have to slide over the bumps to get them out. I hated that thing. May I make a suggestion? Return it. lol . I'm figuring you got a combo seat - Evenflo Generations, Bolero, Chase, that is a forward facing only seat to 40lbs, or a convertible seat like Evenflo Tribute that is forward facing to 40lbs. Since I don't know her age its hard to make a suggestion, but for just a little more money (we paid $79 for our Chase) you could get a much better seat. If she needs a convertible that will rear face, get the Evenflo Triumph for $150 or less, The Evenflo Triumph Advance (not the original Triumph, make sure it says Advance) is a great seat. $150 version at Babies R Us has padding similar to Britax seats, top slots of 17", harnesses to 35lbs rear facing, and 50lbs forward facing. $120 Walmart version just has little less plush padding. Wide open belt path, easy to install, though it doesn't have built in lockoffs. The harness adjusts at the front of the car seat, you don't have to take the car seat out of the car just to raise/lower the straps. It's one of only 2 seats that does this (The Britax Boulevard is the other, I believE), and it has infinite harness adjustment so the harness always fits perfectly until its outgrown. No more tugging straps to tighten them either. You tighten and loosen the harness using knobs on the side of the seat. As a major bonus, it can be used in a recline position even in forward facing mode. Awesome for kids who still sleep in the car. I LOVE THIS SEAT! LOL My son, who is too big for every other car seat at Walmart has the same amount of room in this as the Britax Marathon.
If she is forward facing (over 30lbs and over 2years old) then a Graco Nautilus would be a lot easier to use and install, $150. Harnesses to 65lbs and then becomes a booster, will be the last seat you have to buy her. Metal reinforced.
Combo seats are usually a major waste of money, as they only harness to 40lbs, no more than most convertible car seats, so you're really not getting any more use out them then the convertible seat.
Jun 12, 2009 | Evenflo Generations
Home Logo
174 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
