How do you replace the drive belt on a front loading washing machine.
  • Washing Mach... Master
  • 2,605 Answers
Hello, welcome to FixYa.
As with most things they vary from one model to the next.
Generally you'll need to remove the back panel and rap the belt first around the motor pulley and then turn it like a bike chain around the larger drum drive pulley ( watch your fingers for pinching...oouch ! )
It should resemble this, though it is only one model...WFK2401, but essentially the same.
Let me know how you make out or if you require further assistance.
Thank's for choosing FixYa, please take a moment and rate the info provided for you here today and good luck.
macmarkus :)
Posted on Aug 21, 2010
Testimonial: "Quick and helpful information. Wasn't sure if my thought process was in the right direction."
  • sheba95 Aug 21, 2010
    We had found the belt already off. Thanks, it was like replacing an old fan belt on an older car, but it keeps sliding off the big pulley towards the drum. Is it stretched and we need to replace?
Spin. Working short time do not put cloth water out
Sounds like the belt that spins the washing drum is slipping. It my need to be adjusted or replaced, or try washing a smaller load of laundry.
Mar 10, 2016 | GE Washing Machines
Whats tricky about the remover and replacement?
How to Replace a Washing Machine Belt: 12 Steps (with ...
www.wikihow.com > ... > Washing Machines and Dryers
wikiHowLearning how to replace a washing machine belt can be tricky, but will save you from.... specifics of the location and method for removing and replacing the drive belt. ...your washing machine, then your model has what is called a direct drive.
How to Clean a Washing Machine Inlet Screen ' The Family ...
www.familyhandyman.com/...repair/washer...repair/...washing-machine...
A washing machine that takes forever to fill may have an inlet screen clogged with mineral deposits and tiny ... How to Repair a Leaking Washing Machine ... The onlytricky part is removing the screens without wrecking them (Photo 1).
Speed Queen & Amana Washing Machine Repair Manual ...
www.appliancerepair.net/washing-machine-repair-8.html
Online washing machine repair manual CHAPTER 8 - written ESPECIALLY for do-it-yourself ... Belt driven pumps are replaced by simply removing the pump mounts. Tension ... Pump or belt changing on a direct drive machine is a little trickier.
How to Remove Mold and Mildew from Front-Load Washing ...
www.todayshomeowner.com/how-to-remove-mold-and-mildew-from-fr...
Jan 10, 2016 | Washing Machines
Front loader hums instead of starting
Try to get ahold of a qualified service technician that specializes in washing machines and dryers.
My guess is it could either be if its belt driven the belt has broke and the drive motor is turning freely or the drive motor is possibly burnt out or in need of replacement.
Its not much but I hope it helps
Sep 27, 2013 | Frigidaire Affinity ATF7000ES Front Load...
I need to know how to replace the belt
hello,
intruction
Front load washers are convenient and easy to use. They offer the convenience of extra capacity and tend to wash clothes a little better than their top loading counterparts. Sometimes, however, the belt that drives the drum will break and need to be replaced. Replacing a drive belt on front load washers is not that difficult and can be performed by many home mechanics.
  • Use the screwdrivers to remove the screws in the rear access panel of the washer and then pull off the panel.
  • 2
    Locate the pump coupling, which is the rubber part that connects the motor to the water pump, and unscrew the clamps securing it to the motor. Once the coupling is removed, tension is removed from the belt.
  • 3
    Slide the belt off of the pulley assemblies and slide the new belt in its stead. Reattach the coupling with the mounting clamps and check the tension on the belt. You should be able to wiggle the belt a bit, but not more than an inch or so.
  • 4 Close the access panel and turn on the machine. Run it through a cycle while observing it to see how it handles the belt change.
  • TIPS
    Be sure to unplug the washing machine before beginning to work on it. thnak and thanks for using fixya.
    Sep 30, 2010 | Whirlpool LHW0050PQ Front Load Washer
    I have a 2 year old GE WCVH6260HWW front loading washing machine. Last night I smelled burning and there was actuall smoke in the room. I just shut it down. To me it smelled like a rubber (belt) type...
    Pull the back panel off and look at he drive belt. My pully nut loosened up and caused extreme vibration (more than usual). The pulley is aluminum and it rounded out the center hole of the pulley. The belt finally came off. I replaced the pulley and belt.
    Sep 05, 2010 | GE WBVH6240F Front Load Washer
    Hotpoint WMA32 Front Load... Problem:
    if its not your belt its the brushes in the motor that need replaced i would replace the brushes first the cost about £15-20
    Jan 04, 2008 | Hotpoint WMA32 Front Load Washer
    Washing Machines Logo
    Top Washing Machines Experts
